E46 (1999 - 2006)
Old 01-24-2005, 05:17 PM
alpinewhite325i alpinewhite325i is offline
I love my beautiful wife.
Mein Auto: '01 325i
Question Frozen washer fluid lines
It has been in the teens here in Pittsburgh, but is this normal?
I know only the nozzles are heated, but I can't believe this is happening everyday.
My Honda Civic's lines froze one time in 6 yrs.
BTW, the washer fluid is from the dealer, but I would ASSume it should have sufficient freeze protection.
'01 325i
5sp
I Love my beautiful wife
moonroof:
Old 01-24-2005, 05:45 PM
Desertnate's Avatar
Desertnate Desertnate is offline
Spelling Impaired
Mein Auto: '10 Mazda3 HB
Assuming is your first mistake.
I have a freezing problem due to the car being parked outside at work. Not only do my lines freeze, but the resevoir gets frozen solid as well.
We have only been getting cold weather and no real snow, so I have no way to get out all the summer fluid I added while living in much warmer climates and putting in the anti-freeze stuff.
I wish there was a drain plug. I am thinking about creating my own drain and finding some sort of rubber plug to fill the hole, but I am afraid the plug wouldn't stay.
Old 01-24-2005, 06:27 PM
STEVE46 STEVE46 is offline
Mein Auto: 530i Sport
Get a hair dryer to thaw out what is left of the summer fluid and then just run the washer pump to empty it, that's what it's there for. Then, fill up with some good Winter fluid or Rain-X with De-icer. Make sure it's rated to at least -20F. The BMW winter washer fluid is probably the best I've used (smell's like it has lots of alcohol in it), so I don't mind paying the premium for that.
Old 01-25-2005, 03:14 AM
Mein Auto: '01 325i
Mine froze even before the dealer added fluid, and I know the stuff I put in was good for winter.
I see you have a Sequoia too. Funny thing is, when I drive our Sequoia to work, those lines don't freeze. And...the Toyota doesn't have fancy heated nozzles either.
Too bad the IS300 is so boring!!
'01 325i
5sp
moonroof:
Old 01-25-2005, 06:09 AM
Tanning machine's Avatar
Tanning machine Tanning machine is offline
Using SPF 45
Mein Auto: 2004 330Cic
I used a siphon to get the remainder out--it's not that hard to do--just some tubing and a pump (or your mouth, if you like the taste of washer fluid). I put in the Prestone winter fluid, which so far has been fine.
The stuff you can get at safeway, home depot, etc., that's blue, although it claims to be good to "-20" really isn't--it's not rich enough in alcohol and glycol.
The added problem is that the washer reservoir is away from the engine, so it doesn't pick up much heat and defrost--all you can do once it's frozen is park inside or hope for much warmer weather.
Tanning Machine I: 1989 325iC (Salmon Silver/Black, Heated Seats, LSD). 7/26/1989-11/1/2003.
Tanning Machine II: 2004 330Cic (Silver Gray/Natural Brown, SP, PP, Heated Seats, Xenons). 8/29/2003-present.
Old 01-25-2005, 06:15 AM
Desertnate's Avatar
Spelling Impaired
My tank is almost full right now. With all the rain we have been having, I really haven't used much fluid for the last 18 months or so. I don't know if I want to just run the pump since nearly a gallon of fluid might work the pump pretty hard. It would take a while.
I have a jug of some good winter fluid/de-icer that is rated to -30. Forget the brand name, but it's this weird green color. Once I get it in I am not worried about freezing.
Old 01-25-2005, 06:18 AM
Desertnate's Avatar
Spelling Impaired
I have frozen the fluid in the Sequoia several times. The good part is since the resevoir is so close to the engine, it thaws out pretty quickly. If I run the rear heater vents, the rear washer thaws out pretty quick too, though not as fast as the front.
Bad thing about the Toyota is there is a screen over the top of the resevoir and you cant run a siphon tube down inside.
