E30 (1982 - 1993)
Old 04-11-2005, 07:15 PM
jamilks jamilks is offline
Mein Auto: '89 325iS
89 325iS radio noises
My factory radio started making a strange rhythmic "pop,pop" noise after the car sat for a year while I got it together to do an engine transplant out of another 325iS I got for parts. If I sturn on the radio and leave it just "on" without any volume, no noise, and then later try it, the noise may or may not be gone.sometimes it is an ascending squeal then other times I;m lucky and there'e no noise for the whole time the car is running but this is becoming more and rare. I changed the amp with the one off the scrap car, no difference, got another radio off ebay, no difference....Any ideas out there? It is the cool model radio with the infrared adjuster slot under the screen, I realize I could get a Pioneer or Kenwood on sale locally for under $200 and be basically satisfied with the sound performance, but it wouldn't have the same orange lights as the other dash instruments etc..Anyone else experience this? Thanks!
Old 04-15-2005, 06:57 PM
BimmerBoy73 BimmerBoy73 is offline
Mein Auto: '89 325is
Clean and re-surface ground strap on alt. Also pull head unit out keep it wired but seperate from any chassis ground and start car. If that that doesnt work pull ant. out from back of head unit. By the way Nakamichi has a head unit low-pro and red like bmw e30 dash lighting.
Old 04-28-2005, 11:27 PM
heartbeat?
Thanks for the reply! From the lack of responses, I have to assume not many others have heard this noise (these noises...as it does vary sometimes...)
One thing I lacked to mention was the fact that it also makes these sounds with the engine OFF??? I did try the things you mentioned but no change. Reading the Chilton's manual's wiring diagram of the radio/amp circuit, they mention "unloaders". What do they do?
Maybe I just bite teh bullet and get a Nakamichi like you say....Anyway, thanks for the comeback! Aloha!
Similar Threads
Tons of 89' 325is parts!! trbo2go Classifieds 2 12-24-2004 03:53 PM
1999 E46 (328i sedan) and the radio will not work...keeps blowing fuses. abalto Car Navigation, Audio & Electronics by BAVSOUND 3 08-16-2004 04:54 AM
1999 E46 (328i sedan) and the radio will not work...keeps blowing fuses. abalto 3 Series & 4 Series 0 07-21-2004 07:31 PM
Check out this sweet 89 E30 325is Sean General BMW Questions 5 12-23-2002 09:43 PM
XM and Sirius Satellite Radio??? Upcoming gadgets for your ride BayDetailz General BMW Questions 0 01-24-2002 09:48 AM
