E46 (1999 - 2006)
Old 02-06-2005, 07:40 AM
sk330i sk330i is offline
Caveman
Mein Auto: X1
Ran over a trench, now car vibrates while driving...
My wife and I were driving to the gym yesterday morning. Just before we enter the on-ramp to the highway, we ran over a utility trench that was not fully patched by ConEd after some electrical work. It was a scary moment because the impact was so hard and so loud. I pulled over to the side of the road immediately and checked on all the wheels & tires, they were just fine. However, once I got on to the Belt Pkwy, I started to feel the vibrations on the steering wheel. It's not vibrating to the point where you can see it, but you can definitely hear the noise which was never there before, and you can feel it everywhere. In the afternoon, we went back to that location and took some pictures. The trench slopes down sort of evenly but then there's this 3-4 inches of vertical jump back to the road.
I am wondering what I should do now in order to correct the problem. Will the warranty cover this type of "damage"? Should I go after ConEd for the repair cost? Please advise.
Old 02-06-2005, 07:44 AM
drmwvr's Avatar
drmwvr drmwvr is offline
Stick Drive
Mein Auto: 330i, 911E, UZJ100
Originally Posted by sk330i
My wife and I were driving to the gym yesterday morning, we ran over a utility trench that was not fully patched by ConEd after some electrical work. It was a scary moment because the impact was so hard and so loud. I pulled over to the side of the road immediately and checked on all the wheels & tires, they were just fine. However, once I got on to the Belt Pkwy, I started to feel the vibrations on the steering wheel. It's not vibrating to the point where you can see it, but you can definitely hear the noise which was never there before, and you can feel it everywhere. In the afternoon, we went back to that location and took some pictures, the trench slopes down sort of evenly but then there's this 3-4 inches of vertical jump back to the road.
Sounds like you threw a tire balance weight; you need to have your tire re-balanced by either your dealer or a good tire shop. You should also have your alignment and wheels checked as well.
Unfortunatly, this will propably not be covered under warranty unless you have tire and wheel coverage (cost extra, you would know if you have it).
In regarde to ConEd, I would take a picture of the condition right away for your records and call them and explain your problem to see what they say.
Good luck!
'06 330i 6MT Sedan: MB / Terra / Burl / Sport / Cold
Old 02-06-2005, 08:19 AM
OneLuckyPuppy OneLuckyPuppy is offline
Mein Auto: 2004 325i
Good luck!
Depending on the impact you may have damaged one of the rims (you can't necessarily see it without removing it), which may increase the cost of repair significantly. Unfortunately having low profile tires does have a major disadvantage, the rims damage easily.
Good luck
Old 02-06-2005, 08:59 AM
Alex Baumann Alex Baumann is offline
Ex-Dictator
Mein Auto: Saab
Agreed with above replies, it sounds like bent rim(s).
"Effective leadership is not about making speeches or being liked; leadership is defined by results not attributes."
Old 02-06-2005, 10:09 AM
madmaxny madmaxny is offline
Mein Auto: 2011 E93 M3, E46 330i
Sorry to hear about your ordeal. If it makes you feel any better--I blew out two tires and bent both rims Friday night in a pot hole on the LIE. Here is the link to the post http://www.bimmerfest.com/forums/showthread.php?t=86696
If you were getting on Beltparkway,I am guessing you were in Queens or Brooklyn and I am not sure if that falls in NYC, but I was sent a link on my post by Terry Kennedy(thank you) to file a automobile property damage claim against NYC for reimbursement. Here is the link http://www.comptroller.nyc.gov/burea...mage_claim.pdf
hope things work out for you
Old 02-06-2005, 10:13 AM
Caveman
Mein Auto: X1
If the rims are bent, can they be repaired? Or will I have to get new ones? I wonder how much the rims are going now 225/45R-17...
Any recommendations for a tire shop in NYC?
Old 02-06-2005, 10:18 AM
Caveman
Mein Auto: X1
Madmaxny, thanks for the info. I read your post this morning. I guess the damage on my car is not as bad as yours...
As fas as claiming the city, I don't think it applies in my case since this isn't like a pot hole. It a trench dug up by ConEd, they didn't patch it back 100% afterward. So, if I really wanted to seek reimbursement, it would be ConEd instead of NYC.
