Suspension question - Bimmerfest - BMW Forums
Old 07-13-2002, 08:05 PM
daven daven is offline
Mein Auto: 1999 BMW Z3 Coupe
Question Suspension question
I'm driving a 99 Z3 2.8l coupe with 17" wheels.
Suspensionwise I upgraded the OEM shocks to Bilstein Sport shocks last fall to correct severe body roll at the track. So much so that I wore through the plastic wheel well cover on the front passenger side. Seemed to work great. Went to NHIS after the upgrade and the roll went away. This spring before a session at Lime Rock, I discovered much to my dismay that both my upper and lower ball joints were shot with only 11,000 miles. (Public transportation commute and little free time = low mileage.) Dealer replaced them under warranty and replaced the rear sway bar links that were under an owner requested recall.
I've been to Lime Rock twice this year and noticed no severe body girations - with the exception of 1 spin coming out of Big Bend last time
Today while changing my oil, I noticed that I have worn through the plastic wheel well cover on the front driver's side and can feel where it has been rubbed on the passenger side.
Any ideas? I lose my warranty in September, so it'll be going in to the dealer for a look see by their experts, but I trust you guys more.
Would upgraded sway bars help? I'd like to leave the springs to last; Boston roads suck and even with stock springs and the Bilsteins the ride can get a little rough.
Thanks in advance
Old 07-13-2002, 08:21 PM
scottn2retro's Avatar
scottn2retro scottn2retro is offline
into things retro
Mein Auto: '02 M3 SMG & '08 135i
Hi daven -
Are the 17" wheels from factory or standard for your car or did you upgrade from 16"? If you upgraded, did you go to a tire size that was the same outside tire diameter as the factory tires?
Old 07-14-2002, 06:01 AM
Unhappy Maybe this is the answer?
The wheels are aftermarket upgrades and are 8 x 17 rather than stock 7.5 x 17. (So much for Tirerack saying they will fit perfectly) Tires are
stock 225/45 R17.
If this is the problem, is there a fix?
Thanks Scott
Old 07-14-2002, 12:31 PM
into things retro
should not be a probelm . . .
It's definitely possible to upgrade wheels and tires and keep the same (or close enough) outside diameter of the tire.
The suspension geometry is designed for a certain tire diameter, so if someone were to increase or decrease the tire diameter enough with no other changes, then the suspension geometry changes and could account for things like bushings wearing out prematurely.
That doesn't seem to be the problem in your case. Your car already had 17's and I don't think a half inch increase on the wheels with the same tire size would make too much of a difference. The wider wheel should allow you later to go to a wider tire with a lower aspect ratio (in your case 45 down to 40) and keep the same overall tire diameter.
Any other suspension gurus out there got any ideas?
Old 07-14-2002, 03:25 PM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
One thing is to compare offset on the sheels. If the wheel has the extra width in the wrong place, it could lead to wear also.
Sway bars could help. They would reduce roll during steady state cornering.
You might also contact H&R or another spring manufacturer about higher rate springs, but with stock ride height. This would make the ride firmer though, but without the added problem of lower ground clearance.
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Similar Threads
Front suspension install question..... Shawn Fogg E36/7 Z3 (1996-2002) 22 08-03-2003 02:15 PM
suspension question powerdrift 3 Series & 4 Series 4 02-10-2003 10:37 AM
A Simple Suspension Question PunchIt 3 Series & 4 Series 8 11-01-2002 12:14 PM
Suspension Question.... GSXR Drew E36/7 Z3 (1996-2002) 7 04-18-2002 07:10 PM
A Real Steering question/concern & suspension question on 2002 325/330 AF 3 Series & 4 Series 8 04-01-2002 08:29 AM
