E36 (1991 - 1999)
Old 01-26-2005, 12:20 PM
Xster Xster is offline
Mein Auto: 97 328i
Noise at cold startup
There is a long "whizzing" noise coming from an "air pump" right next to the hood positive terminal for jumping on my 97 328i. The noise would last for approximately 2-3 minutes at cold startup then stop completely. What is that pump or whatever that is called? Any help would be greatly appreciated. Thanks,
John
Old 01-28-2005, 08:11 AM
al_r al_r is offline
Mein Auto: '96 328i
That is your secondary air pump, 'injects' fresh air into the exhaust manifold at start up time till the ECU shuts it off - strictly emissions related. If the pump fails, you'll get a CEL/code indicating 'not enough volume' in the front or rear engine banks.
If you decide to replace it, also replace the valve it feeds on the exhaust manifold.
Old 01-31-2005, 08:47 PM
Mein Auto: 97 328i
Thanks for the response al_r.
Similar Threads
Rattling Noise Cold Start! MC E46 (1999 - 2006) 46 04-22-2013 06:16 PM
E46 330 lifter noise at cold startup Limmey 3 Series / 4 Series 15 10-29-2004 08:36 PM
Starter noise after cold start - should I worry? Sterner 5 Series DIY 1 05-25-2004 04:50 AM
Cold Start Noise barryf 3 Series / 4 Series 0 04-21-2004 05:45 PM
cold start clinking noise sj-02-325Cic 3 Series / 4 Series 13 04-05-2002 10:02 PM
