1996 Z3 can you identify these trim pieces? - Bimmerfest - BMW Forums
Old 08-13-2013, 10:48 AM
Alfre Alfre is offline
Mein Auto: Z3, 635csi. R1100RT
[SIZE="2"][/SIZE
Found thee two trim pieces in the glove box, don't know where they go or what they are.
Both black, one is a plug of some sort about 1 3.8 " long, 1" dis. on the big end.
The other is a surround trim 2" od, 1" id.
I'll try my first attempt at attaching two pics.
Thanks,
Alan
ID:	391307   Click image for larger version
Old 08-13-2013, 11:37 AM
skinners1 skinners1 is offline
FASEONE
Mein Auto: 1997 Z3 1.9
Not sure about the second one, but the first one is the clip that retains the floor mat, there are 2 other parts that go with it though...
Old 08-13-2013, 11:47 AM
ObeyThePoodle ObeyThePoodle is offline
Mein Auto: 1999 BMW Z3 Coupe 2.8L
Isn't the second one a cigarette lighter plug?
Old 08-13-2013, 12:35 PM
crappyattitude1 crappyattitude1 is offline
YYZED3M Driver
Mein Auto: '99 ////M Roadster
Yes, ObeyThe Poodle...
Has nailed it!!!! Cigarette lighter dummy plug.
Crappy : )
(Just outside of Nashvlille)
Crappy : )
(Just outside of Nashville)
Old 08-13-2013, 12:51 PM
I had noticed the plug did fit the cig lighter receptacle but wasn't sure that's what it was.
The floor mat thingy I would have never guessed.
Many thanks,
Alan
Old 08-13-2013, 01:51 PM
vintage42's Avatar
BMW CCA 1405
Originally Posted by skinners1 View Post
... the first one is the clip that retains the floor mat, there are 2 other parts that go with it though...
I have floor mat clips that screw into the carpet backing.
How can those big rings be related to floor mats?
Old 08-13-2013, 03:36 PM
After taking another look at the floor mats, there is a small ring there but a good bit smaller than the item I was asking about.
So, I'm still looking..............
Old 08-13-2013, 06:19 PM
FASEONE
It is def. the floor mat retaining clip. It is a 3 piece set, the piece you are holding is the bottom ring that goes on the bottom of the mat, a smaller slotted ring clips in from the top of the mat and snaps into this retaining ring and sandwiches the mat, the floor screw then slips into the rings and secures the mat to the floor...
Old 08-13-2013, 06:39 PM
vintage42's Avatar
BMW CCA 1405
After digging up my stored floor mats, it does appear to be a mat ring, but with the inside broken out of it. The ring should not be an open ring, but has solid center with a slot where the part screwed to floor sticks through to retain it.
Old 08-14-2013, 04:57 AM
My bad..........when I said it was larger than the ring at the carpet anchor, I was looking at the top ring on the carpet. Didn't realize there was a larger one underneath.
Thanks for clearing it up for me and thanks to all who replied.
Alan
