E36 (1991 - 1999)
Old 03-20-2005, 07:11 AM
Rated_r Rated_r is offline
Mein Auto: nothing
Lsd oil,and tranny
i need to change my gear oil and tranny fliud and i need a clutch. and flywheel. I will make this short, I am new to the bmws so i need help, i track the car about 5 times a year and i drive the twistys almost everyday, The car is a 95 325i sedan 5speed. If anyone can help it will be greatly appreciated
Old 03-23-2005, 11:36 AM
m44droptop m44droptop is offline
Mein Auto: 1996 bmw 318i
ok so for diff fluid use Redline 75w90 and for tranny fluid use Redline MT90 you can find these on the internet for the clutch go with a OEM M3 clutch kit it will be smooth and never slip under abuse also while you are in there either get your stock flywheel resurfaced or a lightweight aftermarket flywheel, places to get these goodies
www.bmpdesign.com
www.bavauto.com
www.bekkers.com
www.turnermotorsport.com
good luck
Old 03-27-2005, 09:45 AM
Mein Auto: nothing
ok thanks a lot for your help
Old 03-30-2005, 03:00 PM
Mein Auto: nothing
www.bmpdesign.com
www.bavauto.com
www.bekkers.com
good luck
i went to order the clutch kit today at my local Bmw dealer. I told them i had a 95 325i and wanted to put in a 95 M3 clutch kit instead. So she check on the computer it had different part # then a 325i. Then she asked the Technian he also said it will not work Now my question is does it have to be another year M3 or is the staff not know what they are talking about. And do i need a M3 flywheel also or would a 325i flywheel work. I am ready to do the clutch i need help asap.
Thanks to all in advance.
Old 04-05-2005, 04:13 PM
Mein Auto: nothing
Anyone
Old 04-05-2005, 04:20 PM
Chris90 Chris90 is offline
Mein Auto: '04 330i
I know an M3 clutch fits fine, and I assume a '95 M3 would be the right one, most BMW dealers don't want to do this stuff, find a good BMW shop. BMW Club Canada should have links to good mechanics.
I believe if you want an M3 clutch, you need all M3 parts, which I assume includes the flywheel.
Are you interested in an LSD? It costs around $1500 to put one in your 325i, including labor.
"When you were born, you cried and the world rejoiced. Live your life so that when you die, the world cries and you rejoice." - Cherokee Expression
Old 04-05-2005, 04:21 PM
Mein Auto: '04 330i
this is not really the best site for E36 stuff, try bimmer.org.
Old 04-05-2005, 04:36 PM
Mein Auto: nothing
Thanks a lot for your help
Similar Threads
What options to get in a MINI? Zeegar The MINI Board 7 01-27-2005 06:34 AM
traction control dsc question KwlAznKid 3 Series / 4 Series 30 12-19-2004 07:27 PM
E46 LSD...easier than you think... Ben Liaw 3 Series / 4 Series 6 08-07-2004 08:12 PM
6-speed + LSD conversion? calvol 3 Series / 4 Series 2 08-17-2003 09:09 PM
DSC and an LSD webguy330i 3 Series / 4 Series 6 02-03-2003 07:51 AM
