E36 (1991 - 1999)
Old 02-13-2005, 12:20 PM
the12pick the12pick is offline
Mein Auto: 94 325i convt.
Question 94 325i convt Doors HELP
When I open my right side door the window will not drop the inch to clear the top, and the dome light will not go on. I worked on it one day, pulled the panel off and sprayed a little WD-40 on the lock parts and switch, at the same time I sprayed the drivers door latching area. Now neither doors will the window roll down when you open them and the dome light will not work when the door is open. What can I do to fix the problem or do I have to replace the locking latches? HELP!
Old 02-16-2005, 01:45 PM
Brashland's Avatar
Brashland Brashland is offline
Das Hellrot Reisender
Mein Auto: 1999 323i Hellrot 'vert
Just a shot in the dark, but maybe it's a bad fuse? Can you roll down the windows without problem?
My YOKOHAMAS were BALD after only 7,000 miles of daily driving!!!
Old 02-16-2005, 03:10 PM
LmtdSlip's Avatar
LmtdSlip LmtdSlip is offline
Do the interns get Glocks
Send a message via AIM to LmtdSlip
Mein Auto: 325iC
This sounds like it could be two different issues.
The light not going on/off could be a fuse.
The window not dropping an inch is likely a mechanical issue. My windows went from dropping about 3/4 of an inch to barely a few millimeters. I havent taken the time to take the doors apart to diagnose the problem.
Also, WD-40 is a solvent that cleans parts and disperses water. It does not lubricate. So, any part that should be lubricated and you sprayed with WD-40 need to be relubricated.
Id check the fuses and make sure all of the internal parts of the door are in line as they should be and lubricate them per the service manual.
Sorry I can be of more help.
Photobucket
Old 02-17-2005, 10:24 PM
I tried all the fuses, all good. Everything works fine on there own, windows, dome light, just not when you open the door. Does anyone know where to buy the cheepest part for our money pits?
Old 02-18-2005, 06:22 AM
JoeCinVa JoeCinVa is offline
Mein Auto: 95 325iC
It's probably the door switch. Look at your right side door latch that is on the b-pillar. If you look closely at the latch, you will see a tiny black switch. When the door closes, it presses this switch closed. When you open the door, the switch opens which tells the car to drop the window a bit and turn on the timed dome light.
Locate the pass side switch and press it a few times to see if it does anything. Verify that the driver's side switch works as intended. To replace the switch you have to replace the whole latch. Good luck.
Joe
03 E39- S62B50 w/90K
00 E46/4- M52TUB25 w/156K
99 E36/8- S52B32 w/69K
95 E36/C- M50TUB25 w/230K
Similar Threads
Overview of my available options regarding 2 doors and hood re-spray Fifty_Cent E46 (1999 - 2006) 4 02-12-2005 01:23 AM
Any 530i Engine Recalls? DANABANA 5 Series 3 01-22-2004 09:07 PM
Auto-Locking Doors and Post Crash Safety Features bimNaround General BMW Questions 11 10-31-2003 11:05 AM
A few questions about a used 94 325i e36 dz223 3 Series & 4 Series 1 07-14-2003 09:38 AM
VIN tags on the doors question Dracula 3 Series & 4 Series 1 06-06-2003 03:23 PM
