Hi there.
2006 328i with navigation
I've been reading and watching some videos on how easy it was to reset the service internals.
I've only had the car for 3 days but when I got it they showed me all the service was up to date and that the services had X amount of miles left to be done.
My question is. I've put a hundred miles on it already and checking a few of the services they're still at say 7000 miles left.
Should it be a ongoing tracker like if you drive 500 miles it will say 6500 left.
How does this system work and how do you know if it's properly working
Second question is when I fire it up it says right rear brake lamp error.
Yesterday I bought new big bulbs for it. Removed the liner on the trunk ( I saw the outer brake lamp was working ) then pulled the bulbs. To my knowledge they looked ok. And when I put my new bulb in it will didn't light up when my wife pushed the brakes.
The car was on and running when she did this.
Should I try to do it at dusk to actually see all the bulbs illuminate or is there some other thing I should look into?
Thanks.
Thanks.
