E46 (1999 - 2006)
Old 02-08-2005, 06:41 AM
markl53's Avatar
markl53 markl53 is offline
bimmerfest Supporting Member
Mein Auto: 2014 535i
Overhead switch panel popping out
Has anyone had this issue? It seems to be related to cold temps. On occasion the upper switch panel will pop out of the housing part way and I just need to click it back in. This morning it was hanging down from the wires. The dealer installed the UGDO before delivery and I'm thinking that the initial "disturbance" led to this happening. I'll inspect it closer, but it doesn't appear that any of the prongs are broken. But, I do notice that the prongs facing the rear of the car don't seem to really engage -- it seems like it's mostly the prongs on the 2 sides that keep it in place. If it keeps happening I'll mention it when I need to take it in for service.
BMW-CCA
Bimmerfest Supporting Member
2014 535i Individual | Azurite Black/Amaro Brown Merino | Premium | Cold | PDC | Rear Camera | Anthracite Hdr
Prior: 2011 535i AT | Black Sapphire/Cinnamon | Premium | Heated Sts | Nav | Sirius | Anthracite Hdr & Trim
Prior: 2008 335i 6MT Sedan | Black Sapphire/Terra Leather | Premium | Cold | CA | OEM Alarm
Prior: 2005 330i 6MT | Black Sapphire/Sand Leather | Premium | Cold | UGO | OEM Alarm
Old 02-08-2005, 08:12 AM
shizat63's Avatar
shizat63 shizat63 is offline
takes the long way home..
Mein Auto: 2016 M3
Is that the lights or the moonroof controls that are falling down?
______________________________
_______________
Old 02-08-2005, 10:18 AM
markl53's Avatar
The moonroof control panel, which on mine now has the UGDO "implanted". There are a series of plastic molded clips on each side, and the edge facing the rear of the car. Most of the time the right side has popped out and I just click it back in. That's when I've noticed that the rear-facing clips don't seem to really do anything, like I need to slide the whole panel rearward a bit. Today I saw where the wire connects to the UGDO. It's actually a wrapped harness of wires, and I'm wondering if it might be applying a bit of downward pressure that wouldn't be there without that connection. I'm going to pop the whole thing out again and check it a bit further.
BMW-CCA
Old 02-08-2005, 10:24 AM
shizat63's Avatar
Mein Auto: 2016 M3
Mine didn't give me a problem. Maybe your's isn't sitting right.
http://m3.madrussian.net/diy_valentine_v1.shtml
* Line up the rear edge of the univ. transmitter panel with the back endge of the opening (see image).
* Push the panel up into place - it will snap in when properly seated - DO NOT FORCE IT!
_______________
Old 02-08-2005, 10:28 AM
markl53's Avatar
Oh, interesting. I've been lining it up from the front first and that's probably why the rear tabs aren't engaging. The picture is good -- I'll try it again from the rear edge first. Actually, I never really disengaged the whole thing until it all fell out this morning, so maybe the rear tabs haven't really been engaged since they installed the UGDO. Thanks!
BMW-CCA
Similar Threads
LeatherZ E46 Gauge Panel Install w/photos Scott ZHP E46 (1999 - 2006) 40 07-06-2010 02:48 PM
1996 318is drive panel lights don't work Das Chimney E36 (1991 - 1999) 2 03-27-2008 04:04 PM
Oil Pressure Switch killeen_john E36/7 Z3 (1996-2002) 2 03-18-2004 09:54 AM
FYI: Mini KVM Switch JPinTO Off-Topic 3 12-04-2002 08:47 AM
Best-looking way to install an additional switch? Terry Kennedy Do-It-Yourself H.Q. 2 10-31-2002 07:35 AM
