E36 (1991 - 1999)
Old 03-15-2005, 04:59 AM
joaquinept joaquinept is offline
Mein Auto: BMW E36
E36 316i Turbocharging Plans...
Anyone here tried installing turbo on their 316i? As you all know, 316i is sooo underpowered, thats why a turbo is an option for me. How many horsepower will this turbo add up t?
Old 03-16-2005, 01:05 AM
AC Schnitzer AC Schnitzer is offline
EURO STYLE
Mein Auto: two/325i,VW,Renault
daily driver: Supercharged
not a daiyly: turbo charged more HP that is for sure but more problems.
Old 03-16-2005, 02:29 AM
Mein Auto: BMW E36
what kind of problems may occur? engine failure?
Old 03-17-2005, 06:01 AM
mashkal mashkal is offline
Mein Auto: 316i
DONT DONT DONT Turbocharge it.. You probably have the M40 or M43 B16 engine. Ramming air into this 8V SOHC engine is not worth the money. Mind you that a NA 325 will smoke your turbocharged 316i on the highway and trust me, you won't feel good.
If you have the cash consider an engine swap.
Old 03-18-2005, 09:20 AM
m44droptop m44droptop is offline
Mein Auto: 1996 bmw 318i
yeah dude swap a m44, everything should bolt up with a ECU and wiring harness. I wouldnt recommend turboing the 1.6 even if you could find a kit for it.
Old 06-05-2006, 05:40 AM
patsanjay patsanjay is offline
Mein Auto: 318i
M44 engine
hi guys i drive a e36 with a m4O engine. im considering swaping my engine for a bigger one. you mentioned the m44. do i need to make any other modifications. suspension? breaks? gauges. steering ?
Old 06-05-2006, 05:42 AM
Mein Auto: 318i
would any other engine go in to my car
Old 05-11-2008, 06:32 PM
1998E36COUPE 1998E36COUPE is offline
Mein Auto: E36 Coupe
Question transmision manual
hey man if I'm interested to swap my m43 with a m44 engine but should if I also change the transmission? or some gear?
Old 05-11-2008, 11:10 PM
Fox2112 Fox2112 is offline
Mein Auto: 1992 320i 6 speed....
I dont think you know very much about turbocharged 316's...... Fist of all a good turbocharger will add 600 hp.... that will leave a NA 325 in the dust in a second.... Do twin turbo charger and you have well over 1000hp.... there isnt a NA 325 in the world that will keep up with that..... other than that.... with the switching engines part.... you would be smarter buying new and build that for a turbocharger....
Old 05-12-2008, 06:19 AM
Chris S Chris S is offline
Mein Auto: 1997 323i
600-100hp? sounds like something will blow... and a four cylinder engine gettin that much.. just doesnt sound right afterall what does the stcik 316 have? under100 or at least under 120hp? so your suggesting like a 5X power increase?
Old 05-12-2008, 07:24 AM
E36youngster's Avatar
E36youngster E36youngster is offline
blank
Mein Auto: 07 e92 335i
Fist of all a good turbocharger will add 600 hp....have well over 1000hp....
that statement is a bit ridiculous
Old 05-12-2008, 07:55 AM
B/\/\W's Avatar
B/\/\W B/\/\W is offline
Monacoblau mit beige
Mein Auto: E92 330i Manual
Haha, hilarious.
The gearbox would be melted within a few seconds, and the pistons would blow right out of the cylinders at that kind of boost.
330i SE coupé
Manual - N52K 262hp, 232ft-lb
Old 05-12-2008, 09:50 AM
328ICantlose 328ICantlose is offline
Life's more fun topless!
Mein Auto: BMW 328 IC
If you swapped to m44 motor, fully modded it, put a twin turbo on it, and did every other considerable modification to it THEN and only then you MIGHT make 800 horses on a motor that small; and B/\/\W's right, your motor'd be fully toasted after an hour or so. Swap the motor first, don't ever expect to get a thousand horses out of ANY vehicle you haven't invested HEAVY HEAVY TIME (months) and MONEY (tens of thousands) into.
Old 05-12-2008, 10:19 AM
e30e e30e is offline
Search: Top right corner
Mein Auto: e36 m3/4
Have you ever posted anything of value?
Old 05-12-2008, 11:38 AM
No all I am saying is that 325's aren't all top sh*t like every one claims.... And yes it yould melt if you f*cking retarded and dont rebuild everything that has to do with the engine..... You know you all are f*cking negitive motherf*ckers.... All of you also buy you car to baby it.... Look it isn't a f*cking million dollar car..... Buy it, build it, drive it, show it off, When it fails fix it.... it isn't that hard....
