Old 03-10-2005, 09:13 AM
shizat63's Avatar
shizat63 shizat63 is offline
takes the long way home..
Mein Auto: 05' 330i ZHP
E90 vs. ZHP at the track
Stock E90 330i vs. stock 330i ZHP- autocross or Neurburgring, who would take it and by how much?
My money would be on the E90 at Nurburgring b/c of the HP advantage, but at an autocross I would give it to the ZHP.
Old 03-10-2005, 10:59 AM
MJTSUB MJTSUB is offline
Mein Auto: x3, e30 325ix, e39 540i/6
Probably the ZHP in autocross since its just slightly lighter, geared lower (numerically higher) and has a shorter wheelbase.
The open track who knows. The e90 definetly has a HP advantage but who knows.
Old 03-10-2005, 11:01 AM
hugh1850's Avatar
hugh1850 hugh1850 is offline
Mein Auto: 335i
The ZHP, cause, well, it kicks butt.
2011 335i M-Sport
Old 03-10-2005, 11:03 AM
Nick325xiT 5spd's Avatar
Nick325xiT 5spd Nick325xiT 5spd is offline
Send a message via ICQ to Nick325xiT 5spd Send a message via AIM to Nick325xiT 5spd Send a message via Yahoo to Nick325xiT 5spd
Mein Auto: M3 & 323i/999 KP
The E90 330 has a 3.15 rear diff, so it'll easily overpower the ZHP.
Presumably, like every revision of the 3 series, it will also outperform its predecessor.
2006 GMC Sierra 2500HD 4WD Duramax LBZ/Allison 6-speed
2002 BMW M3 Alpinweiß/Black
1999 323i KP/GTS2 Alpinweiß
1990 325is Brilliantrot/Tan
1989 325is S50B30US Alpinweiß/Black
1989 M3 Alpinweiß/Black S50B32 (321hp, ITBs)
Old 03-10-2005, 11:29 AM
adc adc is offline
BMW Fahrer
Mein Auto: E90 M3
The ZHP, of course
The ZHP is a track king as well, not just autocross. Last time I was at Summit Point I was passing Nick325xiT in his E46 M3 with ease, lap after lap. Just ask him...
Oh no, wait, it was the other way around!!!
I too have the feeling the E90 will be faster, in all categories...
adc
03 330 ZHP
Old 03-10-2005, 01:07 PM
Chris90 Chris90 is offline
Mein Auto: '04 330i
As others have said, i'm sure BMW designed the E90 to run the Ring faster. Look at the 130i, it's runs like a scalded rabbit out there.
"When you were born, you cried and the world rejoiced. Live your life so that when you die, the world cries and you rejoice." - Cherokee Expression
Old 03-10-2005, 01:23 PM
KrisL's Avatar
KrisL KrisL is offline
Ubergeek
Send a message via AIM to KrisL Send a message via Yahoo to KrisL
Mein Auto: 330i ZHP & 04 Honda VFR
FWIW, Car & Driver got the exact same 0-60 and 1/4 mile times out of the E90 330 in Spain as they did the ZHP. 5.6 & 14.3, respectively.
Old 03-10-2005, 02:18 PM
MicahO's Avatar
MicahO MicahO is offline
In my own cars again
Mein Auto: 330i ZHP
As others noted - history would make me put money on the e90, as it's the new generation. As for FEEL - I'll take the e46 ZHP, with none of that active steering disconnect.
The good news is that there is apparently going to be a 330 wagon brought stateside in the e90 family. So if BMW In-duh-vidual gets a crack at an e90 Performance Package, and applies it to the wagon.... Well, I'll be as happy as a pig in sh!t.
--Micah O'C
CCA 193374
'88 M5, Bilstein Sports/ST Springs, staggered BBS RS, Euro conversion
'04 330i ZHP, Jet Black 6spd, hot seats, LightWerkz TFX-Xenon, Bilstein PSS10
UUC Strut/SwayBarbarians, PowerFlex CAB/TAB, Performance Gearing 3.38 LSD
Old 03-10-2005, 02:26 PM
Did it have run flats?
Did they launch on a similar surface?
What was the temperature?
Same driver?
If it weighs more, it'll likely get substantially faster as speeds go up.
Old 03-10-2005, 05:48 PM
cwsqbm's Avatar
cwsqbm cwsqbm is offline
Dreaming of Track Days
Mein Auto: ED'd 330Ci / E30 325i
Same driver?
run flats, yes and they say the E90 times were done on "a surface with poor grip".
Driver not an issue assuming both were C&D drivers of high caliber, and C&D corrects for temp, air density, etc.
.................................................. ............................................. Space for rent .................................................. ..........................................
Old 03-11-2005, 07:15 AM
brave1heart's Avatar
brave1heart brave1heart is offline
Lap Dog
Mein Auto: '08 Z4 M Coupe, '01 325i
The new cars always perform better. 0-60 and 1/4 miles times are not a great predictor at all on how they will do at the track. I'll put my money on the E90, all else equal. If only because of the 25% better structural rigidity...
'08 Z4MC, Interlagos Blue, Black int, CF trim, H&R springs, TMS camber kit w/ -3 deg, 245/275 Nitto NT01 on D Force LTW5 wheels, 245/275 Dunlop Direzzas
'01 325i: Orient Blue/black, SP, M stress bar, UUC sways, TMS camber plates, TMS rear sub reinf kit, CAI, Shark, Borla, Dunlop Direzza 245/40/17 on 17x8 O.Z. Superleggeras
HPDE instructor, Boston Chapter Autocross Co-chair, Boston Bimmer columnist www.boston-bmwcca.org/bimmer/online.aspx
My performance driving site: www.OneHotLap.com
Old 03-11-2005, 07:16 AM
So the launch sucked.
and the driver is absolutely an issue, unless we're talking about a fairly professional drag racer. Consistency on launches requires a LOT of skill.
