E36 (1991 - 1999)
Old 03-02-2005, 10:55 PM
srikspace srikspace is offline
Mein Auto: 1993 325i
Exclamation check engine light on even after replacing oxygen sensor
Hi,
I recently bought a 1993 bmw 325i sedan with 110k miles on it. It ran great for about 4 months now. Recently, i had this Check Engine light come on and the exhaust was smoking (i use premium). I used the Peake RC5/FX to sheck for the code and it gave me 0d - oxygens sensor. I replaced the Oxygen sensor and reset the error code. After a few days, the light came back on. This time i got two error codes: 0d (oxygen sensor) again and Lambda control (it think it was C4, but it was definitely lambda control)...
The local BMW dealer said he will charge 100$ for diagnostics alone. I remember finding a similar problem to one of our members... but could not find the remedy.
I would appreciate it if anyone can point me in the right direction here.
Thanks,
Sri
Old 03-03-2005, 10:07 AM
bol's Avatar
bol bol is offline
Crazy Canadian
Mein Auto: '01 M Roadster
My 318 had multiple O2 sensor problems. A lot of water and condenstation had gotten into the ECU compartment and started to cause problems... always putting up an O2 sensor code.
I replaced the O2 sensor at first but I still had the same problem. That's when I discovered the wet ECU... I dried it off and it worked fine afterwards. I avoided touchless car washes after that...
Might not be your problem but it was mine.
Old 03-03-2005, 10:28 AM
Hi,
I checked my ecu compartment, and it is dry... as soon as the light comes on (after i reset it) i see a lot of smoke from the tail pipe... which means, the fuel system is running in open loop....
I am still not able to figure it out.
Thanks,
Sri
Old 03-03-2005, 10:34 AM
bol's Avatar
bol bol is offline
Crazy Canadian
I'd check out the O2 sensors wiring harness and see if any of the wires have been disconnected/ripped. If you know that the O2 sensor is good(have tested it, etc) then there is probably a wiring problem or problem with the ECU.
Old 03-03-2005, 04:25 PM
AC Schnitzer AC Schnitzer is offline
EURO STYLE
Mein Auto: two/325i,VW,Renault
There is two O2 sensors right? did you replace both?
Old 03-03-2005, 09:55 PM
I was under the impression that there is just one oxygen sensor...
I double checked the harness - i looks good. I donot know how to check ECU connection...
BTW, some where on the net i found that the error "Lambda control #1" also means "lean/Rich limit stop". I might have no other chice but to take it to a dealer for fixing...
Sri
Old 03-03-2005, 11:41 PM
bol's Avatar
bol bol is offline
Crazy Canadian
OBD1 BMW's have only one O2 sensor
Old 03-20-2005, 10:01 PM
Hi,
According to the local BMW dealer, the reason the oxygen sensor was failing often was a large accumulation of water in the exhaust. He also said that this was due to very small trips. he advised me to take the car for a long ~30-50 mile trip every month if possible.
Anyway, a 400$ later, all seems to be fixed.
Thanks,
Srikspace
Old 10-14-2009, 09:13 PM
shreker shreker is offline
Mein Auto: 1995 bmw m3
so was it the o2 sensor after all????
Old 10-14-2009, 09:21 PM
Hellawut??
Mein Auto: who knows?
did you reallly bring this back from 2005???
fail
-Franklyn
Old 10-14-2009, 10:07 PM
Oh ****....I didn't see that...I would love to know if this fixed the problem???
Old 10-15-2009, 08:42 AM
madromas's Avatar
madromas madromas is offline
Alja Bydlo
Mein Auto: 93 325i
that's what you payd, to get rid of oxygen sensor problem? no offence but OMG!
From Russia with LOVE
Fun and Unique VipJournal
Old 10-15-2009, 10:50 AM
bimmerbarbie's Avatar
bimmerbarbie bimmerbarbie is offline
Official Queen of E36 OT
Send a message via AIM to bimmerbarbie
Mein Auto: 93ish 325ish
fail
He's searching for the answer to his possible O2 issue, that's why he bumped this. Props for searching at least. Try a google search, not just on the Fest.
Originally Posted by E36 Phantom View Post
... We all kinda just ignore Amber (barbie) anyway. She's sort of our attitude and eye candy here, that's why we keep her around...
