Panel under Oil Pan Drain Plug - Bimmerfest - BMW Forums
E46 (1999 - 2006)
Old 02-17-2005, 11:31 AM
OrientBlau OrientBlau is offline
Mein Auto: '02 330i
I tried searching first, but to no avail.
I know that the coupes have a panel under the
oil pan, to be removed prior to draining the
old oil. However, the 4-dr doesn't.
Would the panel of the coupe fit the
opening of the 4-dr?
Also, what's it called exactly?
Thanks.
Old 02-17-2005, 11:33 AM
drmwvr's Avatar
drmwvr drmwvr is offline
Stick Drive
Mein Auto: 330i, 911E, UZJ100
Thanks.
My '03 325i did not have one. I'm not sure if the coupe will fit the sedan
'06 330i 6MT Sedan: MB / Terra / Burl / Sport / Cold
Old 02-17-2005, 12:58 PM
drmwvr's Avatar
Stick Drive
Here is a link that might help you out...
http://www.bimmerfest.com/forums/sho...il+drain+cover
Old 02-18-2005, 11:39 AM
Mein Auto: '02 330i
Thank you.
Old 02-18-2005, 01:03 PM
Flex Flex is offline
Mein Auto: 2003 - 330i - ZHP
Thanks.
OrientBlau,
Just curious. If you're planning to do an oil change, then perhaps you may want to invest on an oil extractor. It's a really cool device that suits oil changes for the E46 perfectly. Basically, it pumps the oil from the same pipe as the oil dipstick and sends it to a reservoir. Furthermore, you don't have to jack up your car when using the oil extractor.
If you have not heard of one, then click the links below as well as do a search on the net and on bimmerfest.
http://www.bimmerfest.com/forums/sho...hlight=mityvac
http://www.griotsgarage.com/catalog.jsp?&SKU=10122
Hope these help you.
Flex
Old 02-24-2005, 12:47 AM
Mein Auto: '02 330i
Flex,
Thanks for the information. I'll assume that you yourself
use an oil extractor for your beauty. Does it remove
as much oil from the oil pan as the conventional way?
OB
Similar Threads
Missing oil drain cover...? Wingboot 3 Series & 4 Series 12 09-03-2004 01:19 PM
m44 block coolant drain plug location? z3roadster19 E36/7 Z3 (1996-2002) 1 05-24-2004 03:44 PM
My Oil Pan Cover Plate Is Gone? Thanks El Cajon Bmw -cunningham!!! 325CI~02 3 Series & 4 Series 7 04-01-2002 06:03 AM
in d haus... i'm returning the favor... Sabrina Off-Topic 5 02-06-2002 07:03 AM
