Old 03-31-2005, 07:46 PM
B r i a n B r i a n is offline
Mein Auto: X3 3.0i
Dealer activated functions
When I asked my dealer about functions I would like activated he told me to go through the owners manual to determine what functions I desired and bring her back in. Unfortunately they are spread out throught the manual, so I developed a single list (I found 22 items). Thought it may help others: It is also attached in "word".
BMW X3 Settings/functions available
* denotes equipment optional
1 Page 18 Central Locking System
-The concept
You can have acknowledgement signal set to confirm the vehicle is correctly locked
2 Page 19 Opening and closing from Outside
-Using the remote control
As a reminder that the ignition Key is still in the ignition lock after you open the driver’s door, you can have a signal set.
3 Page 19 Opening and closing from Outside
-Convenience opening mode
Press and hold the "up arrow” button. The windows and the sliding panel of the panorama glass roof are opened. Press the "up arrow" button a second time and hold. The panorama glass roof is opened. You may have this function set on a vehicle-specific basis if you wish.
4 Page 19 Opening and closing from Outside
-Locking and Securing
If you desire, the vehicle locks automatically if no door or lid is opened after unlocking. You may have this function set on a vehicle-specific basis if you wish.
5 Page 19 Opening and closing from Outside
-Unlocking Tailgate
If you desire, the tailgate can only be opened using the remote control if the vehicle is unlocked. This can be adjusted.
6 Page 20 Opening and closing from Outside
- Using the door lock
You can have a signal set to confirm that the vehicle’s locks have engaged securely.
7 Page 20 Opening and closing from inside
The central locking system locks automatically after driving off. This can be adjusted to be vehicle-specific or key-specific.
8 Page 25 Alarm System*
- Arming and disarming the alarm system
You can have different acknowledgment signals set to confirm arming and disarming.
9 Page 25 Alarm System*
- Avoiding unintentional alarms
If you wish, the tilt alarm sensor and interior motion sensor are permanently switched off. You can have this set at your BMW Sports Activity center.
10 Page 30 Seat and Mirror memory*
You can have your vehicle programmed to automatically dial in your own individual adjustment settings for the seat and exterior mirror position whenever you use your personal remote control to unlock the vehicle.
11 Page 32 Automatic curb Monitor
You can have the angle of downward tilt set in dependence on the key used.
12 Page 47 Computer
-Mode selection
If you desire, you can display the following functions in a different unit (Fahrenheit/ Celsius, Gallons/Liters, 12hr/24hr).
13 Page 48 Ice Warning
After an ice warning has been issued. The display returns to the previous setting. You can have this activated or deactivated.
14 Page 49* Park Distance Control PDC*
-Automatic Mode
You can have a signal tone programmed into the system to verify that the PDC is active.
15 Page 57 Lamps
-Pathway lighting
When you activate the headlamp flasher after parking the vehicle and switching off the lamps, the low beams will come on for a brief period. You may have this function deactivated if you wish.
16 Page 57 Lamps
-Daytime running lights*
You can have the daytime driving lamp circuit activated on your vehicle.
17 Page 57 Lamps
You can have the sensitivity of the headlamp control adjusted.
18 Page 58 Interior lamps
If you desire, the interior lamps are switched on after mechanical unlocking of the vehicle. You may have this function activated/deactivated if you wish.
19 Page 59 Switching the interior lamps on and off
You can have soft dimming of the interior lamps set.
20 Page 61 Rear Window Defroster
You can have your vehicle programmed in such a way that the rear window defroster switches on automatically. It is then switched on at outside temperature of less than approx. 4C/39F within 5 minutes of engine start.
21 Page 64 Automatic Climate System*
-A congenial climate
Your vehicle had been designed to automatically select your personal climate control settings whenever you unlock the doors using your individually programmed remote control. If you want you can have this function deactivated.
22
(same as 20) Page 65 Automatic Climate System*
-Rear Window Defroster
File Type: pdf BMW X3 Settings and Functions Available.pdf (74.9 KB, 706 views)
Old 03-31-2005, 07:53 PM
Aaron325iT Aaron325iT is offline
Mein Auto: 2005 X3 3.0i
awesome info, thanks very much. just ordered my 3.0i, will have to get the auto locking doors and flashing lights on locking programmed when i get mine in late april.
as a side note my old '99 saab 9-5 used to switch on the rear defroster automatically too when it got cold. i thought it was a cool feature at the time. pity the power steering, driver's window, battery, lcd displays and other things all failed otherwise i might not be a bmw owner now!