Old 10-15-2009, 11:45 AM
Hellawut??
he is not going to get an answer... the op has not been online since 2005
-Franklyn
Old 10-15-2009, 12:58 PM
Well atleast I'm searching!!!
Old 10-15-2009, 02:52 PM
Well atleast I'm searching!!!I don't think it should matter how old it is...The funny thing is people are still haveing the same problem....and still can't find an answer!!Plus I keep it old school!!lol!!!!!
Old 10-15-2009, 02:59 PM
madromas's Avatar
Alja Bydlo
Mein Auto: 93 325i
Have you changed at least some parts that are mentioned above in your life time? It will help eliminate them.
List parts that you have changed since you owend it. Or if you know the person before changed something. Hard to point a finger on something just because it's 1222.
Old 10-15-2009, 04:47 PM
im im is offline
Mein Auto: bmw325i /318ic
just because a code reader gives a code regarding the oxygen sensor does NOT mean the oxygen sensor requires replacement.
sometimes a vacuum leak, loose wire, miss fire or other is the cause of the oxygen sensor code.
Old 10-15-2009, 07:39 PM
E36 Phantom's Avatar
E36 Phantom E36 Phantom is offline
I Am The Machine
Mein Auto: Dreier, Fünfer & Siebener
Thanks for searching man. Much preferable to starting a new thread.
What im said is exactly correct. There are different types of O2 errors and all kind of fun things. Sometimes the O2 code can just mean the values are outside the normal range, which means a different problem than the O2 sensor itself malfunctioning.
Specifically, what code(s) are you getting man?
// Chad //
// 2006 BMW 330i Sport 6MT // 2006 Toyota Highlander Hybrid //
// 1997 Range Rover 4.0 // 1994 Range Rover Classic //
// 1997 Land Rover Discovery // 1998 Land Rover Discovery //
// 2009 Kawasaki Concours 14 // 2006 Kawasaki Ninja 250 //
// 1999 Chevy Tahoe //
Ok...this is getting ridiculous. Someone come buy a few of these things.
Originally Posted by SlimKlim View Post
You're a derbanana
Old 10-15-2009, 08:31 PM
That's the only code I'm getting I changed:spark plugs,o2 sensor,boots on the coils,relay dme,relay fuel pump,tps,iacv=on it's way,checked all vaccum lines,cleaned out throttle,.....that's it I think....what else should I change??
Things that I think I should change:
cam positioning sensor
maf
fuel pressure regulator
d.m.e ecu
Anything else you guys can think of???let me know
Old 10-15-2009, 09:25 PM
madromas's Avatar
Alja Bydlo
Mein Auto: 93 325i
iacv=on it's way
If you mean ICV. Than do that first. Go from there.
Old 10-15-2009, 09:44 PM
Update:there was a air line from the manifold that was disconnected!!!dammit!!!!so I put it back.....so that was my air leak!!so I connected it back and still has a hard problem starting..could that of caused my fpr to go out???would that make it take **** basically!it was a line that goes from the manifold to the fpr!!!
Old 10-16-2009, 02:28 AM
Uhhh... He DID start a new thread? Am I the only one that saw it, and replied? Guys, take this to HIS thread. Would make more sense to me, at least.
http://www.bimmerfest.com/forums/sho...d.php?t=404992
And btw, why the eff did you not mention all that you'd changed already in the original post?
Old 10-16-2009, 02:47 AM
Sorry......i didnt mention it...my bad!but in my last post...did you see what I wrote...I'm thinking of buying a fpr...but the ones online have no connection for a vaccum hose...cause the one on my manifold,has a connection for a vacumm line...I'm clueless right now about that!!!!help
Similar Threads
BMW's New Six-Cylinder Engines - In Depth sk330i General BMW Questions 7 07-19-2006 05:52 PM
help with abs/asc and check engine light roo97ss E36/7 Z3 (1996-2002) 7 06-29-2004 11:10 AM
BMW Update for S54 Engines BMWNA 1M & M2 2 08-13-2003 06:55 PM
So I was spinning around on ice in a parking lot... (check engine light) JonW 3 Series & 4 Series 20 02-19-2003 03:01 PM
Check Engine Light AGAIN Desertnate Off-Topic 2 08-07-2002 12:55 AM
