Old 06-29-2002, 11:51 AM
phrider's Avatar
phrider phrider is offline
Equine 1/4 miler ancestor
Mein Auto: 2001 M Roadster, 1998 M3
Question Amateur installation of Daytime Running Lights
I would like to install Daytime Running Lights into my 2001 M Roadster. But I am a very amateur mechanic, especially when it comes to car work. The posting by Ron Stygar at http://www.unofficialbmw.com/e36/ele...ng_lights.html got me started down this path. I've gotten the DRL relay (BMW #61 35 8 368 039) to replace the high beam relay. But now my low skill level starts showing....
1. How do you get the lower dash panel on the driver's side completely off? I can get the plastic panel immediately above the pedals out. But I have not figured out how to get the lower dash panel out of the way -- especially the attachments into the center console.
Suggestions? I assume that I should disconnect the battery before doing this.
2. I was able to get the panels partially out of the way -- but my hands are too large or not nimble enough to get the high beam relay out.
So what is the trick to getting the clips on the side of the relay to "let go" (especially when you are standing on your head under the dash)?
3. There were rumors that the wiring scheme may have changed in 2002 for Canadian DRLs.
Just to double check.... has anyone else done this on a 2001 M Roadster?
4. My dealer , of course, has been uncooperative on this, including stating that this change could jeopardize warranty of related systems.
Anyone get dealer cooperation on these issues? If so, who -- especially if they're in the LA area.
Old 06-30-2002, 12:55 PM
Ron Stygar's Avatar
19,585 Miles
Works on my '01 M coupe and Al Corey's M roadster.
Old 06-30-2002, 01:13 PM
phrider's Avatar
Ron,
Thanks for the help.
Any suggestions on easy ways to get the relay side clips to let go in the confined space?
Old 06-30-2002, 02:40 PM
Ron Stygar's Avatar
19,585 Miles
I pry it out using a Delrin trim tool I purchased between the bottom of the relay and the top of the relay socket. You can also use a small screwdriver.
Noting the orientation of the relay you remove will make it easier to install the replacement. Writing on both face the same way.
Old 07-01-2002, 08:25 AM
phrider's Avatar
I am off to look for a Delrin trim tool.
Even with the battery disconnected, I am not a fan of sticking a conductive screw driver around high amp relay connections (call it "capacitor paranoia" ). I'll use the screw driver for pushing out the side relay "hold down" clips....
One operational question: with the DRLs, is it just the high beams that come on at low light output? Or do the tail lights come on as well?
Similar Threads
The Big Book of Suspension Installation AndyM E36/7 Z3 (1996-2002) and E85 Z4 (2003-2008) 39 09-24-2012 01:09 PM
Daytime Running Lights SM540i 5 Series 3 05-14-2003 03:05 PM
Daytime Running Lights? DAE? Fingaz 3 Series / 4 Series 30 11-07-2002 03:08 PM
Daytime Running Lights JerryL 3 Series / 4 Series 14 05-15-2002 02:45 PM
daytime running lights on 2000 e46s? 10chi 3 Series / 4 Series 7 05-12-2002 05:22 PM
