Half shaded CHECK ENGINE LIGHT 120i - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 1 Series & 2 Series > E82 / E87 / E88 / F20 1 Series (2008 - 2014)
Old 11-07-2015, 02:31 PM
Francis Phiri Francis Phiri is offline
Mein Auto: BMW 120i
Hi folks, I have a half shaded yellow Check engine light coming on my 2004 BMW 120i.
I have topped the engine oil, Closed the fuel cap tightly and checked the engine settings and its indicating OK. What could be the fault. There is a CC-ID29 code when I press the BC button. Please help!!
Old 12-23-2015, 02:39 PM
edwardmagichand edwardmagichand is offline
Mein Auto: '12 X5 35i, '08 135i Conv
I think CC-ID29 is just a generic code which tells you nothing.
In fact, my 2008 135i with N54 engine has the same thing. Half shaded orange engine light at the center of dash. Went to the dealer and they said it's one of the VANOS solenoid. I think somehow it's stuck and triggers the light. When I turned off the engine and then turned on again, it was gone. So I assume it doesn't happen all the time, but it happens when I'm very unlucky - sort of.
Also N54 is notorious for sticky VANOS solenoids and I'm not so sure about your engine.
Anyways, my point is that you need to read the code and diagnose the problem properly.
Old 10-26-2017, 04:21 PM
orraler orraler is offline
Mein Auto: 2009 328i xDrive
I am going with your answer. I am going to replace the Variable Timing Solenoid. it sounds exactly what happens to me
