Instrument Cluster - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series
5 Series
Ask questions and discuss the 5 Series here. If you would like to see all new posts in all the forums, click here.
Old 01-28-2005, 06:47 AM
iconnx iconnx is offline
Mein Auto: 540i Sport Individual
Instrument Cluster
Does anyone have any instructions on pulling the instrument cluster out AND also pulling it apart? I am replacing the dial mat with a White one and need to know if there is anythign to look out for whilst doing the screen print replacement...
Cheers & TIA!
Old 01-28-2005, 07:21 AM
Greco's Avatar
Greco Greco is offline
Trying to tame the 'BEAST
Send a message via MSN to Greco
Mein Auto: '98 540i/6
1) Pull of the small trim pieces on either side of the steering column.
2) 2 screws will be exposed.
3) Unscrew them and the cluster should wiggle out.
4) unclip the 3 connectors in back of the cluster
5) cluster should come out.
6) About ~10 or so screws seal the cluster.
7) It should pop open fairly easy after you remove the screws.
- Bill
>> E39 540i/6 Biarritz Blue <<
CDV, Rogue Engineering Octane Short Shifter w/ WSR, Rogue Engineering Performance Transmission Mounts,
Royal Purple Synchromax Transmission Fluid, GruppeM Ram Filter Charger
Old 01-28-2005, 02:15 PM
Thanks Bill! How do I get the needles off sir? Is it just a matter of levering them off or like MB's do I need to worry about the back end motors coming apart (Benzes have some sort of wave loaded compression spring within their setups that come flying apart if you are not careful...)? Thanks
Ram
Old 01-28-2005, 08:57 PM
Greco's Avatar
These are VDO's. If you have a flat head screwdriver with a v in the middle of it I would use that otherwise gently tug straight up. You do not want to break the pins. You might also want to remove the stop pin first to get an idea of where the needle lies in its true 0 state.
- Bill
Similar Threads
Instrument cluster and ambient lighting?. Quicksilver X5 E53 (1999 - 2006) 8 01-16-2005 10:42 AM
Switching instrument cluster in 4.4 '04..? Emm X5 E53 (1999 - 2006) 2 03-10-2004 07:44 AM
2000 323ci instrument cluster upgrade? TAREK323ci 3 Series & 4 Series 1 07-14-2003 04:52 AM
FS E39 540i Instrument Cluster NEW Alex540 Classifieds 2 07-07-2003 08:18 PM
Is the E46 instrument cluster 'that' good? hts Off-Topic 41 04-16-2002 02:52 AM
