Old 08-17-2006, 07:57 PM
IN540-6 IN540-6 is offline
Mein Auto: 98 540i 03 330Ci 08 ML320
M5 Shifter Questions Need Guidance!
Just picked up an M5 shift lever and shift arm for a steal and I am going to install it in my car. I need advice on if I should replace the existing bushings, washers, ect... and which ones Thanks!!!!!
Also, how much will this reduce the throw anyone know??? Thanks again!!!
Old 08-18-2006, 12:20 AM
Vortec4800 Vortec4800 is offline
Mein Auto: 13 X3 35i MSport, 09 135i
While you're in there I would. I would also suggest looking into the UUC DSSR. With the shift level out, the install is already half done. I am very impressed with mine. Reduced 98% of the play in my shifter, and feels outstanding.
Old 08-18-2006, 02:58 PM
John 540i6 John 540i6 is offline
Mein Auto: 540i6
i felt the m5 shifter compared to my 540i shifter and i was not impressed in the least. I couldnt tell the difference. I was about to buy the m5 shifter but ive decided to try the e36 m3 shifter now since it makes the throw even shorter than the m5. Id be interested in seeing how you like yours.
Make sure to replace the plastic bushing that fits around the ball (pivot point) of the shifter. Thats about all you need to replace other than the lever.
Old 08-18-2006, 09:25 PM
MJTSUB MJTSUB is offline
Mein Auto: x3, e30 325ix, e39 540i/6
Agreed with everything stated above. The M5 shifter compared to the 540 shifter has almost no advantage. If you are going to go through the trouble of paying someone else or doing the install yourself you should go with the e36 M3 or the Rogue Engineering. Here is my install thread.
http://www.bimmerfest.com/forums/sho...d.php?t=150461
Similar Threads
Hamann BMW M5 love330i E60 M5 (2006 - 2010) 1 02-07-2006 06:00 PM
e34 M5 questions... wood_e 1M & M2 3 09-21-2004 11:16 AM
Just raced with a DINAN M5! Jimmy540i.com General BMW Questions 7 04-24-2002 08:26 AM
AC Schnitzer adjustable suspension Alex Baumann General BMW Questions 1 04-05-2002 09:33 AM
M5 aluminum shifter, possible on E46? RaysMD General BMW Questions 2 01-30-2002 07:55 AM