Old 05-12-2008, 04:49 PM
Mein Auto: e36 m3/4
Explain to us, how hardcore bad ass your 320i (THATS WHAT YOU GARAGE SAYS YOU HAVE) is and how we should follow your lead. STOP POSTING WRONG INFORMATION!
Old 05-12-2008, 07:28 PM
kennedy1989's Avatar
kennedy1989 kennedy1989 is offline
[MYTURN]
Send a message via MSN to kennedy1989
Mein Auto: E36 318is
First of all a good turbocharger will add 600 hp.... Do twin turbo charger and you have well over 1000hp.... there isnt a NA 325 in the world that will keep up with that.....
not to take sides but i agree with th eother guys... thats a bit silly...
600hp is about 450kW, on a 4cyl engine? doesnt make any sense. i dno how things work over there, maybe you have some magical way to fit a turbo thats bigger then your engine into the tiny engine bay, but over here in AUST, ( home to v8's ) you can buy a brand new 6L 6speed manual V8 and still only have just over 300kw which is about 400hp.
correct me if im wrong, but i cant comprehend how youd get such power from such an engine.
if you can, tell me!! i have a 95 318is and i wouldnt mind chopping $100 000 Hsv's.
1990 Nissan R31 Skyline 3.0L 6Cyl -[Sold] 1995 BMW E36 318is 1.8L 4Cyl -[Current]
Old 05-12-2008, 07:37 PM
Edev's Avatar
Edev Edev is offline
BMW Genius @ BMW Portland
Mein Auto: M Coupe
whoa. why are you getting so pissed. it sounds like youre the one being negative about it. and not everyone is saying that a 325i is top sh*t..get your facts straight
BMW Genius @BMWPortland.
2000 Z3 M Coupe
Old 05-13-2008, 12:45 AM
Raven6910 Raven6910 is offline
Vampire Freak
Mein Auto: 1992 E36 320i
Not to take sides either but I think fuc* him.... don't pay any attention to that Bimmer killer, and mabe he will go away....
Old 05-13-2008, 03:45 AM
The Bugatti Veyron 16.4 is a mid-engine sports car produced by Volkswagen AG subsidiary Bugatti Automobiles SAS introduced in 2005. It is the quickest accelerating and decelerating street-legal production car in the world, and was the world's fastest street-legal production car until the SSC Ultimate Aero TT in 2007.
Powered by a 1,001 PS (987 hp/736 kW) W16 engine,[2] it is able to achieve an average top speed of 407.47 km/h (253.19 mph).[3] The car reached full production in September 2005, and is handcrafted in a factory Volkswagen built near the former Bugatti headquarters in Château St Jean in Molsheim (Alsace, France). It is named after French racing driver Pierre Veyron, who won the 24 hours of Le Mans in 1939 while racing for the original Bugatti firm.
and even THAT has less than 1000HP... somehow a 4 cylinder car gettin 1000hp outa turbo sounds real ridiculous any way you put it mate
Old 11-18-2009, 04:44 PM
masterpiece555 masterpiece555 is offline
Mein Auto: BMW 325e e30 / a BMW e36
i have a 316i and packed a turbo in it. yeah, it still couldnt match a 325i hence for the 25-30 additional horse power it added. but, compared to a regular 316i i have driven, it runs lighter and has more torque and for me it the perfect daily driver. gas mileage is pretty much the same as that of the stock.
Old 11-18-2009, 04:47 PM
Mr Gusta's Avatar
Mr Gusta Mr Gusta is offline
Fireballs inc.
Send a message via AIM to Mr Gusta
Mein Auto: big turbo hellrot sedan
pictures please
and holy thread revival batman
Turbo lag is just a headstart because the chase is more exciting than the win - Abraham Lincoln
Old 11-18-2009, 04:49 PM
Los's Avatar
Los Los is offline
Too soon Junior
Mein Auto: Elise<3
Three epic revivals in one thread...I thought I'd seen it all.
@hanloso. '98 328i/'09 Tahoe LTZ
Old 11-18-2009, 04:59 PM
Mr Gusta's Avatar
Fireballs inc.
Old 11-18-2009, 05:40 PM
Corey Milne's Avatar
Corey Milne Corey Milne is offline
FixItFaster
Mein Auto: EuroS50B30, e83m54b30
I just read through this thread... Uber fail.
Similar Threads
My E36 v. E46 thoughts (very long) JST 1M & M2 49 12-18-2006 11:45 AM
E36 Shirts FS - from regional E36 gathering Lance Racing Classifieds 4 10-06-2004 09:03 AM
NJ BMWCCA Round 2 Elwood Motorsports, Racing & Track 75 07-06-2004 04:45 AM
Seattle area e36 drivers meet on Oct 12th RedmondRocket 1M & M2 3 10-01-2003 11:27 AM
E34 or E36 Michael330 General BMW Questions 44 08-25-2002 05:59 AM
