Its code time again!!!! - Bimmerfest - BMW Forums
E30 (1982 - 1993)
Old 04-13-2005, 03:24 PM
kenkorsak kenkorsak is offline
Mein Auto: 325i Convertible
Went out to the car turned on the key and depressed the gas pedal 5 times to reveal an OBD I code, the light flashed code number 1231 which is, Battery Voltage/DME Relay Monitor. This monitors the condition of the battery and charging system, and produces a fault if a component goes out of specification or fail. I changed the battery in Nov. My question is how to test the charging system without taking out the alternator? I know I can remove the positive cable while its running, not good for the car. Is there any other way of checking the voltage the alternator is putting out? I can't reach my hand to the back of the alternator (not enough room) to put my volt meter on it. Is there anything else I can try?
Similar Threads
ED re-delivery wait time report MaxTimeOff European Delivery 4 11-24-2004 03:06 PM
t Nick T. The Test Board 5 07-05-2003 09:25 AM