Old 03-11-2005, 11:54 AM
blm blm is offline
Mein Auto: '08 E92 335i
One thing I found interesting was the 0-60 specs that BMW has published. Of course, I know there's more to life than 0-60 times, and with manuals that number can vary quite a bit based on conditions. Still, I've seen them say the E90 330 will get to 60 in about six seconds (can't recall if I've seen an exact number or simply an estimate), and of course their literature says the ZHP will do 0-60 in 5.9. Seems like if there was a significant difference, they would be quicker to point that out. Of course, that's probably a big point right there -- on simple measures like this, there *won't* be a huge difference
'08 E92 335i | 6MT | Montego Blue | Black Leather | Aluminum Trim | ZSP | ZPP | ZCW
Old 03-11-2005, 12:50 PM
Test_Engineer's Avatar
Test_Engineer Test_Engineer is online now
Drives cars for a living!
Send a message via AIM to Test_Engineer
Mein Auto: '01 BMW 330i
I would guess that the E46 ZHP would be faster around "the Ring" compared to the standard E90. The places where HP help you is in the long straights, but since the cars are limited to the same top speed (asumption of 135ish), the extra HP is not that much of an advantage. Besides that, the ZHP handles the fast twisty section much better than the standard suspension. The Ring is all about what car can remain the smoothest and maintain the highest speed, not who has the most HP. The ZHP suspension is tuned very well and remains very flat and stable near the limit. This is a trait that makes the ZHP very easy to drive fast on the Ring. I assume the E90 standard suspension will have a very similar flavor as the E46 standard suspension. Now std to std comparison, I'd put money on the E90!
Old 03-11-2005, 12:56 PM
Lap Dog
There's a lot of marketing that goes into these 0-60 numbers - don't pay too much attention to them They wouldn't want to show that the ZHP is as fast as the E36 M3.
Old 03-11-2005, 01:03 PM
The HACK's Avatar
The HACK The HACK is offline
Rest in peace, Coach
Mein Auto: '06 MZ4C, '09 WRX Wagon
You want to guess which car is faster around the 'Ring, E46 M3 or E63 645Ci?
Let me give you a hint: The 645Ci has less HP (325 v. 333), weighs more (by about 200 lbs I think), don't have the vaunted "///M" suspension.
Let me give you another hint. It wasn't the M3.
Old 03-11-2005, 08:26 PM
Moderato's Avatar
Moderato Moderato is offline
Praetorian
Mein Auto: 07 E92 335i 6MT
What??? The 645Ci is faster then the E46 M3 at Nurburgring?
Old 03-11-2005, 08:49 PM
Is that so shocking?
All E46es have **** suspension setups from the factory.
Old 03-11-2005, 08:52 PM
Mr. The Edge's Avatar
Mr. The Edge Mr. The Edge is offline
Mein Auto: .
Belief cannot argue with unbelief, it can only preach to it
To clasp the hands in prayer is the beginning of an uprising against the disorder of the world.
Old 03-11-2005, 09:17 PM
johnnygraphic's Avatar
johnnygraphic johnnygraphic is offline
Mein Auto: 330i Performance Package
I would have to say that the ZHP would win hands down. Superiority in all things ZHP!!! I mean, after all, this IS a ZHP Forum right???
Johnny
Old 03-11-2005, 10:22 PM
The HACK's Avatar
Both of them lapped the 'Ring at 8 minutes, 19 seconds.
Old 03-12-2005, 12:05 AM
blm blm is offline
Oh, I know. That's why I was surprised they didn't market up the E90 a bit more!
Old 03-12-2005, 06:12 AM
Moderato's Avatar
Praetorian
Yeah it's shocking! I would've bet money that the E46 M3 would've been faster and more nimble then the 645Ci. In a straight line race I could see how it would be close, but at Nurburgring? Is the stock suspension on the 645Ci really that much better then the M3? Is that due to the active sway bar? Also, the 645Ci has to weigh more then the M3 right?
What about the 545i, is that about the same as the 645Ci & M3?
Old 03-12-2005, 07:14 AM
Mein Auto: '04 330i
Johnny
When is BMW going to make a ZHP badge accessory? I want one for my 325i.
Old 03-12-2005, 11:34 AM
The HACK's Avatar
1) You can't make up for torque. The 645Ci has a ~70 #ft torque advantage if I'm not mistaken.
2) You'll be very surprised what active roll stabilization can do. The roll bars on the 645Ci can vary from completely de-coupled to STIFFER than that of an M3. What that allows you to do on the track is keep tires on the tarmac AT ALL TIMES. Remember, stiff sways don't always equal to better times around the track, when your suspension is too stiff you wind up lifting a tire in a tight corner and you lose more traction. I rode in a 745i with sports package with a seasoned instructor driving at Fontucky, and despite the weight he was chasing down various A and B students in their E46 M3s.
3) The 645Ci is only marginally heavier than the E46 M3.
Don't have the times for the 545i but it should be close.
Similar Threads
330 zhp now or wait for e90? SoS 3 Series / 4 Series 20 07-24-2004 07:33 PM
E90 expectations and rumored components Andm99 General BMW 0 02-26-2004 07:33 PM
Anyone track a ZHP yet? BradATL Motorsports, Racing & Track 5 06-09-2003 09:27 AM
Anyone track a ZHP yet? BradATL 3 Series / 4 Series 4 06-04-2003 09:13 AM
ZHP on coupe and convertible... definite maybe alee 3 Series / 4 Series 5 04-20-2003 06:58 AM
