The X5 SAV Forum
Old 02-22-2005, 01:19 AM
wuzin's Avatar
wuzin wuzin is offline
Account Under Review
Send a message via MSN to wuzin
Mein Auto: 09 M3 Coupe
What's the KL-R or KL-15??
Hello,
I'm trying to pair my phone with X5
from this instruction http://www.bimmernav.com/pdf/BT_Pairing_05.pdf
says Trun Key off and then to KL-R or KL-15
I was just wondering what'is that stands for?
Thank you!
Old 02-22-2005, 02:38 AM
doeboy's Avatar
doeboy doeboy is offline
DHP pwns ZHP :p
Mein Auto: DHP Heehee... :p
It means turn the key to "Accessory" or "Run" position.
'03 330Ci DHP
'06 M3 SMG
"du hast mich gefragt, und ich hab nichts gesagt"
Old 03-29-2014, 06:40 AM
DCC DCC is offline
BMW Fan
Mein Auto: '02 Z3 M Coupe
How do you get to run with a push button start vehicle?
2016 320i Sedan
2011 M3 Sedan
2002 Z3M Coupe
Old 03-29-2014, 09:33 AM
QSilver7's Avatar
QSilver7 QSilver7 is offline
"KL" in bimmerspeak refers to the ignition "terminal" positions. For many, the terms "run" & "accessory" still raises questions...because it doesn't plainly explain which ignition positions they are for those that don't refer to their owners manual for better clarification.
Below is some simple explanation:
  • KL 0 = OFF (ignition off position)
  • KL R = ignition position 1 ("run" - some electonics & modules are powered up)
  • KL 15 = ignition position 2 ("accessory" - all electronics & modules re powered)
  • KL 30 = ignition position 3 (where the ignition defauts after starting the engine)
  • KL 50 = ignition start position
I've never owned a BMW with a start button...so my suggestion would be to check your owners manual for any clarification or explanation of how or when the vehicle is in the "run" state. My guess would be sometime between inserting the fob thingy that would be considered the "key"... and when you press the START button. Or perhaps when you press the brake for those that have the CAS option where you don't have to insert the fake key thingy.
Q {BMW CCA Member #191509}
(SOLD)
Old 04-22-2014, 01:01 AM
x6cx3 x6cx3 is offline
Mein Auto: BMW X5
If you push the start button once without the foot on the brake (smart key fob in the car), you will have some electronics runnings, if you push the start button twice without foot on the brake, you will have everything on.
Old 04-22-2014, 12:36 PM
QSilver7's Avatar
Great...must add this to my mental rolodex...I'm sure some day in the future...I may own a BMW that has a START button.
(SOLD)
Similar Threads
Dolphins fend off Great White attack! Jon Shafer Off-Topic 16 12-02-2004 09:19 PM
FS: 15 inch rims style414 Classifieds 0 07-18-2004 11:07 PM
15 x 6 versus 15 x 6.5 steel wheels . . . Magna 3 Series & 4 Series 1 12-13-2002 05:19 PM
