E30 (1982 - 1993)
Old 04-02-2005, 01:52 PM
rgouette rgouette is offline
Mein Auto: 1987 325
rough acceleration
What it does: when either accelerating moderately, or going uphill, it acts almost like theres bad gas, or the fuel filter is clogged with grape jell or something...
If I really get my foot into it, it takes off!
What's ben done recently: New air filter/fuel filter/spark plugs/gas treatment.
I've owned this only for a short time & it's so far not run really well, I believe.
Year: 1987
Engine: 2.7L
Trans: manual 5 speed
Miles: 140,000
Cheers & thanks!!
Rich
Old 04-02-2005, 01:57 PM
msbrown's Avatar
msbrown msbrown is offline
Z3 Crash-test Veteran
Mein Auto: 2002 325i
(Looks at mileage) clutch slippage?
Old 04-02-2005, 03:45 PM
Mein Auto: 1987 325
clutch?
I was hoping noone would say clutch..
is here a reasonably good way to narrow that down as the culprit?
over
Old 04-02-2005, 10:14 PM
pup's Avatar
pup pup is offline
Mein Auto: 89/94 325is 02 325i 05mcs
over
is the engine hesitating or is it still winding up fine and the car just won't accelerate?
Old 04-03-2005, 01:43 PM
Mein Auto: 1987 325
rough....
The whole engine is sputtering.
Rich
Old 04-03-2005, 06:35 PM
pup's Avatar
pup pup is offline
have you troubleshooted for vacuum leaks? most engine roughness with these motors are a result of a vacuum leak.
Old 04-08-2005, 02:20 PM
9x16's Avatar
9x16 9x16 is offline
Mein Auto: 89 BMW 325i (4 door)
Its probably the 02 sensor.If you have bad acceleration,hesitating ,then my guess is the o2 sensor in your exhaust.When was the last time you replaced it?
Similar Threads
Airbags and full face helmets ·clyde· Motorsports, Racing & Track 43 11-20-2004 12:44 PM
Help with rough acceleration gray330 3 Series & 4 Series 2 06-10-2004 03:02 PM
Rough acceleration 323iE46 33beto 3 Series & 4 Series 6 01-02-2004 03:20 PM
Rough Idle, and Runs Rough??????? TimDogg 3 Series & 4 Series 0 12-27-2003 12:41 AM
car idling rough toniarae 3 Series & 4 Series 13 01-11-2002 06:10 PM
