M Series
The ///M Series Forums. If you would like to see all new posts in all the forums, click here. |
e46 m3 suspension
i am thinking about doing suspension work on my e46 m3. i was thinking about putting a set of H&R spring in on the front and rear and leaving on the factory shock absorber. does anyone have any recomendations or ideas of what i should do?? i want something that performs well but will also give the car that low stance.
thanks Joe |
Alex |
What's more important to you? ....performance, or "that low stance"
If performance really is a priority you'll need new shocks to go with the springs. A lot of people seem to prefer the Eibach springs to H&R. Of course for a little more you can get coil-overs.... |
Considering that the stock shocks have half their dampening gone by 10K miles, do the shocks, even before the springs.
Terry Carraway '95 Alpine M3 LTW '00 Dakar M Roadster '02 Topaz M3 Red/White SRF #4 (Chassis 561)
Just install a complete Ground Control suspension...you're going to spend $1000 after labor doing spring and/or shocks anyway...do it once the rightway... get the car corner balanced and alinged right, spec out the spring rates and shock valving that is right for your style of driving and leave it alone.
At the minimum I would do Ground Controls kit including Koni SA shocks, coilovers, rear shock mounts, front camber plates, control arm bushings front and rear. You should be able to get there for about $2000 installed. If you go the other route you'll end up paying labor twice, each suspension install will cost $350-500 after alignment. Condidering the Ground Control is only $2000 done right, why spend the extra parts and labor screwing with just shocks and lowering spirngs, you'll be out half the money compared to "doing it right the first time" anyway. The incremental cost of doing it right is too small to do it any other way. That and you car will actually handle better than stock, not just look better, you'll get form and function.
![]() Homepage Performance BMW Article Performance BMW Article(Bimmerfest) Detailed Modification and Alignment Specs Big Brake Kit Excel Spreadsheet |
You can get some life out of the OEM shocks with the H&R springs. But OEM wasn't designed to damp well at the point where the H&R springs sit. I just upgraded the OEMs to Koni adjustables and I'm pleased with them. All the slop and bloat in the OEM shocks in gone.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| E36 M3 or E46 M3? | IndyMike | General BMW | 18 | 10-16-2010 08:25 AM |
| ModBargains | January 2005 Specials | Mike@Modbargains | Site Sponsors & Bimmerfest Group Buys | 10 | 06-10-2006 07:35 AM |
| FS: Brembo e46 m3, e46 non m, e39 m5 14" and e36 m3 kit BRAND NEW | berman66 | Classifieds | 0 | 06-25-2003 06:01 PM |
| E46 M3 front suspension fits in a 330Ci ??? | wookiehoth | 3 Series / 4 Series | 4 | 06-20-2003 09:42 PM |
| So I drove an E30 M3 tonight... | Jetfire | M Series | 47 | 03-27-2003 06:18 PM |
