E36 (1991 - 1999)
Old 03-28-2005, 09:04 PM
DC - '92 325is DC - '92 325is is offline
Mein Auto: 1992 325is Coupe
'92 325is coupe - loud "rubbing" noise in area of LR tire - only on rt. turns
1992 325is coupe, 5-speed, w/114k miles. I just bought this little black beauty and she came w/ full maintenance records going back to first owner. Always maintained at same San Francisco garage. A week ago I replaced the exhaust, from the cat – back, at a reputable BMW shop. Before that was done, the exhaust sound was loud, but I don't think it was loud enough to drowned out the noise I'm hearing now. Meaning I strongly suspect that something happened during the muffler replacement that caused the current problem. But I'm not certain.
What I'm hearing is a noise that almost sounds like the left rear tire is rubbing on the wheel well when I make a right turn, but I've jacked up that corner and looked closely, and I'm pretty sure that's not it. I see no evidence of anything rubbing on inside of tire, wheel well, or shock. Right turn can be very slight, or 90 degrees, but the sound only happens on rt. turns and absolutely nothing weird happens on left turns (no noise at all. If I listen real hard and sort of “gently swerve” to the right at about 50-60 mph, the sound almost sounds like it's coming from directly under the center console, and I can almost feel something rubbing or “clunking.”. Rubbing noise is probably related to speed of travel, meaning the "frequency" of the rubbing is lower at lower speeds, but it's still there.
I’ve also tried to make right turns while coasting (either in neutral, or w/ the clutch depressed), but I don’t think the sound is affected.
CV joint?
Thx in advance for any help.
Old 03-29-2005, 12:22 AM
Sev03 Sev03 is offline
Drivin Bmw since '03.
Send a message via AIM to Sev03
Mein Auto: 95 325i
i have the same car same year and same loud noise. and it comes from the barrings of the car. i was gonna change it but my mechanic had the wrong tool for it so hes gonna change it soon.im hoping itll get rid of the noise ill let you know if it does
Old 03-29-2005, 10:10 AM
Rubbing noise at LR only on rt. turns.
Sev03,
Thanks very much for responding to my post.
The bearings you're talking about - you mean the wheel bearings?
Meaning that your mechanic said either one, or both, of the rear wheel bearings need 2 be replaced?
Thanks again.
Dennis
Old 03-29-2005, 02:06 PM
Mein Auto: 95 325i
yea its the wheel barrings and hopfully itll take the noise away and if it does ill be sure to tell you. and np
Old 03-29-2005, 02:24 PM
CARLBRUM CARLBRUM is offline
Mein Auto: BMW318
try this
if it,s a hummin noise then it,s definatly the wheel bearing u can tap these out with about 32 socket
Old 03-29-2005, 04:40 PM
'92 E36 rubbing noise on rt. turns.
Carl,
Thanks for your feedback, but i really wouldn't describe it as "humming." It's really more of a 'rubbing' noise; I swear it initially sounde like my LR tire was lightly rubbing on the inside of the wheel well, but i can find no physical evidence of that.
Another possible clue I discovered while riding in back seat while my wife drove - again, only on right turns - I can actually feel a slight rubbing (like a bump-bump-bump) on the floorboard behind the driver. Left side of car - rt. turns only (body is leaning to the left); nothing on left turns.
Bad LR wheel bearing?
Thx again.
Old 03-29-2005, 08:01 PM
Mein Auto: 95 325i
yea mine is when i go over 40+mph and going straight or when i turn right and when i turn left the noise stops, and it does feel very bumpy feels like im running something over ever second. and i could hear it too when im in the passenger seat too.
Old 03-30-2005, 10:55 PM
ImperialDuckM3 ImperialDuckM3 is offline
Mein Auto: E36's
Could it be that you have bad shocks?
Old 03-31-2005, 12:32 PM
Rubbing noise on rt. turns only
Is it likely that bad shocks (especially the left rear one) would contribute to a noise like this? FWIW, the LR shock definitely makes an annoying squeeky-squeeky noise almost always.
Old 04-11-2005, 12:30 PM
Mein Auto: 95 325i
Loud noise gone!
I just got the bearrings fixed and no more noise! so if you get that fixed then it will all be gone. i can finally drive my car w/o a headache.
Old 06-29-2005, 03:03 PM
BigB BigB is offline
Mein Auto: '92 325IS
Rubbing noise
I also have a rubbing/ thumping noise from under the center console area... it started it on right hand turns... now it does it going straight down the road too... could it be the exhaust rubbing on the drive line? worn bushings? i'm stumped... help please.
Old 06-29-2005, 03:44 PM
FierySphere FierySphere is offline
Mein Auto: E36 325is
Broken exhaust hangers (the rubber pieces).
Old 07-01-2005, 12:51 PM
FierySphere
Hey thanks for the advice... fixed the problem... I had a broken hanger... got it welded up... no more noise.
Similar Threads
Dolphins fend off Great White attack! Jon Shafer Off-Topic 16 12-02-2004 10:19 PM
e46 Front Tire area making Noise Bimmer? 3 Series & 4 Series 1 04-10-2002 07:31 AM
