Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series
5 Series
Ask questions and discuss the 5 Series here. If you would like to see all new posts in all the forums, click here.
Old 02-28-2005, 01:35 PM
jdad jdad is offline
Mein Auto: 1997 528
1997 528 Check Engine Light
This winter, my check engine light came on a couple of times, then went away. More recently, my thermostat would go into the red zone, then return to normal, then go back to red and then back to normal and the engine light came back on. My mechanic said there is a slow coolant leak and I need a $1000-$1500 repair to the head cylinder gasket, but that it may be more than that once we get it opened (new cylinder, cracked engine block). The coolant was refilled and the indicator lights are off for now. The mechanic recommends trading the car now so that I do not start putting a lot of money into an older car with 100K miles. I was hoping to keep for a while. Any advice experience is appreciated.
Old 02-28-2005, 01:58 PM
Ågent99's Avatar
Ågent99 Ågent99 is offline
Moderator, 5-Series
Mein Auto: ...a lot of people crazy.
Second opinions are of paramount importance here. See if you can find a good independent BMW mechanic.
I could tell you where to go in CA but not in PA, unfortunately....
Best of luck...keep us informed about what you find. How many miles?
How does the oil look? Is there coolant/water leaking into the oil? That usually makes the oil look lighter in color and even white sometimes...DAMHIKT!!
Similar Threads
Questions on Inspection 2 Bill97Z 3 Series & 4 Series 22 01-03-2005 10:59 AM
Check Engine Light ON Highend 5 Series 15 06-18-2004 09:13 AM
check engine light came on... LiKe_WhOa! 3 Series & 4 Series 2 06-15-2004 07:22 AM
Check Engine Light AGAIN Desertnate Off-Topic 2 08-06-2002 11:55 PM
JC Cold Air Intake - Check engine light just came on. What are my options? Tanin 3 Series & 4 Series 4 07-27-2002 11:16 PM
