E39/M62 engine life, high mile record?
76K views 65 replies 54 participants last post by  golferjohnm
#1 ·
What is the "forum record" for miles on an original BMW engine block, cams and heads?
I have a new-to-me 2000 540i with 96,000 miles on the odo. I'm looking at extended warranties (have one now, till Nov this year), and I'm checking in to engine life expectancy.
In a recent Autoweek, I found Vines Auto, a BMW salvage in Alabama. I called and talked with a guy there for about 30 minutes and learned quite a bit. He said his wife has a 540i with the first generation of Alusil block (4.0 liter), and she has 190,000 miles on the original block, heads, cams, etc., with no signs of impending problems.
He says if no fuel injector or spark problems occur that might cause unburned fuel to wash down the cylinder walls that the Alusil can far outlive steel cylinders. Most all problems he sees with blocks are due to fuel wash problems, and second to that, overheating. He sees very few, if any, camshaft wear problems as long as oil changes have been maintained correctly. He also has reman engines, short blocks and long blocks, as well as reman cyl heads in pairs or singles.
#2 ·
That`s nothing ... :rofl:
I have seen an E39 540 with 450.000 miles on it. Many cars have like 100.000 or 200.000 miles on the odometer ... but ... :D (the truth is outthere ...)
That`s a common view with 10+ year old cars. (E32 730i V8 - still running smooth)
#3 ·
BMW, Mercedes, & Toyota are easy 300k engines when properly taken care of. Of course, there are bad apples once in a while.
I'd take a 2.8 German engine over a 2.8 Domestic engine any day. 2.8 domestic engines are practically engineered to blow a gasket between 50-60,000 miles.
Now a 4.0 engine doesn't work nearly as hard, so you should see a great life span out of it. I'd worry more about taking care of the paint and interior than the engine, we're talking German precision engineering here. The sun will do more damage than holding the pedel to the floor every day.
#6 ·
Extended warranties are a waste of money***8230;you have to wait until something breaks and leaves you stranded, and the repair cost is usually no more than the cost of the warranty.
#13 ·
Extended warranties are a waste of money***8230;..you have to wait until something breaks and leaves you stranded, and the repair cost is usually no more than the cost of the warranty.
Take the money that you are going to use on the extend warranty and put it aside in the bank. Its a waste of money and most cases they never cover anything that is wrong with the car. For example I have heard this story, a person had a leaking oil gasket the warranty company would not replace the gasket under warranty. Then he let some one drive his car the borrower did not check the oil and it ran out and the motor failed. The owner took the car in for repair and the warranty company would not pay for the repair because it was from neglect. I bought a warranty for my 328 for 3yrs 30K miles and in that time they only paid for maybe 300 dollars in the last 3 years. Waste of money in my eyes. Non the less I bought my 540 a year ago with 93K miles and it has 113K miles on it now over 20K in a year. I have to replace the water pump now since it is leaking and the brakes, but it will wait till my finances clear up.
#8 ·
191950 miles on my 540i 6speed and still running almost perfectly. Have to change radiator (going racing rad with mechanical fan delete) and then do the lower and upper timing chain gaskets, upper rad gasket, front main seal, and probably soon main rear seal.
The 4.4l turned out to be more reliable then i expected. My oil pan pickup line was clocked with some plastic crap and my engine was starving for oil. I didnt know about that so i was pushing my car to redline almost every day and no problems. No i unclogged it and engine is running much better :)
#11 ·
hey there at 57k i had to replace the engine,...very well taken care of even oil change at every 3k....quick tip!!! any overheating issue for whatever reason, tow it...its better of paying for towing than a new or rebiuld block!!! love my car but its a surprise box even treating it better than i treat my wife lol!!
#12 ·
it seems that e39s run forever. When i didnt know better i wanted a trans am or a mustang for my first car but in the price range i couldnt get one with less than 90000 miles(v8 loaded and newer body styles). Before i got my first car(my current e39) my dad said those trans ams and mustangs will not out last the bmw and surely enough thats true.i still would love to get a mustang but it would have to be brand new since i know it hasnt had the crap drove out of it. im at 116000 on the 2.8 and have just fixed a few oil leaks and just regular maintance. i should get another easy 90000 to 100000 miles out of it
#14 ·
I bought my 2002 BMW 530ia new and it just ticked over 180000 miles. I usually keep my cars ten years of more and do the maintenance myself once its out of warranty. My Honda Accord was by far the most robust car I ever had, requiring only routine maintenance with the exception of a radiator replacement (which was easy), but the BMW comes in a close second. The car is seven years old at this point and so within the last couple of years I've started replacing things as I've noticed little problems. The biggest and most expensive repair was the cooling system--a total replacement, but it really wasn't all that much money--less than 500.00 and a lost weekend. I expect its probably normal to have to replace it every 4-6 years (which for me is about 96-144,000 miles). The crankcase ventilation system also needed a complete replacement shortly there after--every pipe and hose was brittle with age. I've replaced just about every engine sensor at this point, and replaced one fuel injection (can the others be far behind?). The power steering system leaked at the hose connections to the reservoir, which I understand is pretty common, but an easy fix. All told, the repairs were pretty standard when compared with other vehicles I've had, with the exception of the cooling system components and the CCV, which were somewhat more extensive, but not beyond the pale.
