5 Series
Ask questions and discuss the 5 Series here. If you would like to see all new posts in all the forums, click here. |
manuel to look up fuse location
If someone has a service manuel to look up fuse location # 75 listed as an auxilary fan, should be a 50 amp. my fan in front of radiator doesn't come on
thanks |
You did not specify a year, but in the E39 (1997-2003) fuse 75 would be behind the glove box.
M.Wong E38 2000 740iL Orient Blue E91 2012 328xiT Alpine White Passed on to new families: E30 1987 325i Royal Blue E39 2003 540i/6 Sterling Gray R56 2010 Mini Cooper S British Racing Green
if this is 5 series e39 fuse is behind glove box .there are 2 same size fuses one of them is for the fan but check your fan motor too they go bad all the time.i hope you have small hands you need them to get to that fuse
fuse location
Sorry, wasn't sure what you were asking other than the location of that fuse...
75 is to the left and is labeled 50 amps. (Aux fan) 76 is to the right and is labeled 40 amps. (Blower motor/final stage) One of the classic symptoms of an auxiliary fan failure is the A/C not blowing cool air unless you are driving at highway speeds. Start the car and the fan should not be moving. Turn on the A/C and it should start up. Check fuses first, then attempt to rotate it with a screwdriver through the guard when the car is off and cool. If the fan is difficult to turn or drags, your auxiliary fan is likely bad. If that's not the case, it could be a resistor. There are ways to multimeter check the system in different places, but that is beyond my DIY skills/knowledge. However, if you have to replace the fan, I think a novice DIY'er like me could do it easily. Aux fan info from BMWTips.com (Photo from same link)
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Fuse Box Location? | wildag | E46 (1999 - 2006) | 1 | 02-14-2005 05:10 PM |
| Fuse location please | docvb | E36/7 Z3 (1996-2002) and E85 Z4 (2003-2008) | 3 | 12-28-2004 08:07 PM |
| Dolphins fend off Great White attack! | Jon Shafer | Off-Topic | 16 | 12-02-2004 09:19 PM |
| Touring rear wiper fuse location? | TheMatrixz | 5 Series | 1 | 11-21-2004 06:05 AM |
