Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M Series > E36 M3 (1995-1999)
E36 M3 (1995-1999)
Old 04-12-2005, 06:57 PM
jd501 jd501 is offline
Mein Auto: '99 M3
'99 M3 Engine / Clutch (?) Hesitating
Hi, I have a '99 M3 with almost 80,000 miles, and just today the engine started hesitating, seems to be more pronounced when I'm flooring it. I originally thought it was my clutch slipping, since it seems to gerally be when I'm getting into 1st, but it's sputtered a couple times when I was completely in gear, specifically in low RPMs in 3rd accelerating hard, it jerks as if I had popped the clutch.
I have a Dinan intake (and exhaust), and it kinda seems like the intake isn't sucking in air, could a dirty air filter cause this kind of problem?
Any help is appreciated ... just kinda scared I'm gonna have to come with $1000 for a new clutch.
JD
Old 04-13-2005, 03:17 AM
stylinexpat's Avatar
stylinexpat stylinexpat is online now
Mein Auto: 2009 M3
JD
Have you had your fuel filter replaced? Clogged Fuel filter, Clogged Catalytic converter could also be something..
Old 04-13-2005, 06:19 AM
dawgbone dawgbone is offline
Mein Auto: 05 BMW M3
It could be a very wide range of things..I'm 99.9% sure that it isn't your clutch though..Because the ECU handles just about everything in that car, I would first advise a trip to the nearest scanner and see if the ECU returns any errors...Also check to see if it will do the same with DSC turn off...Because it sounds alot like the crappy shut down that DSC will do when you dump into second, meaning that there could be an issue with DSC...How long has it been since you had the timing chain looked at? Other things to consider:
-compression check...(don't be scared if #5 is a little lower, it will almost always be)
-change plugs...(get a good exspensive set of plugs)
Old 04-13-2005, 10:54 AM
Mein Auto: '99 M3
Drove again this morning ...
... and I'm more and more thinking it's the clutch ... I'm used to getting into first a bit under 1000 RPMs, and I think it just can't handle that anymore, and I really was popping the clutch yesterday. When I rev above 1000 to get into first is seems to act normal.
Dawgbone, the DSC suggestion makes tons of sense though the way I explained the original post, I really appreciate that ... my DSC actually won't turn off though! I had to take in for a smog check last year, they couldn't dyno it because the DSC kept kicking in. You press the button and nothing happens.
I bought it used from a dealer almost three years ago, and it's actually still under warrenty, but I just haven't had time to get that fixed ...
Thanks for the replies.
Old 04-13-2005, 12:42 PM
I'm not sure on e36, but I know that you cannot dyno an e46 past 6500 rpms..regardless if DSC is on or off..And I have yet to dyno my car(no smogs in Louisiana)..I know that there are ways to trick the ECU, but never cared to research it..
Really, if your clutch was going out, then getting into it at low revs(torqueing) would easily cause you clutch to slip IF your clutch was on the brink of failing..You would easily notice this by the revs getting higher and the car just inching along..Not really the way you explained it..I could not see nor ever seen it pop/jerk or sputter from a faulting clutch..
Where does the car start to engage(peddle position)?? Is it hard to downshift or just get into first after a stop??
In nuetral, does the car rev like it should..If it does and then only acts up in gear..then I would definately look into a compression check and /or checking for leaks where your Dinan intake meets the head..
Old 04-13-2005, 02:54 PM
Mein Auto: '99 M3
Hm, it engages at about where I expect it to, but it definitely feels like it's popping / sputtering, no hi revs. No problem downshifting, just getting into first. I'll look into the compression.
The dealers probably gonna give me a hard time about the aftermarket stuff, I should go independent?
Any good experiences with independents in the Santa Monica, CA area?
Old 04-16-2005, 10:28 AM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
Plugs, coil packs or connectors from coil pack to plug
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Old 04-18-2005, 11:20 PM
Mein Auto: '99 M3
Spark Plug, Coil
Just got the car back from BH BMW, turned out to be a bad spark plug and coil, somehow got them both replaced under warranty! I'm a happy camper.
Thanks a bunch for everyone's help
Old 04-19-2005, 12:08 PM
LordGop LordGop is offline
Bimmer Fester
Send a message via AIM to LordGop
Mein Auto: 05 325ci e30 325i cab
Gotta love the warranty hehe...
Pics soon
Old 04-20-2005, 01:27 PM
Pinecone's Avatar
M Mad
Told you so.
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
Old 04-20-2005, 02:39 PM
Mein Auto: '99 M3
Originally Posted by Pinecone
Told you so.
Yeah, that was very insightful
Did you have the same problem at some point?
Also, before I took it in I had been having a rough idle for as long as I can remember, where it would idle at about 700 but dip to 500 every minute or so ... seems to be fixed now.
Gotta make this car last until the V8 E90 M3
Old 04-21-2005, 03:30 AM
Pinecone's Avatar
M Mad
Not yet, just have been paying attention to E36 M3s and MZ3s issues for serveral years, and this it not uncommon. The other one that tends to give similar symptoms is the cam position sensor, and it is also not uncommon.
I may pre-emptively change the plug connectors on both the LTW and the M Roadster. I would like to go to Laser coil packs, but a bunch of money to do two cars.
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
Similar Threads
Bimmerfest Caravan Route, in case anyone missed it MarcusSanDiego General BMW 19 05-02-2007 09:55 PM
BMW's New Six-Cylinder Engines - In Depth sk330i General BMW 7 07-19-2006 04:52 PM
Tracking VINs of M3 Engine Failures? Zappo M Series 1 10-18-2003 06:05 PM
So I drove an E30 M3 tonight... Jetfire M Series 47 03-27-2003 06:18 PM
Easy to put a M3 engine in four doors? DaveN323i 3 Series / 4 Series 4 01-31-2002 11:31 AM
