Old 06-28-2002, 10:09 AM
Polar Bear Polar Bear is offline
Send a message via ICQ to Polar Bear
Mein Auto: '99 M Coupe
Z3 clutch bushings = no squeek
I turned out a set of aluminum bushings to replace the stock plastic ones that were causing my clutch pedal to creak like an old door from a 16th century castle. Seriously, every time I put the clutch in I though Vincent Price was going to materialize in the passenger seat.
If you don't have any problems with a sloppy or squeeking clutch then you're lucky. If you do I highly recomend picking up a set of clutch bushings from UUC or getting some for Ron S. (if he's still selling them not sure). If anyone is interested in aluminum bushings send me an email.
I made mine out of aluminum (6061T alloy) which is a slight departure from other replacement bushings i have seen that are either nylon or delrin or similar non-metal construction. I made the outside diameter a little oversized so that they fit very snug into the clutch arm and isolate the friction point between the steel rod the clutch swings on and the aluminum bushings.
Old 03-25-2010, 04:12 PM
HajMan HajMan is offline
Mein Auto: Z4
Hi there,
I took my car to the dealer today to get the bushings replaced as I was experiencing the notorious squeak when depressing my clutch pedal, however after replacing that and the pedal box they are saying the noise still remains. There are now saying that it is the rod which connects the clutch to the body work has come loose. Could someone shed some light on this for me, as I am not sure what they are talking about. They mentioned something about the welding/bracket.
Old 03-25-2010, 05:44 PM
jragan's Avatar
jragan jragan is offline
Mein Auto: 07 Imola Red/Black MCoupe
Originally Posted by HajMan View Post
Hi there,
The OP has a Z3 and I've never heard of this in relation to a Z4. You don't list what kind of Z4 you have so I had to guess, but you might take a look at this: http://www.realoem.com/bmw/showparts...86&hg=35&fg=05
His: E86 ///M Coupe: Pics Track Pics Vids
Hers: 997-1 C4S: Pics
Old 03-25-2010, 05:47 PM
Mein Auto: Z4
Thanks for getting back to me.
I have a 2005 2.5i manual Z4. Have you ever heard of such a problem?
H
Old 03-25-2010, 09:38 PM
1good1 1good1 is offline
Mein Auto: 06 Z4M Coupe, 97 540 6 sp
This sounds like the same noise and probably the same bushings. I have a squeak also with my e39 540 6spd. But aren't the plastic ones supposed to be self lubricating and might the aluminum ones wear on the shaft?
Old 03-25-2010, 09:41 PM
Ron Stygar's Avatar
19,585 Miles
I use Delrin AF which has Teflon in it.
Old 03-26-2010, 04:41 AM
Mein Auto: Z4
But they have replaced the bushings and the squeak still persists, they think it might be the bracket that clutch rod feeds into, but I am not sure how this then mounts to the body work. Any ideas?
Old 04-04-2014, 09:51 AM
jaredfarouki jaredfarouki is offline
Mein Auto: 1996 z3
Anybody know how to change these?
Old 04-04-2014, 11:56 AM
vintage42's Avatar
vintage42 vintage42 is offline
BMW CCA 1405
Mein Auto: 1997 BMW Z3 1.9 5MT
Just look at the other thread that is running now...
http://www.bimmerfest.com/forums/sho...54&postcount=3
Similar Threads
Thoughts on UUC Clutch Stop Cruzer General BMW Questions 8 04-17-2006 04:06 PM
Clutch Delay Valve (CDV) Information Karl 3 Series & 4 Series 8 11-18-2002 12:46 PM
E36 UUC Clutch Bushings in_d_haus Do-It-Yourself H.Q. 0 09-27-2002 01:08 PM
