E34 (1989 - 1995)
Old 03-15-2005, 12:37 PM
kcraft kcraft is offline
Mein Auto: 525i
Installing a new gas tank door hinge
I need to install a new gas tank door hinge (part number: O3119-80663) and I can not get the old hinge (partially intact) removed. (I have a 1994 525i.) I purchased the part online and it did not come with any instructions. Does anyone have any advice on how to remove the old part of the hinge still hanging on the gas tank area? I think the new hinge will snap into place on the old gas tank door, but I don't want to just tear the old hinge off and mess up any pieces on the car I may need for the new hinge to snap into place. Any advice is much appreciated...
KC
Old 03-15-2005, 12:49 PM
Ågent99's Avatar
Ågent99 Ågent99 is offline
Moderator, 5-Series
Mein Auto: Trek 6500 MTB
Dunno it will help but can you take some pics and post them?
Old 03-07-2006, 11:51 AM
derrith derrith is offline
Mein Auto: 1994 530i
I just had this happen to me. It's a fairly easy fix, I found a new part at Bimmer Parts Wholesale for $12 and change, plus 5.50 for shipping. The broken bits are clipped into the frame and the fuel door and a a bit of a pain to remove. I used a small flathead screwdriver to depress the tabs and get the broken parts out. I'll update when the part gets here later this week with whether or not it's necessary to save any parts. Best of luck to you.
Old 03-07-2006, 03:32 PM
SharkmanBMW SharkmanBMW is offline
On the HI-Way of Life
Mein Auto: '94 540i, '03 330Xi
go here and have a look.... best e34 site
Old 03-09-2006, 10:12 PM
liquidtiger720 liquidtiger720 is offline
Mein Auto: e46 m3 ZCP, 335d
Kraft, IIRC....i just broke mine all off. Take a look at the new part and look at the attachment points....then you can figure out how to get it off, should be simple. It only took me ~5 minutes to do the job.
Old 12-22-2008, 01:11 PM
pavman pavman is offline
Mein Auto: 2001 BMW 740iL
I know this is an old thread, but I just broke my door off while trying to use the door to dislodge ice that had gotten under the door. I checked online, found a hinge @ autohausaz for $9.50. I was wondering of those who attempted it, was it difficult removing the old hinge hardware? I'm thinking it just clips in, so it looks like long-nose pliers and maybe a flathead screwdriver should suffice, but figured I'd ask here while I wait for it to ship.
Old 12-30-2008, 01:22 AM
E34freak E34freak is offline
Mein Auto: 4 bmws
Be aware that the cold will make the job much harder then it should be. If you have a warm place to install this it could save you from breaking another. I just took off a door intact in florida and it was easy. If I were to attempt the same thing in MI I would have broken the hinge.
Similar Threads
Ran out of Gas!!!!! 1/8th tank left!!! jblackburn General BMW Questions 10 06-26-2005 10:16 AM
91 850i - Gas Tank Removal - Help Needed nicko 7 Series & 8 Series 3 03-28-2005 05:36 PM
Full tank of gas on redelivery? 325SMG European Delivery 18 04-14-2004 07:21 PM
Something's wrong with my gas tank qewl 3 Series & 4 Series 12 08-20-2003 07:52 AM
Found little pin in my Gas tank...WHAT? 330Guy 3 Series & 4 Series 5 05-24-2002 09:20 PM