"I heard hard work never killed anyone, but I thought, hey, why take the chance." Ronald Reagan
'05 X3 3.0i Jet Black/Black Leatherette+Sensatec/Aluminum Trim; Steptronic, Pano Roof, PDC, Heated Wheel
Old 03-31-2005, 08:13 PM
judybe83 judybe83 is offline
jb & ab
Mein Auto: X3 jb F250/5th wheel ab
we had to ask for the form 3 times before they finally gave it to us
after searching here and other forums we found that SOME dealeres give you the form when you buy/order your X3 others (ours ) act like they don't know what you're talking about???
i've attached the form, i hope, still learning this forum
Old 03-31-2005, 08:40 PM
jb & ab
hmmm can't attach .doc so we'll try this
this is a copy of the 4 pg form we received
SIB B 09 03 98
Car and Key Memory Settings E83 (X3)
"=" - Factory setting
Anti-Theft System
Interior sensor
= Active
Not Active
Arming/Disarming
Disarming only with remote control
= Locks and remote control
Tilt Sensor
= Active
Not Active
Acknowledgement - Vis. lock., without antitheft alarm syst.
Active
= Not Active
Acknowledgement - disarm visually
= Active
Not Active
Acknowledgement - arming visually
= Active
Not Active
Acknowledgement - disarm acoustically
= Active
Not Active
Acknowledgement - arming acoustically
Active
= Not Active
Acknowledgement - arm visually, lids closed
Active
= Not Active
Acknowledgement - arm acoustically, lids closed
= Active
Not Active
Central locking
Selective Central Locking
= Selective central locking
Not Active
Automatic lock after drive off
Active
= Not Active
Locking threshold
Terminal R
4 km/h (= 2.5 mph)
8 km/h (= 5 mph)
12 km/h (=7.5 mph)
= 16 km/h (= 10 mph)
20 km/h (=12.5 mph)
24 km/h (=15 mph)
28 km/h (=17.5 mph)
Lock after unlock, without open.
Active
= Not Active
Unlocking rear window
Active
= Not Active
Panic mode
= Active
Not Active
"="- Factory setting
Interior light
= Active
Not Active
Entrance aid
= Active
Not Active
Open tailgate
Active
= Not Active
Power Windows /SHD
1 touch driver window open
= Active
Not Active
1 touch driver window close
= Active
Not Active
1 touch passenger window open
= Active
Not Active
1 touch passenger window close
= Active
Not Active
1 touch rear window open
= Active
Not Active
1 touch rear window close
= Active
Not Active
1 touch open sunroof
= Active
Not Active
1 touch close sunroof
= Active
Not Active
1 touch raise sunroof
= Active
Not Active
Convenience open, remote control
= Active
Not Active
Convenience closing, remote control
Active
= Not Active
Lighting
Interior lights - Soft ON/OFF
= Active
Not Active
Interior lights - Inter, light on with unlck. via Ick.
= Active
Not Active
Interior lights - Inter, light on with term. R off
= Active
Not Active
Exterior lights - Daytime running lights
Active
= Not Active
Exterior lights - Home Lights (pathway lighting), time period
Not Active
= 40s
90s
150s
240s
Autom. driv. lights Ctrl. (Set of threshold values)
= Sensitive
Normal
Heating / A/C / Ventilation
Fan - Fan correction (increase/decrease by 10%)
= Not Active
Increase
Decrease
Vents - Flaps set point valve correct.
= Not Active
+3 degrees
+2 degrees
+1 degrees
-1 degrees
-2 degrees
-3 degrees
Vents - Rear window defroster
Active
= Not Active
Vents - Close footwell flap
= Active
Not Active
Vents - recirculated air memory
= Active
Not Active
Vents - A/C mode on when ignition turned on
Active
= Not Active
Seat and Mirror Memory
Seat adjustment
= Not Active
After unlocking and door opening
After unlocking with remote control
Autom. Kerb view park.funct.
