Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series / 4 Series > E30 (1982 - 1993)
E30 (1982 - 1993)
Old 03-23-2005, 08:30 PM
rickburby rickburby is offline
Mein Auto: 87 325i, 86 735i
87 325i Idle Problems
I AM HAVING IDLE CONTROL PROBLEMS. I REPLACED ICV AND ENGINE STILL JUMPS UP AND DOW. I HAV ETHE mOTRONIC 1.1 WITH 3 WIRES. I KNOW ICV IS GOOD, I SWITCHED IT WITH MY 86 735I AND EVERTHING WORKS. ANY IDEAS
Old 03-23-2005, 08:34 PM
Lanc3r Lanc3r is offline
Banned
Mein Auto:
#1 Please stop yelling (CAPS)
#2 Is your idle problem at start up (cold) or at normal oper. temp?
Old 03-23-2005, 08:41 PM
At start up and as I drive. Of course I only notice it at stop lights.
Old 03-23-2005, 08:46 PM
Banned
Mein Auto:
At start up
Cold start valve. Do you have a manual?
Old 03-23-2005, 08:52 PM
I have a Haynes 3 & 5 repair manual. Is cold start injector expensive to replace?
Old 03-23-2005, 08:59 PM
Banned
Mein Auto:
If you go to the stealer, yes.
Its @100$ for the part, if you go aftermarket, Bosch only.
Its pretty easy to replace.
Old 03-23-2005, 09:08 PM
Will it hurt the car to drive it? It is quite frustrating to drive. Is that a part I could get used? I get some at vinesauto.com sell only bmw parts
Old 03-23-2005, 09:20 PM
Banned
Mein Auto:
IF the prob is only at cold start up, and it runs fine after its warmed up, I would say its ok to drive it. You might want to maintain the idle manually intil it is warmed up.
As far as buying that part used, I wouldnt recommend it. Its like buying a used lightbulb.
Old 03-23-2005, 09:27 PM
Thanks for all your help. I will try to warm it up and see if problem goes away. If not any other ideas? Manual also mentions Thermo-time switch in same section???
Old 03-23-2005, 09:33 PM
Banned
Mein Auto:
IIRC the thermo time switch is a mechanical part, that "should" be o.k. From my experience with the Old E30's, corrosion is my #1 enemy. I would check all the points, connections and clean or replace them. Also fun little things that would be a factor after warm-up are the oxygen sensor and the air flow meter.
Old 04-08-2005, 01:30 PM
9x16's Avatar
9x16 9x16 is offline
Mein Auto: 89 BMW 325i (4 door)
oxygen sensor is my guess.I had the same problem on my 85 eta.After new o2 sensor,it was gone.
Old 04-08-2005, 03:06 PM
89 325i 89 325i is offline
Mein Auto: 1989 325I
Not sure we have the same problem though the symptoms sound close, but my '89 325I was having cold start/rough cold idle issues. Cure: New Cooleant Temperature Sensor, which tells the computer to leave the injectors open a little longer in cold weather; new Fuel Pressure Regulator, and new Fuel Pump Relay. Parts = $145, Labor = $160.
I still question the Coolant Temperature Sensor replacement, however, since Bentley says that when that goes the Check Engine light responds with a certain blinking pattern. Same with O2 sensor. Who knows.
The Motronic 1.1 did away with a separate Cold Start Valve, as I understand it.
Old 04-12-2005, 12:51 PM
julz's Avatar
julz julz is offline
Mein Auto: 92 318i Cabriolet
Hey misterlance, just reading your helpful replies here. I have a 92 318ic. The car runs beautifully except just recently during start ups. It seems a little rough at idle but only after it's been warmed up and only at the first stop light. I never drive it cold, always let it warm up. It idles at .8rpms and never waivers..that seems low to me. Back to the first issue though, the rough idle seems like it isn't getting air or gas would be my guess, but I'm not a mechanic. When I read your answer stating to check air flow meter or OS, could that be my problem too..(I realize diagnosis over posts isn't accurate)..but gives some point of direction. Thanks
Old 04-12-2005, 01:56 PM
Banned
Mein Auto:
When was the last time you had a tune-up (cap, rotor, plugs)? Next I would check all filters (fuel, air, oil). After that, you'll need to narrow down the fluctuation. Is it at start-up (cold)? Or is it consistent even after warmed up?
Old 04-13-2005, 01:47 PM
julz's Avatar
I have replaced the plugs (not the cap and rotor) in the last 1 year and 3 months. I have regularly replaced the oil and air filters. I have not replaced the fuel filter. If it isn't the OS or the FM, my guess would be the FF. It feels starved or choking for something but runs extremely smooth once we get going. It only does it at start up and only on my way "home" in the afternoon from work...not first thing in the morning. Our temps aren't that much different am/pm, maybe I warm it up longer in the am. If it isn't too much to ask you, could a person that is somewhat mech-inclined change the fuel filter? (me) Thank you so much for taking the time to answer.
Old 04-14-2005, 08:00 AM
WileECoyote's Avatar
WileECoyote WileECoyote is offline
Needs more cowbell
Send a message via AIM to WileECoyote
Mein Auto: 1999 Z3 2.8, 2000 328Ci
Whoa, guys....have you checked the air intake's elbow pipe, the one that looks like an accordian? If it has any cracks, especially at the flex points, replace it immediately. It's like $15. These cars are getting up there in age, so the rubber tends to break down.
I've had that problem, as did my buddy, and in both cases, replacing it solved the surging idle.
Old 04-14-2005, 08:08 AM
Real good idea. Were you able to spot the cracks by looking closely?
Old 04-14-2005, 08:13 AM
Banned
Mein Auto:
The FF is a slight pain to get to but it is straightforward ( I hope you have small hands).
It should be an inline type filter below the master cylinder.
Good luck!
Old 04-14-2005, 08:31 AM
Needs more cowbell
Yeah, it's pretty simple. Pinch it to cause it to flex.
Old 04-15-2005, 06:20 PM
BimmerBoy73 BimmerBoy73 is offline
Mein Auto: '89 325is
Good luck!
what type of plugs did u use? when was the last time you cleaned your throttle body? Also air flow meter flap is known to lose its ability to open flush to the housing and will actually start to make a groove after a while (long shot) but easy to R&R for both.
Old 04-20-2005, 02:49 PM
julz's Avatar
Good luck!
Thank you for treating me nicely. I've been having a rough time just trying to ask honest questions in some other areas. I'll give it a go on the FF.
Take care.
Similar Threads
325i idle / driving problems FLIP E36 (1991 - 1999) 7 08-04-2005 09:52 PM
2002 e46 325i idle surging issue starcentral E46 (1999 - 2006) 8 03-29-2005 09:07 PM
330CI Problems ref77 3 Series / 4 Series 6 09-19-2004 03:52 PM
Another newbie with 325i sp questions belsouth 3 Series / 4 Series 22 09-09-2003 06:58 AM
2003 325i wire harness problems. SlideR1 3 Series / 4 Series 1 07-31-2003 07:40 AM
