E30 (1982 - 1993)
Old 04-13-2005, 09:57 AM
fporro fporro is offline
Send a message via MSN to fporro Send a message via Yahoo to fporro
Mein Auto: 87 325iC
suspension, brakes + project
hey guys,
finally ready to dive into this project. have all needed work done and parts pressed in.
The new rear bearings are in as well as the S/F Bushings, welded reinforments for rear sway bar to trailing arm mounting point.
any advise ?
thanks.
Frank
Old 04-13-2005, 10:11 AM
Lanc3r Lanc3r is offline
Banned
Mein Auto:
Awesome man! BahnBaum has A LOT of E30 suspension experience. I believe he has a stickied thread at Bimmerforums.com.
Good Luck!
Old 04-14-2005, 12:50 AM
Mein Auto: 87 325iC
thnaks misterlance,
i'll look up BahnBaum posts.
this is what i did so far...
- installed frame brake lines,
- rear sway bar,
- trailing arms into sub-frame,
- 3 jacks, raise whole assambly, wiggle in and attach old shocks to trailing arms., then you can pullback and forth on subframe assambly, line i up with S/F screws, dont forget washer between bushing and frame.
Similar Threads
Porterfield R4-S bedding question??? Zeegar E36/7 Z3 (1996-2002) 1 08-02-2004 01:38 PM
'01& up 530 brakes same as 540 brakes? ///-Power 5 Series 8 05-15-2004 07:54 PM
i've had my brakes checked out twice now, is it just me? (Please HELP) drpahjee 3 Series & 4 Series 1 07-23-2003 11:05 AM
