E46 (1999 - 2006)
Old 01-26-2005, 01:47 AM
phar phar is offline
Mein Auto: 2001 316i
Windscreen washer not working!
One of the windscreen washers has stopped working. The passenger side is fine so I am assuming that the pump and the pipes are okay.
Can I do anything or is it just a matter of replacing the nozzle?
Old 01-26-2005, 03:44 AM
Dr. Phil's Avatar
Dr. Phil Dr. Phil is offline
The Original Dr. Phil
Send a message via AIM to Dr. Phil
Mein Auto: 2012 135 coupe
could be frozen or clogged
2012 X5 Premium, Sparkling Bronze/Sand/lLight Poplar, Premium Sound, 20 Way Seats, Head Up, Comvenience, Surround View, Sirius, Heated Seats
Old 01-26-2005, 03:56 AM
It couldn't be frozen its not cold enough but it could be clogged. Is it possible to remove it and blow it out?
I think the nozzle is a heated one, does that make any difference?
Old 01-26-2005, 08:00 AM
AG AG is offline
Mein Auto: 330i
The fluid is probably frozen. Give it a few days to sort itself out. I've had it freeze before when I too thought it wasn't cold enough.
Old 01-26-2005, 08:02 AM
Desertnate's Avatar
Desertnate Desertnate is offline
Spelling Impaired
Mein Auto: '10 Mazda3 HB
I'd say frozen fluid resevoir or lines. They don't thaw out nearly as quickly as you would expect/want.
Similar Threads
Heated Washer Nozzels not working NH-SHICKS 3 Series & 4 Series 0 12-20-2004 07:45 AM
Any appliance gurus out there? Washer issues... Jetfire Off-Topic 22 01-03-2004 01:26 PM
Headlight washer seems to be leaking... pmb1010 3 Series & 4 Series 2 04-20-2003 08:46 AM
No luck with leaking washer fluid Sjumper 3 Series & 4 Series 6 01-24-2003 09:22 AM
