E36 (1991 - 1999)
Old 06-24-2009, 08:42 AM
fresaUKBM fresaUKBM is offline
Mein Auto: 318is Coupe
My airbag light came on on my compact 318ti and i had no idea why. One day whilst cleaning the interior i noticed a wire that was hanging from undeneath the passangers seat i checked it out closely and i asumed it was conection to the seatbelt sensor that had snaped when pushing the seat forward. Anyways I attached back together, the light didnt go off, But i can tell you that both airbags deployed as I had quite a bad accident and wrotte the car off about a month after fixing it. VERY VERY Lucky as the passanger wasnt wearing his seatbelt and the only thing that stopped him flying out through the windscreen was the airback.
Old 07-17-2009, 02:35 PM
ln69bt ln69bt is offline
Mein Auto: bmw 318 convertible
My air bag light on bmw 1995 convetible 318
Hello iv had my bmw 318 convetible 1995 about 3 months. Iv noticed the air bag light never comes on so i looked on the back of the clocks and someone has taken the bulb out. I have tryed a new bulb in and the light just stays on all the time. I want to know what could be the fault and what sensors will a 1995 one have iv had the drivers seat out before and there was no wires on it. Will it have seat belt pretentioners with sensors. The only thing i can see that someone has changed is the front as its had fog lights added could they be a sensor on the front bumper thats been left.
Any help please
Old 11-09-2009, 02:54 PM
PeteDawg PeteDawg is offline
Mein Auto: X3
Air Bag Light On
I have spoken with two or three technicians, they all indicate that if the light is on and the peak test indicates that the only error is with the passenger occupancy sensor, the default is that the airbags will deploy.
This is contrary to what other have posted here, but my thought is that perhaps others were not qualifying their statement with the above facts.
The conclusion I am gleaning here is this: Obviously the advice is, if the light is on, have a tech look at it otherwise your airbags may not deploy. If you have had a test run, and you know where the error is, and it is only with the occupancy sensor, the default setting is that if a crash occurrs, both the driver and passenger seat will deploy.
Is there anyone out there willing to confirm or deny this? Thanks in advance.
Old 11-09-2009, 06:46 PM
dc_wright's Avatar
dc_wright dc_wright is offline
bimmerfest Supporting Member
Send a message via ICQ to dc_wright
Mein Auto: '96 328iC, '04 325Ci
Air bag systems are designed to always try to deploy regardless of any fault indications. Whether the bags actually deploy or not is a function of the fault. For E36s if there is a constant fault the SRS light comes on as soon as you turn the ignition to the on positions and it stays on. If there was an intermittent fault, the fault code is stored and the SRS light comes on for 3 minutes every time you start the car.
'96 328iC "Marie"
Old 01-21-2010, 09:43 PM
bushcal bushcal is offline
Mein Auto: 318ti
air bag light
so i removed the air bag sensor light today from the back of my instrument panel cluster and the light is half way lit now? does anyone know if there is a light shining through my air bag light or y it is still illuminated. Thanks
Old 01-22-2010, 04:02 AM
Mr Gusta's Avatar
Mr Gusta Mr Gusta is offline
Fireballs inc.
Send a message via AIM to Mr Gusta
Mein Auto: 11:1 hx40 s50b28 sedan
Lol so you pulled the bulb and it is still lit? Wow that is one persistent light
Turbo lag is actually a headstart to make it fair
Old 01-22-2010, 06:20 PM
Slave 2 Slave 2 is offline
I have questions!!
Send a message via AIM to Slave 2 Send a message via Yahoo to Slave 2
Mein Auto: 92 325is & 78 VW Scirocco
Just to resurrect this thread one more time and hopefully get a few questions answered:
My SRS light (92' 325IS) starts blinking as soon as I turn the ignition on, and after 3 minutes goes solid and stays on. That tells me that there IS a fault in the system somewhere.
Most signs point to the Passenger Seat Sensor.
But here are a few questions that I'd like to ask:
1) With the Passenger seat senor kaput, will the DRIVERS ( Steering wheel) airbag still deploy?
2) Is there a sensor in the DRIVERS seat?
3) If you clear the fault with whatever reset tool, does that reinstate all the airbags to perform normally?
4) If there truly IS a fault, or a short, or a malfunction in the SRS system to cause the light, will the reset tool reset just the warning light,ignoring whatever fault there was in the first place, and run the risk of still not firing the airbags?
5) If the seat sensor is faulty, won't the warning light just come back on after a reset of the fault?
6) There are a few devices out there that claim to bypass the passenger sensor and stops the light from lighting up, but does it still allow the airbags to function normally?
7) Has anyone installed one of these devices? http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
8)If that device clears the light and fault from the system and allows the airbags to function normally, doe it work like there's someone in the seat permanently and fire the passenger bag regardless of true occupancy?
I ask all this because I really want my airbags to work in a crash!
