E90/E91/E92/E93 (2006 - 2013)
The E9X is the latest evolution of the BMW 3 series including a highly tuned twin turbo 335i variant pushing out 300hp and 300 ft. lbs. of torque. BMW continues to show that it sets the bar for true driving performance! -- View the E9X Wiki |
Torque graphs of the new Valvetronic Inline-6 engines
Courtesy of BMW AG
"Effective leadership is not about making speeches or being liked; leadership is defined by results not attributes." |
325i left - 330i right
Does BMW try to make it's torque output equal its engine displacement? Or is that just an odd coincidence?
Yup . But this only applies to petrol engines. BMW's diesels kick out anywhere from 170-190 Nm per litre.
Nice to see that dip eliminated!
2011 1M 2008 MCS 2002 325iT |
I love the Metric System! . |
Well.. It can't be an odd coincidence... I thought both engines were 3.0 litres? |
Normally aspirated VS Turbo-charged
Wouldn't that make it easy to mod a lower output car up to the higher output ones? People always say there's no substitute for displacement... ~Jon
2013 135is | Le Mans / Black w/ Blue stitching | Manual | Premium | HK Sound 1991 318is | BrilliantRot / Natur ette' | Manual | Fogs | Sunroof 2009 135i Cp | Alpine White / Black Plastic Cow | ZSP | ZPS SOLD 2007 Z4 R 3.0i | Silber Grau / Dream Red | ZSP | 711 | 522 | 494 SOLD 2007 335i Cp | A61 / LCSW | ZPP | ZSP | 322 | 4AS | 609 | 655 SOLD 2005 DINAN 330Ci | Silber Grau / Alacantara | ZHP | ED 12.10.04 SOLD |
That is quite impressive. 80% of peak torque available at 1100 rpm? Wow.
It is very common to use different cams for different applications
It is very common to use different cams for different applications. These affect the breathing of the engine and determine the torque characteristics. Usually, a light car would get more top end power at the expense of low end torque, and a heavier vehicle (SUV/RV/Truck) would get more torque at low speed at the expense of top end power.
BMW had an eta line of engines in the '80s that were optimized for torque and fuel efficiency. The 528e for example, had its power peak at about 4000 RPM and had no high RPM punch at all. With double vanos (variable valve timing) and variable inlet track length or resonance there is much less need to make this compromise, and torque can be optimized through a much wider engine speed range. The valvetronic engines have so much torque at low speed that they would work well for SUVs and good top end power too. It would be possible to limit power and torque by means of the engine controller software, but that would be silly. Even sillier than limiting the performance of a particular model by using very long gearing (low revving). I seriously doubt that the US will get two derivatives of the 3 liter engine, with one called a "325" in that car. The graphs above strongly suggest displacement of about 2.5 and 3 liters. That does not mean there won't be two 3 liter engines with slightly different characteristics; like with the ZHP engine we have now. Before variable valve timing it was common for hot rodders to replace the stock cams in their engines for ones that improved top end breathing. Today you have the best of both worlds, but it can still be done. The ZHP is BMW's version of such an engine. Quote:
Maybe somebody can explain to me the advantages of a 325i motor that has been so drastically detuned from the 330i. It still runs on premium, according to the guide, so it won't save money at the pump. |
2001 325i Touring Alpinweiss/Anthracite cloth, Alpina Softline 1988 M6 Royalblau/Silbergrau Nappa |
Australian broshure
http://carpoint.ninemsn.com.au/Tig/U...ias=carpointau I believe two three liter engines is a typo, but if this is correct, the only reason to do it is economy of scale: You cover two marketing price points with only one investment in hardware. Same block, crank , head, etc. That suggests the differences are in cams, because if it is only in software, hacks will be selling cheap upgrades in a hurry. Last edited by dynosor; 01-21-2005 at 11:04 PM. |
Aha!
From BMW USA
Based on this info from BMW on the 5 series, who knows...
http://www.bmwusa.com/bmwexperience/...tm?article=152 http://66.102.7.104/search?q=cache:_...+215+hp+&hl=en "In order to offer improved performance while at the same time improving fuel efficiency and meeting ever more challenging emissions requirements, two 3.0-liter engines will be offered. In the U.S., the 525i and 525xi will offer a 3.0-liter engine which produces 215 hp (SAE net) and 185 lb-ft of torque at 2,750 rpm. Responsiveness in everyday driving situations is outstanding. Nearly 85 percent of peak torque is available from 1000 rpm all the way to 7000. The 530i and 530xi models will feature a 3.0-liter engine which produces 255 hp (SAE net) and 220 lb-ft of torque. Peak torque is available between 2750 and 4000 rpm. Here fully 90 percent of peak torque is available between 1500 and 6700 rpm." |
Clarification
Ok, let me make my position clear. I don't know if BMW will offer two versions of the 3 liter engine, but I am trying to find evidence one way or the other. I think that detuning the 3 liter engine could make sense if it allowed you to build more of the same engine, and not a 2.5 liter engine. As the rest of the world will be getting a range of engines, including a 2.5, offering two 3 liter engines is not being done for economy of scale. Perhaps I should delete my previous posts or edit them as my opinion develops and new facts come into play. On the other hand, I think I have already edited some and thereby seem to be contradicting myself. I was offering a potential reason for doing something, not stating that as fact. It seems the facts point away from economy of scale, in this instance. |
Detuning might make sense if the detuned motor would run on regular. Which BMW owners would rejoice over a savings of $.25 per gallon? Many of the same ones who drive 325s and 525s with slushboxes. Yet the ordering guide says premium for both motors. Maybe THAT is the typo.
or they could just be putting it in there for bragging rights... look even our base model has a 3.0 liter engine...
It is not surprising to me at all that the US would get a 3 liter in both cars. The reason is that competition from other brands is so tough here . |
#25
I still don't get it..
I see that Europe is getting a 2.5 litre engine.. But, they are saying that the U.S. 325i will have a 3.0 litre engine.. And, yet.. coincidentally... The power specs for the 2.5 litre and the "de-tuned" 3.0 in the U.S. model are identical? This just doesn't seem right.. I can't believe they will be building these cars in the next few weeks.. and, no one seems to know for sure.. |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| * M6 * - Press Release from BMW | Emission | E63 / E64 M6 (2006 - 2010) | 6 | 03-06-2007 07:20 AM |
| BMW's New Six-Cylinder Engines - In Depth | sk330i | General BMW | 7 | 07-19-2006 04:52 PM |
| MazdaSpeed 6 Official info from Dealer | Optimus Prime | General Automotive Forum | 47 | 10-18-2004 04:07 PM |
| My ZHP is slow! | Nefilim | 3 Series / 4 Series | 103 | 06-25-2004 12:04 PM |
| Valvetronic engines | DaveN323i | General BMW | 2 | 03-28-2002 09:24 AM |
