E30 (1982 - 1993)
Old 02-21-2005, 03:03 PM
Jus07 Jus07 is offline
Mein Auto: 318i 1989
Unhappy Eratic misfiring M40/B18 engine - anyone else?
I've been to several mechanics with this problem and none seem to be able to help.
This problem is very erratic
A typical scenario is that car experiences misfiring / incredibly uneven firing for a period of 5 minutes (never when totally cold / usually anytime after 5 minutes of driving). I continue to drive and suddenly it then works perfectly for the rest of the journey sometimes the problem will vanish for a week or more only to return at a very odd time such as in the middle of a 2 hour motorway drive. When it happens if you stop and leave the engine at idle it splutters and revs to avoid stalling but eventually will stall.
-The misfiring can be quite severe causing the car to hop (at low speeds) if the clutch is not used.
-Higher revs helps to ease the problem.
- there are no faults recorded on the engine management system
-This can happen at idle or at very high revs, under load or not.
-Cold weather and long journeys the day before sometimes seem to be partial factors
My suspicions have ranged from:
-eratic air intake leak that his affected by air temperature?? I had the air intake -manifold gasket replaced and the problem seemed to go away for a while?
-eratic electornic sensor problems?
Has this happened to you or do you have any ideas what this could be?
Jus
Old 02-22-2005, 07:58 PM
smc smc is offline
Mein Auto: 325i and 540i
Ignitor
I had the same problem and took it to the dealership. The ignitor had to be replaced. It's a common problem according to the service rep.
Jus
Old 03-01-2005, 11:00 AM
Thanks for your posting. When you say you had the ignition replaced. Do you know what they replaced i.e. I have replaced teh Ht leads and distributor cap and rotar arm but this does not seem to help?
Old 04-27-2005, 02:01 AM
Damien1 Damien1 is offline
Mein Auto: E30 316i
Stalling/misfiring
Hi I was wondering if you have managed to sort this out at all. I'm having exactly the same issue and finding it difficult to get a diagnosis/resolution. Local BMW garage haven't cured. I'd be interested if you managed to get any more info
Similar Threads
New Info on e46 M3 Bearings/oil pump service bulletin MUST READ TGray5 1M & M2 5 12-03-2007 09:08 PM
BMW ///M press release - BMW WilliamsF1 engine details PhilH Motorsports, Racing & Track 6 05-04-2006 11:33 AM
Engine freaked out (EML, DSC, Brake) FenPhen 3 Series & 4 Series 2 06-30-2004 08:14 AM
BMW Update for S54 Engines BMWNA 1M & M2 2 08-13-2003 05:55 PM
Product review: Griot's Engine cleaner kit(m) The HACK The Detail Department 20 01-08-2002 07:56 PM
