Fuel and heat gauge broken?
Hi I have just bought a 328 e46, 99 modell. (will post images later on
)But when i fill the gastank up it only show 3/4 full, and i cant pump in more fuel.I have pumped in about 55liters when the warning lights starts to show(spare tank). And my heat gage stands on the blue bit, well, it stands just abit over the blue mark.Shouldnt this stand in the middel of the red and blue? Does anyone know what is wrong? Cheers
The heat gauge usually point to middle when the engine starts, HOWEVER, when under cold condition, such as these days recently, ( I assume both Canada and Norway have about the same temp around this time of the year, around -5.0 to -15.0 C ) it takes couple mintues for the needle to "move" to the centre. |
But if the tank holds 63 liters it should show 4/4 (full tank) on the indicator, cause i filled about 52-55 liters when the spare tank ligth started to show. My indicator only goes up to 3/4 and not 4/4. The heats gauge doesnt move more than just above the blue indicator, and it stays like that for the whole ride, nomather if i drive 10 minutes or 8 hours (like i did this weekend). Can it be that it has set itself in "winter mode"? But if it has done that it shouldnt be the other way around, i mean it should stay cooler at summer time, and not winter time. I hope my gauges not are brooken. Isnt there a way to test this?, like getting all the needles to move to the max and back? I think i have read that somewere. |
I can't explain the fuel gauge, but it looks like you need a new thermostat for the cooling system.
Both gauges (or rather, the stuff they measure) are definitely broken.
2001 325i Touring Alpinweiss/Anthracite cloth, Alpina Softline 1988 M6 Royalblau/Silbergrau Nappa |
If you search on "test mode" you should be able to find some documentation on how to make your guages "test" themselves... hopefully that will give you some further insight! Good luck!
Thans everyone, i will look into it asap
1. Car off 2. Press and hold the mileage reset button 3. Switch to KL R or ignition switch #2 4a. Do nothing and the display will automatically go into sub tests of main menu 0.1. The top part f the display will show "TEST 0.1" Sub-Test: 12345 1.0 is the VIN 4812 1.1 is the Body # 834762 6_1.2 is the part # for the cluster 010203 1.3 is the coding/diagnosis/bus index 3495 1.4 is the manufacturing date (calander week/year) 04_600 1.5 is the hardware/software # of cluster (HW:04, SW:6.00) 415_06 3_1.6 injection status, number of cylinders, engine factor. 4b. Press and release the reset button immediately (<1 second) to advance to the next main test menu. Scrolling through the numbered test functions is achieved by pressing the instrument cluster button. The button is either momentarily pressed (tapped) < 1 second or pressed and held for > 1 second. This signals the BC to display the sub-tests of the displayed main test menu or continue on to the next main test menu. Go directly to Test 19 to unlock the test features. TEST 19 Lock/Unlock Sub-tests: L-On L-OFF Display changes from "L-ON" to "L-OFF" every second. To unlock test functions press the cluster button immediately when it changes to "L-OFF". Tests are automatically locked when exiting test functions. TEST 2 - Cluster System Test - Acticates the gauge drivers, indicators and LEDs to confirm function. TEST 03 - SI Data Sub-tests: 1500 3.0 = liters 0 3.1 = Periodic inspection days (not applicable in US) TEST 04 - Momentary Consumption Sub-tests: 0267 4.0 = 26.7 liters/1000km 0073 4.1 = 7.3 liters per hour TEST 5 - Distance Gone Consumption Sub-Tests: 0195 5.0 = 19.5 liters/100km 226 5.1 = momentary distance to go (226km) TEST 6 - Fuel Level sensor inputs in liters Sub-Tests: 237415 6.0 = Fuel level averaged *LH sensor input = 23.7 liters *RH sensor input = 41.5 liters 0652 6.1 - total tank level averaged = 65.2 liters 0667 1_6.2 = indicated value and tank phase * 1 = both sensors are ok * 2 = one sensor fault * 3 = implausible input TEST 7 - Temperature and Speed Sub-tests; 032 7.0 = coolent temp input 32C 245 7.1 = outside temp input 24.5C 5283 7.2 = engine speed 5,283RPM 058 7.3 = vehicle speed 58km/h TEST 8 - Input value in HEX form Sub-Test; XXX 8.0 thru 8.3 = Hex code, instrument cluster inputs. TEST 9 - Battery Voltage Sub-Test; 125 9.0 = 12.5v TEST 10 - Country Coding Sub-Test; 02 10.0 US 02 TEST 11 - Cluster Code Sub-test: 000003 11.0 = cluster code TEST 12 - Not used TEST 13 - Gong Test Sub-test; GONG 13.0 = activate gone by pressing button (gond response is delayed) TEST 14 Fault memory (not for diagnosis) TEST 15 thru 18 - Not used TEST 19 - Lock unlock function TEST 20 - Avgerage fuel consumption - correction factor. The factor follows previous systems, with adjustment range of 750 to 1250. The adjustment method is new for the base cluster. If adjsutment is necessary, enter into test 20 using the cluster button. The correction factor number is changed by using the sub-test for the "ones, tens and hundreds of the factor number. The digits will automatically scroll through 0-9 within each group (ones, tens, hundreds) Sub-tests; XXX9 20.0 = press the button when the correct "ones" position is attained. XX5X 20.1 = Press the button when the correct "tens" position is attained. 12XX 20.2 = Press the button when the correct "hundreds" position is attained. TEST 21 - Software reset Sub-test; Reset 21.0 = reset software. NOTE: Using the test function of 7.2 will give you a digital tachometer! Becareful when using this function and driving on the road. The display is low and will divert attention from the road!
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| BMW's New Six-Cylinder Engines - In Depth | sk330i | General BMW | 7 | 07-19-2006 04:52 PM |
| Should I choose oil or gas heat? | Plaz | Off-Topic | 38 | 08-12-2004 07:24 PM |
| E65 V12 debuts | nate | General BMW | 21 | 07-14-2004 09:04 PM |
| What Causes Carbon Buildup? | JFS | General BMW | 29 | 02-10-2004 12:28 PM |
