All BMWs **Mike's Easy BMW Tools Package** - Bimmerfest - BMW Forums
Old 11-03-2015, 05:12 PM
stylinmike stylinmike is offline
Mein Auto: 323ci
SINGLE INSTALLATION FILE. ZERO CONFIG.
I have just finished spending the day creating an installation package that I think people will find very useful. The package takes all the guess work out of getting your computer ready for coding and diagnostics. It will be extremely useful for novices as well and basically is one single installation file that installs and sets up EVERYTHING.
What's installed:
- Inpa 5.0.6 (with English script files & Support for F-series)
- EDIABAS 7.3.0
- NCS Expert (with English menus and buttons, and NCS Dummy Profile pre-installed)
- NCS Dummy 4.0.1
- Tool32 4.0.3
- WinKFP 5.3.1
- Integrated SP-DATEN v53.3
- BMW Coding Tool v2.5.0 (for use as an alternative to NCS Dummy, or to update DATEN files as new ones become available)
- USB Drivers for cable
Why is this beneficial?
- One single installation will install ALL the programs needed for coding & diagnosis, will update the programs to show English menus, will set up NCSExpert with the correct NCSDummy profile, will automatically install USB Drivers, and comes integrated with SP-DATEN 53.3 (YES, Integrated!)
- All the latest versions of the programs in one neat install file
- No hunting or searching for SP-DATENs then struggling to import them
- SMALL file size. The entire package is only 170MB!! No need to download 15GB of DATEN files.
- System Environment PATH variables taken care of by the installer
- USB Driver included and automatically installed (and figured out if you need the 32 bit or 64 bit driver by itself)
The ONLY thing that users may need to do is reconfigure their COM port to be COM1 after the install, but a Readme file pops up after the install with simple instructions.
Hopefully this is not against the rules posting a link. If it is, feel free to contact me to have it removed.
DOWNLOAD
_a2_ _sl_
Old 05-02-2016, 08:30 PM
xtoor xtoor is offline
Mein Auto:
170mb? hmmm somehow im skeptical about this
Old 05-02-2016, 09:25 PM
Almaretto's Avatar
Almaretto Almaretto is offline
Moderator
Mein Auto: Coded 2016 F10/ F15 Sport
I know nothing of this source, but my BMW Standard Tools and INPA Fxx was 156mb.
Have a hard time believing this does not violate Bimmerfest policy though.
Old 05-03-2016, 05:24 AM
fratan fratan is offline
Mein Auto: 2006 750i
I've tested it and installs cleanly. You have to learn the program's though especially if your going to use WinkFP
2006 750 I
Old 05-03-2016, 05:26 AM
I've tested the software and it installed cleanly but you need to learn how to use it especially Wink FP. Good Luck
2006 750 I
Old 05-03-2016, 05:48 AM
liquidity liquidity is offline
Mein Auto: E92
Seems kinda odd that this is the one and only post from this guy.
Old 05-03-2016, 07:02 AM
Mein Auto:
I scanned it found no virus, but just in case installed it on a virtual machine, installed fine but for the size took a long time to install and bmw coder doesn't work for me it gives a missing .dll error on win 7 32bits
Old 05-03-2016, 01:17 PM
I had all the software before hand. I would like to learn wink FP but haven't had time yet. Mike did a great job writing the software for an easy install. I just passed it along. Also, I m not sure if I got it from this website or from anothet
2006 750 I
Old 05-30-2016, 08:03 AM
discordia666 discordia666 is offline
Mein Auto: 320d M Sport Coupe
I've been using NCS Expert to code my 2006 E90 for 2 years with no problems. Just bought a 2012 E92 and have spent about 4 days trying to get it to work with no success. Tried 2 versions of EDIABAS, 2 versions of NCS, 3 versions of SP-Daten (including 53.3). Reinstalled about a million times.
Downloaded this installer and had it working in minutes. In 64bit Windows 10.
Nice one Mike!!!
Old 05-31-2016, 06:23 PM
Yeah, I thought it installed smoothly as well. Those programs can be tough to install.
2006 750 I
Old 06-01-2016, 01:30 PM
hapklaar hapklaar is offline
Mein Auto: 2003 530D
Absolutely fantastic. Thanks a lot for this!
Old 06-03-2016, 10:59 AM
evgeniy evgeniy is offline
Mein Auto: e60 530d 2004
thanks mike amazing job
Old 06-10-2016, 11:47 AM
yetieater yetieater is offline
Mein Auto: 03 330i
When I select Choose ZUSB in WinKFP, I get an empty list. Can you help me resolve this?
Old 06-13-2016, 09:50 AM
I haven't used Winfp yet so I can't help. You can go to other websites that specialize in winkfp
2006 750 I
Old 06-14-2016, 10:07 AM
oceandiver86's Avatar
oceandiver86 oceandiver86 is offline
Mein Auto: z4
you need to import the files to WINKFP first. there are lots of tutorials around.
the fastest way is to use the coding tool...
Old 07-15-2016, 05:34 AM
08-730d 08-730d is offline
Mein Auto: 08 730d
Downloaded that thing, since my bmtechnic acted up and wanted new activation codes.
But I got FTDI CDM Driver error while installing, is that important?. I also have a problem with getting the usb port called com1 as described in the readmefile..
Old 07-15-2016, 05:56 AM
Sounds like you have a problem with your cable. You need to check to make sure your usb cable is set to com port 1. Depending on your operating system it could be set to com port 4.
2006 750 I
Old 07-15-2016, 09:19 AM
Mein Auto: 08 730d
Thanks, found out, it was at com3. When you launch the ncs expert, isnīt it supposed to be in the wmware virtual machine? Do you have to start the virtual machine by itself first?
Old 07-15-2016, 09:44 AM
2006 750 I
Old 07-15-2016, 09:48 AM
No NCS expert should just start but I've only used it a few times. Go to bmwcoding.com and they can walk you through it. I use INPA mostly to check codes and reset them. I also used INPA to adjust my vanos and stopped smoke coming out during idle.
2006 750 I
Old 07-15-2016, 09:52 AM
NCS doesn't use VMware that is DIS that uses that.
2006 750 I
Old 07-15-2016, 10:02 AM
Mein Auto: 08 730d
sweet, thanks..
Old 07-15-2016, 10:34 AM
What are you trying to do? NCS Expert is for coding modules. It doesn't do diagnostics. For that you need INPA or DIS or, better still, ISTA Rheingold. INPA is very clunky, though quite useful if you can get it recognise all the modules in your car. I can't even get it to talk to my DDE, so it's not much use to me. DIS is way better but a total ballache with all the VMware BS. On my laptop, it only loads 1 time in 4. Rheingold is a standalone program that runs in any version of Windows (including 64 bit Windows 10). It does everything that DIS does but loads every time with no problems, is quicker and easier to use.
Old 07-16-2016, 12:31 AM
Mein Auto: 08 730d
I`m trying to code a module.
Old 07-16-2016, 03:38 AM
gerberos gerberos is offline
Mein Auto: 525 e39 -02
i have problem, INPA and KFP gives error that API32.dll is missing
i have win 10 64-bit