I haven't had to do anything to the suspension at all, although I could probably replace the thrust bearings and restore the original ride. I do recommend a decarbonization of the engine, which produces remarkable results. I maintain with a bottle of seafoam in the gas tank every 4-6 months. The result is an car that is still a pleasure to drive, and judging from the experiences of several of my friends, 350,000 is a completely realistic number for BMWs. I figure, setting aside tires and brakes, that I've spent about $1,500.00 in parts over the past three years to keep the girl running well.
Now I find myself in an interesting position--I could get a new car, but I don't really want to. The E39 is such an appealing body-style, even five years after its been discontinued (I'm not a fan of the successor design...), and I'm starting to think I may have my hands on a future classic. That's making me think it might be worthwhile spending a few thousand dollars to restore her to like-new condition, including new leathers and foam for the front seats, various trim items and possibly and engine-rebuild when it gets to that point
#24 · (Edited)
Whenever I think about trading my E-39 (145,000 miles) I think about all those systems at work every time I fire it up or turn it off. (Do you ever drive into the garage and sit and listen to all those systems shutting down?) Getting rid of it would be like throwing away my home audio system, my refrigerator, my furnace, and my computer, plus several other electronic gadgets. I just can't bear the thought of it. Maybe it's just me.
#16 ·
Mine has 193k miles and it still runs good. As long as you keep up with the maintenance, they should last forever. M62 probably outlast the car, you'll see wheels falling off long before M62 dies.
besides, we're talking about 50k+ cars, so generally expensive mid size/ large size luxury cars lasts much longer than average econobox.
#17 ·
I just turned over 194,000 mi on my 2000 540. I hope to keep it long enough to double those miles. I agree with apiereder about the e39 styling. I prefer my car to a new one although I do like all the intergrated electronics of newer cars.
#18 ·
A good question to ask would be what's the record for miles on the original transmission, especially the 5HP24 EH.
#19 ·
My 3.5L M62 has done 250,000 kilometres so far. Never given me any trouble at all, never throws any codes (well the camshaft sensor died and an oxygen sensor died 12 months ago, but they're maintenance items anyway) the engine itself is a gem- look after it and it looks after you.
My ZF 5HP24 auto tranny covered 220,000 kilometres with the ORIGINAL fluid in it, and then it grenaded a clutchpack. Rather than go for the expense of a new or second hand tranny (which was what the dealer was trying to push onto me), I took it away from the dealers and opened it up myself on my workbench, and found it blew clutchpack 'A'. That part cost me $400 from ZF, and hey presto, a fluid flush, new filter and we're in business again :) The tranny has now done 30,000 kilometres since I rebuilt it myself, and its still going strong.
Took awhile for the pressure adaption codes to work out what was going on with the new clutchpack in the tranny, but now its all good :)
I think my suspension, front wheel bearings and timing chain tensioner cartridge are all the next things to do on my list.
#20 · (Edited)
540i 1999
Three years ago I bought a well-maintained 540i @ 136K mi. It now has 162K. I replaced the fan, radiator and cooling system as a result of a failed water pump. I also replaced the alternator... it was liquid cooled! $$.
I put on new disks in the front and have changed a dozen or so brake light bulbs. $3,000 in repairs at the dealer, no lesss, in three years, much less than a regular payment. Just recently I found a great independent BMW repair shop who charges about 1/2 the dealer. That is the key.
In spite of these problems, the car is as tight as new and runs very well. The interior leather and electronics all work well and the sound system is still top notch (although behind in tech). I live in a very cold-weather climate and the rwd is getting to be annoying, but the car seems like it will do another 160K. It is the best "cheap luxury" car you can find - and there are some good deals out there.
BUT.... I'm taking delivery of a 2008 335xi tomorrow, and am selling my kid brother the 540. Enjoy Bro! :bigpimp:
#21 ·
Interesting so many people are in the 19x,xxx range. I am at around 195,000 - 198,000 or something like that. ( Who cares! LOL).
mw
#23 ·
2000 540i6
142800 miles
New timing chain and guides WP and many gaskets about 4 months ago.
new Alt 2 yrs ago
replaced front suspension about 3 months ago...
Due for a clutch but still ok if i dont push it real hard...
DSC module died about 3 months ago... non fixable :( still broke.
various things, Intake gaskets, zero pressure cooling system, plugs, a couple coils...
i will stop writing now...
#26 ·
180000 here
My girl runs like a champ, and still gets ooohs and aaahs being a sport packaged touring, which is rare in these parts, especially with all the glass tinted out.
She needs cats and is bogging, I would love to drill them out b/c the fix is a fortune.
#28 ·
Price
Well, considering I take such great care of my car, it is never going to get what I think it's true value is. At this stage, it is best to keep it for one of your kids or as a second car. If you have to sell it, don't be surprised at lowballers looking to steal it away for a lot less than blue book. You know what energy and care to the car you put in. Mine has 187000 miles, but it runs better than some friends cars with less than 25k. I would say my 525i sport wagon would sell for 6400.00, but I would ask 7000.00
#36 ·
First, 236K miles and going strong.
To Maverick10's point, value is a relative term; market value versus personal/perceived value for example. If I sold my car, I would never get out of it what I put into it. But that is not my concern. I put the money into for my own entertainment and I intend to put more money into it as it needs it since I do not intend to sell it.
These are great cars. What value you put on your car is a personal judgement call.
