Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Do-It-Yourself H.Q.
Do-It-Yourself H.Q.
Share your DIY projects or ask questions about how to fix something on your own. Help fellow Bimmerfest members improve your wrench turning skills! All BMW DIY tips, tales, and projects discussed inside. Learn to work on your car and know the right BMW parts you will need!
Old 02-24-2005, 08:50 PM
jgcal12 jgcal12 is offline
Mein Auto: 2000 323i
Unhappy Transmission Removal
has anyone removed an E46 ZF 5HP19 tranny? how hard is it? the sale of my car is on the line here
Old 02-25-2005, 02:20 PM
TeamM3's Avatar
TeamM3 TeamM3 is offline
Living on the redline
Mein Auto: a BMW killer
if it's a manual it's a PITA, but do-able if you have the proper place and tools
if it's an automatic or SMG, I don't know
Yesterday's history, tomorrow's a mystery, but today is a gift; that's why it's called the present
Old 02-25-2005, 08:53 PM
Its the Steptronic auto. only reverse is going out but apparently i have to rebuild the whole thing
Old 08-16-2005, 11:53 AM
lv2srf lv2srf is offline
Mein Auto: 330i
I'm about to replace my own ZF due to the same problem. How did yours work out?
Old 08-17-2005, 06:29 AM
Mein Auto: 330i
Dropped the exhaust and drive shaft last night. Besides the typical shearing of the exhaust bolts it's been a pleasurable experience. Now on to the torque converter/flywheel and I still haven't figured out how to get to those top bell housing bolts...I'm going to attempt lowering the rear of the tranny and reaching it from the rear. Anyone with some experience in the removal I'm open for suggestions/advice.
Old 08-17-2005, 01:18 PM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
Lower rear of tranny, and a LONG set of extensions, and a lot of fighting and cussing.
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Old 08-17-2005, 09:25 PM
Mein Auto: 330i
Thanks for the input...worked out without a single problem. Air tools are a godsend for tight spaces once the bolt is broken with a breaker bar. My only concern was the starter which was a little stubborn. Why the hell they put the starter on top of the transmission in such a hard to reach location still leaves me scratching my head.
Old 09-13-2005, 10:31 AM
Mein Auto: 330i
Tranny Install Update
I purchased a remanufactured zf 5hp19 from PheonixRemanufactured transmissions for 1800. I also bought the Esso fluid from the local VW dealer for 15.00 a liter. It took a total of four hours to install the tranny by myself and get the driveshaft, exhaust, wires, shift linkage and all shielding back on. I will soon be replacing my driveshaft support due to a tear in the rubber though.
My only concern is that the tranny only took 8 liters of fluid instead of 8.9. I have checked the level three times and everytime the fluid level seems good at 104 degrees after shifiting through all gears for 3 seconds it will trickle out when I add an ounce. Am I missing something? I know the place I purchased the tranny from dyno's it for 30 minutes, so the only thing I can think of is that some fluid must have been left in. If anyone else has purchased a tranny and installed it have you encountered similar fill amounts?
The tranny shifts smooth no hard shifting, no slipping, although I can feel a slight shimmy at 15 - 17mph with generous acceleration which I attribute to the driveshaft support.
Old 02-26-2010, 05:47 AM
Mein Auto: 330i
Just an update...it's now four years later and 60k miles. The transmission is still working just like it did when I installed it. No problems at all. I am however receiving a CES light stating my torque converter (original) is not locking up and I can feel the converter slip at 70 when applying gas. I found on this forum several people experiencing the same problem. I have never had a torque converter go bad but I guess there's a first time for everything. I really was not looking forward to dropping the transmission again.
Old 12-07-2010, 11:16 PM
kjsgadh kjsgadh is offline
Mein Auto: 2001 330i
Did you end up replacing the Torque Converter? Other updates?
Thanks.
Similar Threads
1999 528 transmission problem? ATL2001 E39 (1997 - 2003) 9 03-01-2011 02:12 AM
* M6 * - Press Release from BMW Emission E63 / E64 M6 (2006 - 2010) 6 03-06-2007 07:20 AM
323/325 328/330 etc. engine changes Optimus Prime General BMW 15 04-03-2004 06:56 PM
Does anyone have a remanufactured manual transmission in his/her E46? ldn 3 Series / 4 Series 0 02-28-2003 05:50 AM