Old 02-06-2005, 10:25 AM
rjh325 rjh325 is offline
Mein Auto: 2005 325i Sport/Manual
Probably a bent wheel(s)
Bending a wheel in the NE is a very common occurance. A wheel is made to bend or give in order to save your more expensive suspension. The first thing you have to do is have them tested at a local wheel shop. Bent or unbalanced wheels will be noticeable via the steering wheel while driving and a bent rear wheel will be felt in your ass usually. You can swap wheels around to pinpoint the culprit or spend money on a shop to do it for you. Once you determine that you have a bent wheel or wheels, you can possibly have it fixed at a place like this http://www.wheelcollision.com/ or find one on ebay for $100-$200. You could spend $100 to fix it and still not have it 100% true or you can buy a true used one for @$100 or so. good luck
2005 325i Orient Blue | Manual | Sport | M3 Wheel/knob | M3 Lip | Xenons | Sirius | Alpine-JL Audio System | OBC | HomeLink | Clears
Old 02-07-2005, 05:49 PM
Caveman
Mein Auto: X1
Just went to a mechanic this evening. The left front rim is bent on the inside, all the other 3 rims are ok. Now my question is if I should just swap it with the spare and forget about fixing it? Or should I just buy a new one? If I swap the spare, then my front tires won't match (10k on right, 0 on left). Any thoughts?
Old 02-08-2005, 05:24 AM
Spare rim (full size naturally) makes a perfect swap rim. I would probably install the old tire on the spare rim although it might not make a significant difference (depends on the wear pattern of the tire more than actual mileage). I would also get the damaged rim repaired ($100US approx.), it is well worth it.
Old 02-08-2005, 06:10 AM
Caveman
Mein Auto: X1
I checked www.bmwwheels.com and they have my wheel for $307 shipped. I don't know if those are OEM or not. Either way I thought it would be better just to get a new one instead of fixing it (for ~$200 - $250 @ wheelcollision.com).
Old 02-08-2005, 06:39 AM
I would shop to have the wheel repaired, it cost me $125 Canadian a year ago to have one repaired. Beats the price of a new OEM anytime and you could not tell the difference with the other ones. BTW I would not buy a reproduction as it is probably different in some means to the OEM. I would assume that a new OEM is probably way more expensive than $307 US.
Good luck!
Old 02-08-2005, 09:00 AM
Caveman
Mein Auto: X1
Good luck!
I just asked the guys @ bmwwheels.com, they told me the rim is OEM for $307 shipped...
Old 02-08-2005, 09:47 AM
Look at it on the bright side, it could have costed alot more. Take my example, 2 years ago 1 rim damaged, 1 shock tower out of commission and two tires gone on my Subie (pothhole the size of Manhattan). Last year on my BMW two rims dented (cheaper to replace than repair as aftermarket) after a I hit another pothole!!! Nothing like that ever happened to me b4, I guess a mixture of low profile tires and roads in a pitiful condition. Mind you I do about 30,000 miles a year of driving which increases the probability of finding potholes.
Old 02-09-2005, 10:50 AM
Caveman
Mein Auto: X1
I contacted ConEd today. They asked me to fix whatever's been damaged and send a claim through. They will then decide who's responsible for it. ConEd said they will pay for the damage if it's their fault, however if it's the contractor's fault, they will claim it through the contractor's insurance.
Before I put in a claim, I decided to give the contractor a chance to fix the problem so it would not affect their reputation with ConEd or their insurance. This guy whom I talked to on the phone from the contracting firm is not in power to make a decision. But he'd rather settle this between us than to get ConEd involved...just as I thought. So I will call the boss tomorrow and see what he has to say.
They should have put road plates or patch the trench so I wouldn't have to go through this... Well, let's hope they will pay for the rim. I have yet to get the alignment checked out...
Similar Threads
A purist review of SMG II nate General BMW Questions 30 03-25-2013 05:47 PM
Rotora Brake System Performance on BMW M3 Racer Car ralphwarren Motorsports, Racing & Track 6 03-13-2009 06:00 PM
BMW ConnectedDrive: ChrisTO General BMW Questions 12 11-08-2005 06:41 AM
Andy, how was your 1st autocross? Randy Forbes Motorsports, Racing & Track 9 09-14-2003 09:16 PM
