E46 (1999 - 2006)
Old 02-06-2005, 10:59 AM
AlexE46 AlexE46 is offline
Alex
Send a message via AIM to AlexE46
Mein Auto: 328 Ci 2000
Headers?
Where can you find some Good headers for a good price? And does it make a big difference that you can feel?
Old 02-07-2005, 02:57 PM
hecklerz's Avatar
hecklerz hecklerz is offline
Send a message via Skype™ to hecklerz
Mein Auto: '07 E90 328i
I won't even venture to guess to what kind of responses you're going to get. Especially with this kind of inuendo potential
p.s. Sorry, not an answer that you would find helpful, but the post made me snicker
2007 E90 328i | Metallic Black | Black leather | Heated seats | 6-Sp. Step. | ZPP | ZSP | NAV- iDrive | Adapt.-Xenon | Prem. audio- CD changer | Burl trim | BT to iPhone
**Looking for an E39 540, 530 or X5
Retired:
*2006 E90 325i- Ti-Silver Metallic, Black leather, Heated seats 6Sp Step. , ZPP, ZSP, NAV, Adapt.-Xenon, BT to iPhone
*2004 E46 325i- Silver Grey Metallic, Black Leather- heated, 6sp Step. , ZSP, ZPP, Xenon, Nav- V.26, BT to Blackberry
Old 02-07-2005, 04:41 PM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
Headers usually work best in conjunction with other mods, like CAI, a chip upgrade, large-diameter free-flow exhaust, etc. All these mods combined would probably net you around 30-35 rear-wheel HP at a cost of somewhere around $2500 (nobody said horsepower is cheap!) Or, you *could* install a nitrous system and get 2 to 3 times that increase for under $1000....as they say, "You pays your money, and you makes your choice"....
Regards,
Bob
Old 02-08-2005, 05:37 AM
Artslinger's Avatar
Artslinger Artslinger is offline
BMW + twisty road = fun
Mein Auto: Car
Wouldn't that be "Header" it is a inline six.
Old 02-08-2005, 04:40 PM
Fast Bob's Avatar
Keeping it surreal
Do me a favor, Art...read your question *again*....
Regards,
Bob
Old 02-09-2005, 05:19 AM
Artslinger's Avatar
Mein Auto: Car
Huh?
Inline 6... one Header.
V8... two Headers.
Old 02-09-2005, 05:41 PM
Fast Bob's Avatar
Keeping it surreal
Huh?
V8... two Headers.
Actually, I was referring to your statement "it is a inline 6"....my point being, if you`re going to criticize someone for using incorrect language, you should try to not be guilty of the same thing....furthermore, any group of exhuast pipes exiting the head are known collectively as *headers*, regardless of configuration.
Regards,
Bob
Old 02-09-2005, 06:39 PM
Artslinger's Avatar
Mein Auto: Car
Regards,
Bob
Why do they call it a Header on the online parts catalogs?
Old 02-09-2005, 07:48 PM
RSPDiver's Avatar
RSPDiver RSPDiver is offline
Ich bin ein Bimmerer
Mein Auto: 04 ZHP/4
Not sure for the M54 motor, but I've seen split banks of headers for other BMW inline-6 motors. That would be 2 separate units, indicating headers.
While we are wrestling about semantics.
Old 02-10-2005, 12:26 AM
Dirtboy's Avatar
Dirtboy Dirtboy is offline
Ring Junkie
Send a message via ICQ to Dirtboy Send a message via AIM to Dirtboy Send a message via Yahoo to Dirtboy
Mein Auto: E46 E83 E30- all M sport!
headers
Nürburgring info
Old 02-10-2005, 05:44 AM
Artslinger's Avatar
Mein Auto: Car
Hmmmm.... interesting what is the purpose of the split headers? You will need to connect the two headers into one pipe to exhaust, unless two pipes will fit under a 3 series.
I admit I was wrong on this one.
Old 02-10-2005, 12:40 PM
jsc's Avatar
jsc jsc is offline
Mein Auto: E85 M-Roadster, E82 135i
The standard E46 exhaust on a 6-cylinder uses split manifolds, so they are a direct substitute:
http://www.realoem.com/bmw/showparts...83&hg=11&fg=50
Old 02-10-2005, 03:21 PM
Artslinger's Avatar
Mein Auto: Car
The split design must be for clearance and installation issues. And for the headers it would make it easier to design equal length tubes.
Old 02-10-2005, 04:42 PM
Fast Bob's Avatar
Keeping it surreal
Add to this the fact that one long exhaust flange is a lot more likely to warp from the heat....
Regards,
Bob
Old 02-10-2005, 10:36 PM
Dirtboy's Avatar
Ring Junkie
The 325/330 uses dual pipes all the way back to the tail pipes.
The 323/328 uses dual pipes up to the first resonator, then goes to single pipe to the rear muffler, then has dual tail pipes.
Nürburgring info
Old 02-11-2005, 12:24 AM
Bob Clevenger's Avatar
Bob Clevenger Bob Clevenger is offline
ex-M couper
Send a message via Yahoo to Bob Clevenger
Mein Auto: '06 650i Coupe
Note that due to the fact that a six-cylinder engine fires (and exhausts) every 120 degrees of crankshaft rotation and the fact that the exhaust valves are open for more than 180 degrees of crankshaft rotation, if you feed every alternate-firing cylinder into its own collector and muffler/pipe system it will avoid having two cylinders exhausting into the same system at the same time. This reduces back-pressure and increases the savenging effect.
Good design.
Bob, Lord Helpus, KtR
Monaco Blue 650i coupe; 6MT, HUD, ACC, ZCW, ZPS. Redelivered 20 July 2006
Old 02-11-2005, 05:56 AM
tim330i's Avatar
tim330i tim330i is offline
Administrator
Mein Auto: Ti Silver 03 M3
There are a few companies that carry headers. I believe most of them are made by super sprint and should give you 15ish HPs. In addition to headers you will need to deal with a work around for your catalytic converters. The stock headers have the cats built in so you will need to get aftermarket cats and locate them where the center resonator is currently. You will also need to extend the O2 sensor wires and deal with all of that as well.
Tim
Old 02-11-2005, 06:02 AM
Artslinger's Avatar
Mein Auto: Car
Tim
So if the catalytic converter needs to be replaced you have to replace the whole stock header?
Old 02-11-2005, 09:48 AM
doeboy's Avatar
doeboy doeboy is offline
DHP pwns ZHP :p
Mein Auto: DHP Heehee... :p
Yup because they're both in one piece. There are two cats/exhaust manifolds on the car.
'03 330Ci DHP
'06 M3 SMG
"du hast mich gefragt, und ich hab nichts gesagt"
Similar Threads
E30M50 Headers l8nite 3 Series / 4 Series 0 11-22-2004 09:18 AM
E46 M3 Gen2 Supersprint Headers $1450 M3Dragon Classifieds 0 09-04-2004 01:18 PM
E46 330I Headers and racing Cats for ZHP stylinexpat 3 Series / 4 Series 1 06-06-2004 10:24 PM
Headers for my S50 euro spec M MCoupe321 E36/7 Z3 (1996-2002) and E85 Z4 (2003-2008) 7 06-06-2004 12:08 AM
FS: E46M3 Supersprint Headers and Cats w/O2 sensors foofoo11 Classifieds 2 03-10-2004 05:38 PM