= Not Active
Active
PDC
Switch - on signal
Active
= Not Active
Windshield Wipers
Rain sensor
= Active
Not Active
Car and Kev Memory Settings E83 (X3)
Displays/Language
Units - Consumption
Liters/1 00km
mpg (UK)
= mpg (US)
km/liter
Units - Distance
Kilometers
= Miles
Units - Time
= 12 hours
24 hours
Units - Temperature
Degrees Celsius
= Degrees Fahrenheit
Basic settings - Temporary ice warning
= Active
Not Active
Audio/Video
Key-specif, set. of Audio/Video
Active
= Not Active
Old 04-01-2005, 06:22 AM
pipo pipo is offline
Mein Auto: BMW X3
Thanks Brian and judybe83. Very helpful posts.
Old 07-11-2007, 10:36 AM
Sans Nil Sans Nil is offline
Mein Auto: 2007 X3 3.0si
I wanted to say, THANKS for this great information as well.
I'm a new X3 owner and this is really great to have all the customized options centrally listed.
Old 07-13-2007, 07:06 AM
brycem brycem is offline
Mein Auto: BMW X3 2.0 D SE
has anyone with a car which does not have xenons managed to have the day running light feauture activated?
Also has anyone with automatic folding mirrors managed to have the setting applied which means they fold when you lock car and unfold when you unlock? The feature is listed on my printout as per email above but the techs can't get it to work.
Bryce
Old 08-11-2007, 10:20 PM
contempt contempt is offline
Mein Auto: '07 X3 3.0si
Bryce
Just got my X3 today. I would love this function and asked my salesperson about it and he said it wasn't possible. Would love to hear otherwise so I can forced them to get it done.
Old 08-12-2007, 07:07 AM
AzNMpower32's Avatar
Tar Heel Faithful
No, you must use convenience close via the key hole. To lock, put your key into the door and turn clockwise and hold for a few seconds. The power mirrors (if equipped) will fold and the windows will go up. The next time you unlock, the mirrors will automatically unfold.
DRLs have nothing to do with what type of headlight installed.
Old 08-12-2007, 10:59 AM
MPBX3 MPBX3 is offline
Mein Auto: 2004 X3
After this is done, will they also unfold using the remote next time to open?
Old 08-12-2007, 05:41 PM
Mein Auto: 2004 X3
Tried this and only the windows went up down. Nothing with the mirrors folding.
Old 08-13-2007, 02:53 PM
Same here.
Old 08-13-2007, 04:14 PM
Tar Heel Faithful
Yes. Are you turning the key clockwise (to the right) to lock? The windows should roll UP, not down.
Old 08-13-2007, 04:55 PM
Mein Auto: 2004 X3
They do both as stated.
I was hoping the mirrors would also fold and unfold.
Old 08-13-2007, 06:23 PM
Tar Heel Faithful
So, when you turn the key in the keyhole right to lock and hold it there, do the windows go up at all?
Old 08-13-2007, 09:57 PM
I believe MPBX3 and I are having the same experience. YES, when we turn the key the windows go up all the way; however, the mirrors do not fold close.
Old 08-14-2007, 05:20 AM
dduane dduane is offline
Mein Auto: 2007 328cic, 2007 X3
Explanations for setting
Is there a document anywhere that explains the dealer programmed functions? I know that some of them are explained in the manual, but a number of the functions on the form from the dealer do not seem to be in there. Specifically, the ventilation settings and the tailgate locking options. On my X3 I cannot open the tailgate with the remote unless the doors are already unlocked. I see the "Open Tailgate" function, but do I wnat it Active or Not Active?
Old 08-14-2007, 07:46 AM
Dealer informed me, for the liftgate to open from the remote, you must press and hold the button for 3 seconds.
Similar Threads
Does your dealer offer BMW loaners and car washes? Chipster General BMW Questions 59 01-09-2007 02:06 PM
X3 3.0i auto dealer incentive re-check heyloo Ask-A-BMW-Dealer 9 04-20-2004 06:43 AM
Pros and cons of buying local or from a dealer in the next state? 4th Coupe General BMW Questions 16 02-27-2004 01:27 PM
Euro Delivery, 1.9% apr and cash to dealer mystic 3 Series & 4 Series 1 06-20-2003 08:52 AM
Temporary Fix For Nav Volume by Dealer rwebbe 3 Series & 4 Series 1 06-29-2002 08:34 AM