Old 01-23-2010, 02:52 AM
johnf's Avatar
johnf johnf is offline
John Firestone
Mein Auto: 1996 318is
The airbags are a safety-critical system and are programmed, upon detecting a fault, to choose the course of action providing the greatest safety for the (possible) occupants. If the passenger seat mat fails, for example, the system assumes the seat is occupied and fires both front airbags in a crash. That protects the passenger if there is one, and only wastes money if there isn't. Similarly, if, say, the driver's U.S. seat belt buckle switch fails, the system assumes the driver isn't wearing his seat belt and fires the airbag in a milder crash. That protects the driver if he isn't wearing his seatbelt, and largely wastes money by needlessly firing the airbag if he is.
Other faults, for example, in the crash sensor circuit, disable the airbags as that is safer. Until you read out the cause of the fault(s), you won't know for sure if they may injure your person or just other things like your bank balance. (Many of the common faults fall do the latter.)
Old 01-23-2010, 08:24 AM
I have questions!!
Best info ever!
Thanks John. I will track down a fault code reader that is sensitive enough to differentiate between a simple seat belt fault, and a complete core meltdown fault.
Any suggestions in a reader good enough for that?
Old 01-23-2010, 09:24 AM
foremiilk foremiilk is offline
Mein Auto: 1999 BMW M3
since we are on this topic... I changed my oem seats in my 1999 m3 for corbeau a4 seats and my air light is on... I know its because the passenger seat has that sensor however I was wondering if there was a way to turn it off since its disconnected now
Owner of a 1999 BMW M3
Cosmo Black
Old 01-23-2010, 09:26 AM
I have questions!!
What I keep running across are these..
Are they worth a damn?
Old 01-23-2010, 10:01 AM
Progress's Avatar
Progress Progress is offline
Dream Green or die
Send a message via MSN to Progress
Mein Auto: 98 AA Turbo 328is
Man, don't mess around with airbags. Buy oem...
I drive a E36 328is, It's not a m3. It's not as fast as a m3.... Its faster
|Active autowerke Track Pipe | Custom Top Mount Turbo Manfiold | Umnitza Depo Angel Eyes |
| Turner Performance Cams | Stage 1 TurboCharger by Active Autowerke | Much More... |
Originally Posted by E36 Phantom View Post
As soon as I saw "Progress" as I was scrolling down I knew you were gonna piss on his parade....
Old 01-27-2010, 09:36 AM
ov010 ov010 is offline
Mein Auto: 318
I own a 2003 3 series. The airbag warning light (red) is always on.
I went to the BMW garage, they wanted £138 for diagnostics and a further £138 for each hour of labour.
I then went to my local non-BMW garage, they did a diagnostics test for £29. They found the fault was with the front passenger side seat occupied sensor - the seat-mat had short circuited. It shouldn't be too difficult to fix, however my local garage will not fix it as they are not official BMW electricians.
For my peace of mind am i right to assume if the car has a collision both airbags will go off automatically (even if there is no passenger)?
Judging by the responses in this forum this is quite a common fault?
Old 01-27-2010, 07:44 PM
dc_wright's Avatar
As already stated several times in this thread, the SRS system will almost always attempt to inflate the airbags. Whether they actually inflate or not depends on the condition of the system. The SRS system runs a self test when you turn on the ignition and if any faults are detected, a fault code is stored in the SRS Computer memory and the SRS light is illuminated. The SRS system runs the self test periodically when the car is running and if a fault is detected, the fault light is illuminated. If the fault is continually present the light stays on. If it was only a momentary fault, the code remains stored but the fault light only comes on for about 3 minutes when the engine is first started.
There are significant liability issues with making repairs on the SRS system and it is rare that an independent shop will attempt it. The reason is that unlike the other systems on the car, you can't test that the system is actually working. That would require actually deploying the airbags. All you can do is clear the fault codes and rely on the self test designed by BMW. The dealer will work on the system because they carry a higher level of insurance coverage, plus BMW provides some coverage to them.
The SRS system adds a significant level of additional survivability to a crash. It should be maintained in good working condition. Removing the light bulb so you don't have to look at it is not a good fix.
'96 328iC "Marie"
Old 01-28-2010, 01:32 PM
migalle migalle is offline
Mein Auto: 1997 328i
my airbag light came on on my 97 328i at 100,000 miles. I just put a piece of black electrical tape over it
Old 01-28-2010, 01:53 PM
TnT817's Avatar
TnT817 TnT817 is offline
Mein Auto: 1993 325i 4dr
That does not fix stuff
Old 01-28-2010, 02:54 PM
I have questions!!
Disabling the light does not fix the problem and the problem is:
WILL or WILL NOT the drivers side airbag deploy upon impact with a fault showing in the SRS system.
Amongst all of the faults possible, WOULD or WOULD NOT any of those faults that would make the SRS light come on, have ANY bearing on the functionality of the DRIVERS SIDE airbag.
