2013 238ix with a trouble code p126b - Bimmerfest - BMW Forums
Old 08-29-2016, 09:23 AM
ge12274 ge12274 is offline
Mein Auto: 328xi
I have a 2013 238ix with a trouble code p126b cannot find a discription of what this code is if i clear it it comes back on 3rd restart
Old 08-29-2016, 10:49 AM
tim330i's Avatar
tim330i tim330i is offline
Bimmerfest.com Founder
Mein Auto: Ti Silver 03 M3
Welcome to Bimmerfest! I've moved your question to our F30 3 Series forum, you'll get more help with your BMW in here. Are you sure that is the right code? How did you get it?
Tim
Bimmerfest 2018 - Coming soon!
Old 08-29-2016, 01:56 PM
seth3399 seth3399 is offline
Mein Auto: 2013 328i
F30 N20 2013 BMW 328i with a P126B Code
My sedan BMW 2013 328i has the same code, P126B with check engine light on and "Drivetrain malfunction: Drive moderately. Maximum drivetrain output not available. Consult service center." The only thing I've noticed on the car is the loss of acceleration. I've pressed the pedal so hard with little acceleration. Seems like the sport mode is not working anymore. I have replaced a fuel pressure sensor AND a manifold pressure sensor but with no luck.
Old 08-29-2016, 06:01 PM
jjrandorin jjrandorin is offline
Mein Auto: 435 Grand Coupe MSport
Originally Posted by seth3399 View Post
My sedan BMW 2013 328i has the same code, P126B with check engine light on and "Drivetrain malfunction: Drive moderately. Maximum drivetrain output not available. Consult service center." The only thing I've noticed on the car is the loss of acceleration. I've pressed the pedal so hard with little acceleration. Seems like the sport mode is not working anymore. I have replaced a fuel pressure sensor AND a manifold pressure sensor but with no luck. The problem still exists. I've been searching and come across two descriptions: The first one is P126B - Alternative Fuel Injector Driver Supply Voltage Circuit 2 and the second one is Turbocharger boost pressure sensor - the signal is low (Translated from a Chinese website.) Now, I'm really exhausted and don't know what to do with it. I have an emissions test due soon.
do you have more than 50K miles on this car? If not, have you taken it to the dealer?
2016 435 Grand Coupe Estoril Blue MSport |Hex. EB Trim-Blk. Dakota | MSoort | Technology | Drivers Asst. | Drivers Assist+|Lighting |Track Pack W/ 442 Wheels |Heated Frnt Seats | Smartphone Integration | HK Stereo (His)
2016 X5 XDrive35d Space Grey |Blk Dakota W/ Fineline Oak | MSport | Lighting Pack | Premium Pack | Drivers Assist | Drivers Assist + | ACC W Stop N Go | 20" Wheels| Smartphone Integration | Multi Contour Seats | HK Stereo (hers)
BMW CCA #477341
Old 08-30-2016, 04:06 PM
Update: A standard scan tool used on a BMW with a trouble code P126b is caused by a faulty wastegate actuator. I got a wastegate actuator replaced and the problem was fixed.
Old 09-25-2017, 06:00 PM
irving91605 irving91605 is offline
Mein Auto: 2013 328i F30
I'm having the same issue here. Did you replace the Wastegate Actuator yourself? or did the dealer do it for you? Also how did you find out it was a faulty actuator?
Old 12-04-2017, 06:13 PM
wjrez wjrez is offline
Mein Auto: 2013 328i xdrive
I got the check engine light and the indie I work with told me it was the wastegate actuator and it is almost $900 to replace. He cleared the code and the check engine light and it seems to run ok, but he said he can't guarantee it won't show up again. He did not think I could cause damage to the engine by continued running of the engine, but what is the experience in this forum? Is it worth the $900 repair? Does that cost sound reasonable? He is using BMW parts.
Old 12-04-2017, 06:21 PM
It was the Electric Wastegate that gave me the issue. I actually bought that wastegate on ebay from an X1. It was the same part number and it fit perfect, now my code disappeared and it has not been back on for a few months. Fyi I bought the used wastegate for $60 and installed it myself.
Old 12-04-2017, 08:37 PM
I bought mine from an online BMW website for $284.64 + $22.95 (tax) = $307.57. Seems like the price goes up now. You can find a cheaper one on Ebay. Part number: 11657638783.
code 126b
