330i Front/Rear Shock Replacement - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Do-It-Yourself H.Q.
Do-It-Yourself H.Q.
Share your DIY projects that have helped you keep your BMW running. For questions about how to fix your BMW use the model specific forums. All BMW DIY tips, tales, and projects discussed inside. Learn to work on your car and know the right BMW parts you will need!
Old 04-07-2005, 12:03 PM
Wosby's Avatar
Wosby Wosby is offline
Send a message via Yahoo to Wosby
Mein Auto: 2007 E90 335i
Hey Guys,
I'm preparing to replace all 4 shocks (Bilstein Sport) on my 330i. Although I've done a shock replacement on my previous E30, I've never done a shock replacement on and E46 before.
Has anyone here done this replacement who can tell me some things I might need to look out for, or what else should I consider replacing while i'm under there?
Any information would be helpful.
Thanks,
Wosby
Old 04-07-2005, 12:05 PM
Nick325xiT 5spd's Avatar
Nick325xiT 5spd Nick325xiT 5spd is offline
Send a message via ICQ to Nick325xiT 5spd Send a message via AIM to Nick325xiT 5spd Send a message via Yahoo to Nick325xiT 5spd
Mein Auto: M3 & 323i/999 KP
Well, it's a lot easier.
Don't break your xenon headlight adjuster up front, but other than that you've got the skills. The nice thing about the E46 is that front struts are just clamped in.
2006 GMC Sierra 2500HD 4WD Duramax LBZ/Allison 6-speed
2002 BMW M3 Alpinweiß/Black
1999 323i KP/GTS2 Alpinweiß
1990 325is Brilliantrot/Tan
1989 325is S50B30US Alpinweiß/Black
1989 M3 Alpinweiß/Black S50B32 (321hp, ITBs)
Old 04-07-2005, 12:52 PM
Andy's Avatar
Andy Andy is offline
Mein Auto: E30, M3, 540i
Use at your own risk…
1. Jack up car using front-side jacking point.
2. Put jack stand under A-arm, lower jack a little to put some pressure on the jack stand.
3. Use a 16 mm deep socket w/ a 17 mm open end wrench and remove sway bar arm nut
4. Using an 18 mm socket loosen the lower strut bolt (no need to remove, just loosen)
5. Using a 13 mm socket remove all three strut hat nuts.
6. Raise the jack as high as it will go, the a-arm will stay on the jack stand, while the car raises and the strut hat will lower from the top of the car. This is where you’ll break your xenon auto-leveler arm if you have not disconnected it (passenger’s side only).
7. Grab the strut, twist, pull up and remove.
8. Use a bungy cord to hold your brake rotor in toward the car so it doesn’t flop around and break your brake line.
It really is that easy!! Good luck!!
- 1987 BMW 325is
- 2002 BMW M3
- 2003 BMW 540i Sport
Old 01-27-2008, 10:50 PM
dmak94539 dmak94539 is offline
Mein Auto: 325 XiT
Shock absorber replacement
I am ready to replace the shocks on 2002 325xiT. Would the instructions work for it? Thx.
Old 02-23-2008, 08:54 AM
paul180 paul180 is offline
Mein Auto: 330ci
I made a DIY for changing the shocks/springs out. You can check it out here: http://www.bmw330ci.net/projects/suspension.php and maybe it will give you some guidance.
I would definitely change out your Rear Shock Mounts (RSMs) while you're there! Depending on your mileage other mounts/bearings may need to be replaced, but you might not know until you start taking things apart.
Old 11-05-2010, 09:20 PM
cosmoapt cosmoapt is offline
Mein Auto: 2016 M5 Competition Pkg,
What about changing the rear self leveling shock on a 7?
Similar Threads
Latest Fastrack - replacement rear shock mount bushings stock legal SoloII///M Motorsports, Racing & Track 20 07-22-2004 08:03 PM
"ZHP" vs. Stock 330i - Acceleration Numbers Emission 3 Series & 4 Series 63 06-02-2004 01:22 PM
Spring replacement, shock question pmb1010 Do-It-Yourself H.Q. 4 03-13-2004 09:10 PM
First 2500 miles: Thoughts on my 330i, Step, HK, Nav and other aspects OBS3SSION 3 Series & 4 Series 13 03-13-2003 07:02 AM
What bits of the 330i Performance Package are "worth it" to you? OBS3SSION 3 Series & 4 Series 30 03-09-2003 07:59 AM