Old 01-28-2010, 06:07 PM
dc_wright's Avatar
The answer is YES! The built in test checks to see if the electrical circuit that fires the gas generator is good in both the driver side and passenger side air bags. If the resistance of the circuit for either (including the ignitor in the gas generator) is out of tolerance or open a fault is flagged and the SRS light is set to illuminate. With this condition the faulty air bag circuit will not activate the airbag and it WILL NOT inflate in an accident. The same is true for either of the seat belt pre-tensioners which are just as important for safety as the airbags are.
The sole reason for the SRS light coming on is to alert you of a fault that could keep the SRS system from functioning. Some of the faults are related to the passenger side but they are still faults that could keep that air bag from deploying.
'96 328iC "Marie"
Old 04-19-2010, 08:53 AM
I have questions!!
All that is well and good, but the fact that I do not have a Passenger Airbag installed in my particular vehicle is meaning that my DRIVERS airbag is in question! ...and that's, like, the IMPORTANT one since I'M DRIVING!
So are any of these "Fixes" going to allow the airbag to deploy as it should on a car with no factory passenger airbag? They all seem toaddress the PASSENGER seat pad... Or are we still only fixing the light from bugging us ,and the problem still exsists and I'm going to be taking a chest-full of steering wheel?
Old 12-12-2012, 12:39 PM
rcauntay rcauntay is offline
Mein Auto: 328i
frustrations with bmw service over airbag indicator
I'm insanely frustrated with my local service center (which has been a disappointment from the start) over potential malfunctioning of my front passenger airbag. The indicator started functioning inconsistently when my daughter was about 58lbs., illuminated sometimes, other times not. I took my vehicle in to have the airbag indicator checked and was told everything was functioning properly. I assumed 60lbs. might be the limit to deactivate the Airbag Off sensor and she was verging. Two years later my daughter weighs 75lbs. (a lightweight 11 year-old) and the Airbag Off indicator doesn't illuminate when she's in the seat, but in my husband's 2011 335, the Airbag Off indicator is illuminated when she's in the seat, which seems consistent with safety guidelines that children under the age of 13 are at risk of airbag injuries. When I took my vehicle back for service, my concerns were dismissed and their response to my questions was that the car is "functioning as designed." They can't, however, explain the nature of that design (i.e. the weight limit for the airbag sensor - they claim there "is no published limit"). Perhaps my husband's vehicle is malfunctioning, they said. I'm not at all satisfied with or reassured by their lack of explanation. Three days after bringing my vehicle in, the service agent still wasn't even clear about the nature of my concern. One minutes he's telling me the car is functioning correctly, the next minute he's asking, "wait, the airbag indicator is on or the airbag is on?" It's ridiculous. They just want me to go away, and my warranty runs out in two months. I won't buy another BMW after this service expreience.
Old 12-12-2012, 01:13 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
Firstly, you're in the wrong section for your car. E36 BMWs were built between 1991-1999, and do not have airbag occupancy indicator lights like the later cars. Until you find out what the weight limit is for activating the airbag, you won't be able to get to the bottom of who's car is working correctly. Does the airbag off light deactivate (i.e. airbag activated) when you or your husband sit in the passenger seat?
Secondly, saying you won't buy another BMW because you're unhappy with a particular dealership's service department is fairly overly dramatic. Have you tried going to a different service department? If you buy a quart of milk from a grocery store and it turns out to be spoiled, yet the grocer won't offer a refund, you don't simply say "I'm never drinking milk ever again!" You just go to a different grocer...
1998 BMW 328is
1966 Pontiac GTO
Old 12-13-2012, 09:08 AM
ryder23's Avatar
ryder23 ryder23 is offline
BuckFifty
Mein Auto: 1998 328i Manual
Perhaps the sensor sensitivity for the weight of the child varies depending on how your daughter sits on the seat. Also, maybe there is a larger variance due to how the the sensor is mounted in your car versus your husbands. Therefore, it is a design issue. You should play with it to see what triggers it off consistently. Get your daughter to sit in various seat adjustment positions and hold different items (books, bags of rice, etc) to see how it responds. Perhaps it only takes a few more pounds to activate the airbag system and soon you will be there and won't need to worry about it when your daughter grows a bit more.
Old 12-13-2012, 11:01 AM
GarethE30 GarethE30 is offline
Mein Auto: 99 e36 M3, 91 318is
If you plan on owning your E36 for a wile it is probably worth getting an airbag reset tool. They cost about 130 bucks but is well worth it if you have multiple airbag issues over the years. So glad I got one.
This is the one I have and it works great!!
Peake Research R5-SRS Airbag (SRS) Scan/Reset Tool for BMWs (1994-mid 2000) NOTE: Can be Adapted for use on 2001-2003 models with optional Adaptor #PEL-AB03
Similar Threads
Radiator Warning Light - Questions lsedels 3 Series / 4 Series 13 12-19-2004 07:23 AM
Restraint system failure warning light drbmw Dealer Feedback / Vehicle Problems 3 05-11-2004 04:28 PM
Airbag light Bart E36/7 Z3 (1996-2002) and E85 Z4 (2003-2008) 1 12-25-2003 10:20 PM
problems with airbag light 328iSC 3 Series / 4 Series 3 05-22-2002 12:11 PM