Old 01-25-2005, 06:20 AM
Desertnate's Avatar
Spelling Impaired
I noticed that too...
Last winter we had a long cold spell and I was frozen solid for nearly a week
I wonder if I can use the 'ole Turkey baster to draw out the fluid. It would save me a trip for some tubing or a siphon.
Don't tell the Mrs Desertnate
Old 01-25-2005, 06:51 AM
Staszek Staszek is offline
Mein Auto: Something German
I siphened out all the regular fluid and replaced it with Rain X antifreeze deicer stuff. $2 a gallon, and works great. It was 5 degrees yesterday not including the windchill and they didnt freeze at all, even at higher speeds
Originally Posted by Rob Levinson * UUC Motorwerks View Post
What if leprechauns installed them while unicorns watched? - Rob
Running the pump is the way I've always drained out the leftover summer fluid before winter. You won't hurt the pump, that's what it's made for. You will get fluid all over your car, but I usually need a car wash anyway. The turkey baster is a good idea if you don't want to run the pump, but get that summer fluid out! It could freeze and destroy the lines or the tank!
Old 01-25-2005, 09:17 AM
JonathanIT's Avatar
JonathanIT JonathanIT is offline
Padawan
Location: L.A., but I'd rather be on Brokeback Mountain
Mein Auto: 2004 330ci Convertible
Stay away from Desertnate's house for Thanksgiving!
--J.
2004|330ci|Convertible|Silver Grey Metallic|Sport Package|Premium Package|Steptronic|NAV|Xenon Adaptive Headlights|Heated Seats|Black Montana Leather|Aluminum Brushed Column Trim|SSR/GT3 19" Rims (original 18" Style 71's in storage)
Old 01-25-2005, 11:01 AM
I just took a plain old plastic tube, like one that you have for fish tank or whatever, put it in the top, suck a little on the end to get it started (get your mouth out of the way before it starts to come out lol! And it drained the whole tank in about a minute or so.
Old 01-25-2005, 12:39 PM
NH-SHICKS NH-SHICKS is offline
Mein Auto: 325i, 4Runner
I just had my heated nozzels replaced. My washer juice would always be frozen, now I have no problems.
Steve
Old 01-25-2005, 02:33 PM
Fast Bob's Avatar
Fast Bob Fast Bob is online now
Keeping it surreal
A wet/dry shop-vac will empty the resevoir in a few seconds. For winter use, I always add extra denatured (91%) alcohol to the mix....trying to drive in this s#it with no washers is dangerous....
Regards,
Bob
Old 01-25-2005, 02:38 PM
Miles_1 Miles_1 is offline
Mein Auto: 2004 330i ZHP
It was 83 degrees here today
I love hearing stories like this...that's why I left NYC 10 years ago.
2004 330i Silver Gray Metallic, ZHP, Steptronic, Moon Roof, Black Leather, Universal Transmitter & Xenon
Old 01-25-2005, 04:51 PM
Mein Auto: '01 325i
I almost bought the RainX; but wasn't sure if it was any good.
I think I'll give it a try.
Thanks.
'01 325i
5sp
moonroof:
Old 01-26-2005, 07:04 AM
Thanks.
It leaves a little bit of a film on the car but not bad since when you are usually using them the car is dirty from road salt anyway. They havent frozen since so far so good.
Similar Threads
My X Couldn't Provide Washer Fluid! Bavarian X5 E53 (1999 - 2006) 3 12-20-2004 01:51 PM
E46 eats Windshield Washer Fluid Fzara2000 3 Series / 4 Series 19 03-31-2004 02:00 PM
First mod... SS brake lines, question on brake fluid? jderry M Series 14 03-09-2004 07:00 AM
windshield washer fluid tank filter ChrisTO 3 Series / 4 Series 6 02-19-2003 09:54 AM
No luck with leaking washer fluid Sjumper 3 Series / 4 Series 6 01-24-2003 09:22 AM
