The X5 SAV Forum
Old 02-15-2005, 06:32 AM
IFlyX5's Avatar
IFlyX5 IFlyX5 is offline
Mein Auto: '15 535i MSport
Question Whistling noise from steering wheel
I've been noticing a low whistling noise coming from the steering wheel when I turn from left to right, or right to left. It is more audible at lower speed (like when coming out of parking lot or garage) and less audible at higher speeds. It sounds as if something is rubbing against the steering column. I extended the steering out hoping it was rubbing against the cover, but that wasn't it.
I searched the archive and found a few posts about low power steering fluid. The @$#$@@$ manual doesn't say anything about topping off the power steering fluid, and I can't find the reservoir under the hood. Is the reservoir next to the oil filter (with the 8-star cap) that says "ATF Fluid Only"? I checked and the fluid level is halfway between the 1st line and 2nd. Does it mean I need to add more fluid? Or should I take it to the dealer?
Does anybody have this problem happen to your X5? Mine is 4.6is so I have the servotronic power steering, if it helps.
TIA, guys.
2015 535i MSport Space Gray/Black Nappa | Driver Assistance | Premium | HK Sound | Heated Front Seats
Old 02-16-2005, 04:05 AM
TSAGG's Avatar
TSAGG TSAGG is offline
SJU Hawk ! Goin' Big!
Mein Auto: '06 BMW 330i sport
I've got the same issue but mine is more like a squeak. It only happens from the range of about 6" to the left to 6" to the right (from center). I'm planning on taking it in since I've also been notcing a slight "click" or "clunk" felt in the steering wheel when going over some sharp bumps (driveway skirts, etc.). I had the front sway bars done several months back but I wonder if something is loose again. I don't know if the two are related however (squeak and click)
Old 02-16-2005, 05:53 AM
breytonX5's Avatar
breytonX5 breytonX5 is offline
Hog Town
Mein Auto: 14 F10, 14 F15
IFly, try topping off the power steering fluid and see if the squeal goes away.
Old 02-16-2005, 01:16 PM
TSAGG's Avatar
OK, i can try that. where is the fluid resevoir located again?
Old 02-17-2005, 01:07 PM
IFlyX5's Avatar
It's the one next to the oil filter and has an 8-star cap. Right behind the radiator.
Old 02-17-2005, 06:49 PM
TSAGG's Avatar
Old 02-18-2005, 09:22 PM
crete crete is offline
On The Road To Find Out
Mein Auto: '05 X5 4.8is, '03 540iA
Last week I test drove a 2003 4.6is and heard a low squeaking sound while turning the steering wheel. I tracked it down to something in the steering column rubbing up against the back end of the steering wheel. Or at least where the turning part of the steering wheel meets the bulkhead where the wheel telescopes out from.
It was very annoying and when I went to buy my new 4.8is that was the first thing I listened for and didn't hear anything.
- 2005 X5 4.8is : LeMans Blue, Black/Blue Alcantara Leather Interior, Navi, Retractable cargo floor, Rear Side Impact Air Bags
- 2003 540iA : Sport, CWP, Nav, Titanium Silver, Premium Sound
- 1987 Yamaha Virago 700
Similar Threads
Heated Steering Wheel and PDC retrofit stlbimmer X5 E53 (1999 - 2006) 12 01-29-2005 06:37 AM
Help: Strange feedback vibration from steering wheel masmole X5 E53 (1999 - 2006) 13 01-23-2005 11:47 AM
Alcantara Steering Wheel Recover - Update JonM E36/7 Z3 (1996-2002) 10 05-21-2004 04:22 PM
Noise from differential or wheel bearings? (Non-BMW) 2001E46 Do-It-Yourself H.Q. 2 04-08-2003 05:55 PM
Tech: How to extra wires in steering wheel Raptox 3 Series & 4 Series 5 10-01-2002 08:51 AM
