E36 (1991 - 1999)
Old 04-03-2005, 06:41 PM
kishg's Avatar
kishg kishg is offline
E30 Maniac
Send a message via Skype™ to kishg
Mein Auto: too many bmws
steering vibration when cornering at speed
i have a vibration from the frontend when cornering at high speed. usually after 60mph. It only happens when i am taking a left turn. im wondering if it could be the tie-rod ends. Increasing the front tyre pressure seems to reduce the vibration but makes for a rough ride.. im considering replacing the front-end including the control arms, tie rods and bushings. anyone else have a similar problem? any insights would be appreciated.
Old 04-03-2005, 07:51 PM
SergioK's Avatar
SergioK SergioK is online now
Donkeybike?
Mein Auto: HP2Sport - R1200GS - F30
Sounds like tires that are out of balance. How many miles on that set? It could also be that you lost a wheel weight.
Old 04-03-2005, 08:14 PM
kishg's Avatar
E30 Maniac
about 10k on the front set. could it be a bent rim?
Old 04-03-2005, 09:33 PM
AC Schnitzer AC Schnitzer is offline
EURO STYLE
Mein Auto: two/325i,VW,Renault
check the PSI on each tire. Make sure nuts all nice abd tight.
Old 04-03-2005, 10:50 PM
SergioK's Avatar
Donkeybike?
Get the fronts balanced and you'll find out.
Old 04-04-2005, 01:00 PM
Sev03 Sev03 is offline
Drivin Bmw since '03.
Send a message via AIM to Sev03
Mein Auto: 92 325is
it might be the wheel baerings cuz mine is when i go 40+mph makes a vibration but when i turn left it stops making the noise and im gonna change mine soon ill tell you what happens
Similar Threads
BMW 330CIC: 2001 vs newer steering. Difference? elmalloc 3 Series / 4 Series 18 09-14-2004 11:00 AM
Pros and Cons of Speed sensitive steering assist v. Engine speed sensitive Magna 3 Series / 4 Series 5 07-02-2004 01:49 PM
Lighter steering after installing M3 steering wheel tk 3 Series / 4 Series 5 06-13-2002 11:27 AM
Perfect steering at last (long) PG 3 Series / 4 Series 25 05-15-2002 12:01 PM
Alternative to a shorter diff? Nick325xiT 5spd 3 Series / 4 Series 28 04-05-2002 07:06 PM
