E46 (1999 - 2006)
Old 02-13-2005, 12:05 PM
CRZY BMW CRZY BMW is offline
Mein Auto: BMW 3 Series
Question Fault Codes
I took my car in for a 60k Inspection II and my mechanic said everything looked good but that the car did store 2 fault codes.
123 Map Cooling
106 Vanos Position
He said that the check engine light would have come on, but I watch that thing religiously and know it hasn't come on. He said it could be a fluke but to watch and see if it goes off again.
What do these Fault Codes mean specifically? anyone know? Thank for the help...
Old 02-13-2005, 12:40 PM
RKT BMR's Avatar
RKT BMR RKT BMR is offline
Banned
Mein Auto: 5/01 production 330Cic
123 Map Cooling
106 Vanos Position
Probably intermittent, and nothing ot worry about. The Map Cooling code is related to the electrically controlled thermostat, and simply means that something was amiss during an automatic diag cycle in checking the current flow through the unit. If there's a real problem, it will happen again, and your SES light will come on.
The VANOS error code is probably due to a transient error with one of the cam shaft position sensors. The exhaust cam sensor has historically had some reliability problems, and can cause VANOS error codes. However, this code is not the one I've typically seen related to the exhaust cam sensor, so it's a little mysterious.
Bottom line: If your motor seems to be running fine, has the familiar power and torque characteristics you're used to, is running smoothly and not having idle problems, don't worry about it so long as you don't get an SES light. Both of these components will cause the SES to light if they cause two failures within the prescribed OBD drive cycle. It's not uncommon for transient conditions to cause a false positive from time to time in the on board engine diagnostics, which is the reason the OBD II drive cycle specs require consecutive failures within a prescribed drive cycle profile before alerting the driver to a problem.
It's probably worthwhile to clear the fault codes with a code reader tool (if the BMW tech didn't already), and then check again after a dozen or so drive cycles (assuming the MIL doesn't light up), to see if it occurred again intermittently. Code reader tools are pretty cheap -- you can pick one up new these days for about $70 new, and they go on sale frequently. I'd be surprised if you couldn't find one on eBay or another auction site used for $20-30, although I haven't looked.
Old 02-13-2005, 12:45 PM
Hey, thanks for the help... I've already cleared it and will wait to see if it goes off again.
Old 03-11-2009, 02:12 PM
richymonteagudo richymonteagudo is offline
Mein Auto: 2001 Z3 Roadster 3.0i
I have a bmw z3 2001 roaster 3.0i its has 4 codes p0174, p0171 and there tell me " system too lean bank 1 and bank 2" I change oil filter, air filter, before I was using 89 octane gas now I put 93 octane also i put full injector cleaner. I change also spark plug and a bootbroke that is part of the mass flow system. The other codes p0369 that tell me the camshaft position sensor "B" Bank 1 is wrong, and p0313 that is a misfire has ocurred with low fuel. I still have the codes after the little tune up and I don't know if the sensor could be the promblem. Main problem is the car has two camshaft position sensor and wish one is for bank 1 and wish one is for bank two. How can I clean all codes and wish one sensor is to be change The intake Camshaft position sensor or The exhaust camshaft positin sensor, if that the problem the codes go away or is that I need to reset something. Thank you
Similar Threads
PEAKE R5/fcx code/reset tool and understand the codes reevesna Do-It-Yourself H.Q. 2 12-29-2006 10:57 AM
Help with fault codes zoran E36/7 Z3 (1996-2002) 6 10-30-2004 08:28 PM
I need some help reading fault codes (E36 OBDI) JonW 3 Series & 4 Series 0 06-08-2004 07:24 AM
Question re: Storage of Fault Codes GM 3 Series & 4 Series 7 10-04-2003 05:52 PM
Anyone seen this? re: getting fault codes from your car ff 3 Series & 4 Series 4 07-28-2003 10:18 AM
