Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > 5 Series DIY
5 Series DIY
Knowledge Is Power! ~ The place for do-it-yourself threads on a variety of topics. Start a thread describing a particular job (oil change, cooling system overhaul, brakes, shocks and springs, etc.) or search for one you need help with!
Old 02-10-2005, 07:12 PM
jdowpe jdowpe is offline
Mein Auto: 528
windshield washer
I am assuming my pump is dead. No pump noise. How do I get it?? Looks like might be on resevoir...but that doesn't look like it comes out either.
THANKS
Old 02-10-2005, 10:42 PM
dpjn dpjn is offline
Mein Auto: bmw
I just replaced the pump on my 97 528. the pump is located in the passenger front wheel well toward the passsenger compartment. it is behind the black plastic shield.
Old 02-13-2005, 04:54 AM
Toxic Toxic is offline
Mein Auto: 97 523i
as dpjn says, depending on whether your car is right or left hand drive, it's up behind the right front wheel. Mines a RHD, so it's the driver side.
Remove the wheel, remove the wheel arch liner (about 10 bolts) and its there in front of you. The pump just gets disconnected from the wire and pull it out of the reservoir. Make sure you get one from BMW that is matched to your car's chassis number. They changed the design sometime mid 1997 and they are not compatible.
Similar Threads
Windshield washer pump problem halsnook 3 Series / 4 Series 2 10-01-2004 09:24 PM
E46 eats Windshield Washer Fluid Fzara2000 3 Series / 4 Series 19 03-31-2004 02:00 PM
Aiming Windshield Washer Jets? acao E36/7 Z3 (1996-2002) and E85 Z4 (2003-2008) 8 07-08-2003 06:51 PM
Windshield Washer Spray PunchIt 3 Series / 4 Series 21 04-22-2003 07:29 PM
windshield washer fluid tank filter ChrisTO 3 Series / 4 Series 6 02-19-2003 09:54 AM
