E30 (1982 - 1993)
Old 03-31-2005, 02:32 PM
rickburby rickburby is offline
Mein Auto: 87 325i, 86 735i
Need a used 87 325i engine
I need an inexpansive good used engine. My current engine has 240,000 sounds like a rod bearing problem. I live in Columbus Ohio
Old 03-31-2005, 03:32 PM
Would it be better to replace Rod bearings
Would it be better to replace rod bearings and oil pump ?
Old 04-01-2005, 09:12 AM
Anyone have any ideas
Anyone with any suggestions for me?
Old 04-01-2005, 04:34 PM
Lanc3r Lanc3r is offline
Banned
Mein Auto:
Check the local wrecking yards.
Find a good Indy mechanic that knows bimmers. Maybe he can figure out what the actual problem is. You probably need a total rebuild at your milage.
Or check this place out.
http://www.bmrparts.com/engine1a.htm
P.S. You could probably buy a good running E30 for what the above options will cost in the end.
Similar Threads
325i engine conversion Goat04 3 Series & 4 Series 2 09-13-2004 04:38 PM
Rough idle and Check engine light??? dvs7310 3 Series & 4 Series 3 07-16-2004 08:48 PM
Engine swap, old 325i to young 325e OldBMR1 3 Series & 4 Series 1 07-07-2004 12:15 PM
NJ BMWCCA Round 2 Elwood Motorsports, Racing & Track 75 07-06-2004 04:45 AM
A few questions about a used 94 325i e36 dz223 3 Series & 4 Series 1 07-14-2003 08:38 AM
