Old 02-05-2005, 07:17 PM
x3man's Avatar
x3man x3man is offline
Mein Auto: M3/X3
Wiper system
The X3 wiper system drinks like a fish in the ocean. Is there any reason why the rear wiper has to spray THREE times instead of once? Is there a way to independently control the headlight washers and/or disable them? It's very wasteful.
2010 328xi Space Gray/Black, Premium, Navigation, V1 and more.
2005 X3 3.0i Metallic Silver/Black, Premium+Cold packages, Xenon, Navigation, Premium Sound, Steptronic, Servotronic, PDC, Heated Seats/Wheel, Bluetooth, V1.
Old 02-07-2005, 04:09 PM
FireFly FireFly is offline
Mein Auto: 330xi
You can unplug the headlight washers. Go under the hood and look near the filler tank. There is an electrical connection- undo it and wrap the ends in tape to protect them. Headlamp washers will no longer work until re-connected. I did this to the X3 and my 330xi and only connect them when I go skiing.
/Joe
330xi (sold)
1965 C2 Roadster
2005 X3 3.0
1997 TJ Sahara
2008 JK Unlimited Sahara
Old 02-07-2005, 04:59 PM
LeucX3 LeucX3 is offline
Send a message via AIM to LeucX3
Mein Auto: 06 VW Jetta GLI
Maybe it's so that for the first sweep it'll get some spray, then after the second sweep, it'll get some fluid in the other direction and then the same for the third?
I haven't really paid attention to it so i cant' tell you in enough time goes by for the wiper to make a sweep before the next spray shoots.
Old 02-09-2005, 09:43 AM
dikkius dikkius is offline
Mein Auto: X3
You're driving a $40,000 truck and you're complaining about wiper fluid which costs all of $1.59 a gallon?
Old 02-09-2005, 10:20 AM
sppuddsy sppuddsy is offline
Mein Auto: bmw
Originally Posted by dikkius
You're driving a $40,000 truck and your complaining about wiper fluid which costs all of $1.59 a gallon?
You know it's not the money.....it's the notion of wasting all that fluid.....and it really only cost $.99 a gallon, on sale.......
Old 02-13-2005, 12:27 PM
D.D. D.D. is offline
Mein Auto: '06 330xi, '05 X3 3.0
I too would like to disconnect this washer system, as I do not want the fluid sprayed all over the vehicle. I checked under the hood as suggested, but found there are two electrical connector plugs attached to the washer tank. Which one should be disconnected??? Thank you for the help.....I really want to stop the fluid all over the truck!
Old 02-15-2005, 05:22 AM
motordavid's Avatar
motordavid motordavid is offline
RetiredBum
Mein Auto: '01 X5 3.0 '02VetteVert
You can skip having the rear window wiper on=no spray there...
J/K'ng...but, be careful running that rear wiper often or for long
periods: that rear blade picks up large amounts of grit from rear
window. Will quickly produce that "mini-van look" of scratches
and a scrape wedge on rear window.
BR,md
Ol'Uncle Motor
'01 X5 3.0 Sport, 5 Spd Manual, etc.
'02 VetteVert 6 Spd, Z51 susp.
'10 Hyundai Tucson for the CEO, & 3 Assorted M'Cycles.
BMW CCA mem. Tarheel Chapter
My Flickr...Scenes,Cars & Road Trip Pics:
http://www.flickr.com/photos/45275375@N00/
Old 02-15-2005, 03:45 PM
OK.......................So which plug should I undo?
Old 02-15-2005, 04:38 PM
Mein Auto: 330xi
I don't have a picture handy but will take on over the weekend. The plug should be vertical if that helps. And when you unplug it, you will have 2 dangling ends to wrap up.
note- you can't just pull them apart! You must look at it and then push in the plastic tab and then pull apart.
/Joe
330xi (sold)
1965 C2 Roadster
2005 X3 3.0
1997 TJ Sahara
Old 02-16-2005, 07:00 AM
x3man's Avatar
Mein Auto: M3/X3
Is there some way to change the setting so that the rear wiper only sprays once or twice instead of three times? Can it be programmed? Also, is there a way to change how often the front headlight washers come on? I'd rather it come on every 6 times instead of 4.
Old 02-16-2005, 03:19 PM
Thanks FireFly!
Old 02-16-2005, 06:53 PM
Mein Auto: 330xi
Thanks FireFly!
Did you find it or do I need to take a picture?
330xi (sold)
1965 C2 Roadster
2005 X3 3.0
1997 TJ Sahara
Old 02-17-2005, 02:17 PM
Wife has the car............I'll check tomorrow when she returns home and let you know if I need the pic. I appreciate the time.......
Old 02-18-2005, 11:53 AM
Firefly.........Just checked the fluid tank. There are TWO verticle plugs in the front. Do I disconnect both of these?, or just one, ( left or right)? Thanks for the time...Dale
Old 02-18-2005, 03:25 PM
Mein Auto: 330xi
The white thing on the left is where you want to pull the connection out. The white thing on the right is what gets disconnected and will be left hanging. I put a balloon on each connection to keep the crud out but would suggest you wrap with electrical tape.
/Joe
330xi (sold)
1965 C2 Roadster
2005 X3 3.0
1997 TJ Sahara
Old 02-18-2005, 04:03 PM
WOW!!!! Thanks Joe! I REALLY appreciate the pic and all your help! I'll be out there tomorrow disconnecting and sealing the ends! Dale
Old 02-18-2005, 04:26 PM
Mein Auto: 330xi
You actually did me a favor. I used a balloon on the X3 and realized it is starting to show signs of wear. I used eletrical tape on the 330xi and it has held up and will do the same on the X3 this weekend.
330xi (sold)
1965 C2 Roadster
2005 X3 3.0
1997 TJ Sahara
Old 02-19-2005, 06:38 AM
Joe...........Just did the disconnect.....I am now headlight washer free! I had these on my 930 Turbo and disconnected them as soon as I drove the car home. I really do not like to wash the car with washer fluid.....especially when I am unable to remove it from the hood because of freezing weather! Thanks for advice and info! Dale
Similar Threads
BMW ConnectedDrive: ChrisTO General BMW Questions 12 11-08-2005 06:41 AM
Logic 7 sound system, is it any good? Flavio 7 Series & 8 Series 4 09-30-2003 03:49 PM
New dilemma: NAV system or SAT radio fstubbe Ask-A-BMW-Dealer 5 09-30-2002 06:28 AM
Jag X-type gets REAMED by edmunds. jastevenson General BMW Questions 12 12-31-2001 09:21 AM
