Old 03-18-2005, 08:46 PM
ICEBERG ICEBERG is offline
Mein Auto: 2008 BMW 335i Sedan
Unhappy Burning Smell From My New X3..Help...
Hi guy's
My X3 just came in today. Wonderfull car. But i noticed a burning rubber smell when i got it home and parked in the garage.
The car has only 50km on it. When i took delivery it had only 9km. When i took it home it smelled like burning plastic bag from the engine.
Should i be worried? Is it very new and thats why it is doing this?
Any info would be great.
P.S it is a step auto. So it is not the clutch.
2005 2.5i X3
Metallic Black
Premium Package
Activity Package
Heated Steering Wheel
Many More options to list.
Old 03-18-2005, 08:59 PM
The car is only 5 hours old before this happened. Also i was doing highway driving home at about 100km/h but i never went over 3500 rpm. So worried, hope nothing serious.
2005 2.5i X3
Metallic Black
Premium Package
Activity Package
Old 03-18-2005, 09:13 PM
xspeedy's Avatar
xspeedy xspeedy is offline
mmm... carbs!
Mein Auto: 2007 E90 335i
It is probably just cosmoline burning off the undercarriage.
Old 03-19-2005, 09:15 AM
tonymey tonymey is offline
US Army Retired
Mein Auto: 2005 X3 , 2009 Corvette,
I notice this too
I notice this too after I parked my X3, so I'm not crazy,, thanks for the post. It's probably just "new" sfuff burning away, I would not worry about it too much unless you start to see smoke
Red 2009 Corvette, Red 2005 X3, Red 1990 Camaro RS
Old 03-19-2005, 03:27 PM
Thank's guys.
The smell went away today. Hope it will stay away. No smoke.
Love this car though. Drives great. Corners good as my C230. No rattles or shakes. Solid as a rock so far.
Will post pics. when i have time.
2005 2.5i X3
Metallic Black
Premium Package
Activity Package
Old 03-19-2005, 05:33 PM
iChick iChick is offline
Hi Tech GI Jane
Mein Auto: 2005 X3 3.0i
Originally Posted by ICEBERG
Thank's guys.
Mine had that smell after its first trip "home". Went away after a day or two.
iChick
2005 X3 3.0i, Sapphire Black, Black Leather, Dark Wood, Automatic, Premium Pkg, Premium Sound, Navigation, Privacy Glass, Heated Front Seats , Chrome Exhaust Tips
Old 11-06-2011, 04:36 PM
craigmack1's Avatar
craigmack1 craigmack1 is offline
Mein Auto: 02' 325i
Any follow up info on this "burning smell" issue. when my wife parks the car in the garage you can smell something burning. i drove it today and noticed the smell is in the cabin when at a light or something but kind'a fades away as you drive. it it much more noticeable now that we are using the heat in the car instead of the air.
no leaks
99k
stumped!
'02 325i
'04 X3 traded
'99 528i RIP
'95 325i RIP
'84 318i RIP
Old 11-06-2011, 05:50 PM
mlukas161's Avatar
mlukas161 mlukas161 is offline
Mein Auto: 03 330i, 04 X3
This burning smell is almost definitely the valve cover gasket leaking. Its a rubber gasket that gets dry with age and allows small amounts of oil to escape and burn on the headers. It's a common problem. A pretty easy DIY fix and parts are less that 75 dollars. Do a search and a lot of info will show up, mostly with the 3 series BMWs.
Old 11-06-2011, 05:54 PM
madurodave's Avatar
madurodave madurodave is offline
BMW Enthusiast!
Mein Auto: 2007 Z4+X3, 2006 530Xi
no leaks
99k
stumped!
Could've what I just had. I spilled a little oil at my last change. Must be on pipe below. Fading now. Took a while to fade.
Or could be leaking gasket or seal.
Madurodave
My garage: 2013 BMW 550xi GT, 2007 BMW Z4 3.0si Manual, 2006 BMW 530xi
Retired: 2007 BMW X3, 1998 BMW Z3
Member of BMWCCA!
Old 11-12-2011, 05:04 PM
craigmack1's Avatar
Mein Auto: 02' 325i
thanks for the info guys. i am seeing some smoke so something is definitely leaking and burning off somewhere, and sounds like a good call on the valve cover gasket. i am going to get on that as soon as i can before oil gets down into one of the pistons!
'02 325i
'04 X3 traded
'99 528i RIP
'95 325i RIP
'84 318i RIP
Old 11-14-2011, 10:22 AM
fivepointnine fivepointnine is offline
Mein Auto: BMW X3, Hyundai Genesis
a valve cover gasket leak will drip right down by the rear O2 sensor (on mine at least) and will smell with the head on at idle. my VCG had 67k on it and when I pulled it off it was no longer rubber, it was almost like brittle plastic! takes about 2 hours and is a very very easy job, all the gaskets and grommets were about $70 from my local BMW dealer. BTW I had 0 sludge in the head!!!! (just a little crust on the inside of the valve cover)
Old 11-14-2011, 11:44 AM
Martin5333 Martin5333 is offline
Mein Auto: BMW X3 3.0i
Guys this is what exactly happened this morning with my X3. Every once in a while I see a bit of smoke out the motor compartment and by inspecting i can tell there is a bit of oil under the valve cover gasket that is burning out....I`m not sure if due to oil spil during the fill or dry rubber gasket....Will see!
X3, 3.0i Mystic Blue Metallic, sport and cold weather package, xenon, steptronic
Old 11-25-2011, 02:47 PM
craigmack1's Avatar
Mein Auto: 02' 325i
well, i changed the valve cover gasket. it was brittle just like already described. i still am seeing and smelling some oil, but i just hope that it is just the loose oil burning off from doing the job. i will watch it for a few days. hopefully it will all burn off soon.
'02 325i
'04 X3 traded
'99 528i RIP
'95 325i RIP
'84 318i RIP
Similar Threads
clutch smell burning hightest E46 (1999 - 2006) 3 02-16-2005 08:02 AM
Burning smell dagoo98 5 Series 4 01-20-2005 11:18 PM
Burning smell Flimson 3 Series & 4 Series 8 05-16-2003 11:50 AM
Where does the burning clutch smell come from? 2001E46 3 Series & 4 Series 1 03-10-2003 10:39 AM
