E36 (1991 - 1999)
Old 04-13-2005, 12:42 PM
ewbmw ewbmw is offline
Mein Auto: 318is
mass air flow sensor
Need advice. My husband has a 1994 318is. Check engine light came on last week, did it for two days. A couple times before that the car had problems turning over, but started ok. He put gas in it last weekend and when he tried to start it, it wouldn't turn over. He checked under the hood and said gas was spraying out of the engine somewhere, fire dept. and police got called out, yikes. Said he saw a hole in a line or something. Anyways,it was towed away and mechanic got it cleaned up, had to take stuff apart to clean parts out and diagnose it. So fas bill is $232 dollars. He says it needs a new mass air flow sensor. Parts $400 plus ~200 labor. Any ideas if this sounds right and is it a DIY or is it better to let them do it. I found a used part from Bavarian for $175 +sh or a new one Bosch sensor for 283, which would be better. Thank you so much in advance for any advice.
Old 04-13-2005, 05:57 PM
ImperialDuckM3 ImperialDuckM3 is offline
Mein Auto: E36's
Its a simple DIY. Man, I hope to get a wife like you. My wife don't know crap about cars
Old 04-21-2005, 08:50 AM
ZeroG ZeroG is offline
Mein Auto: 318 IS, 320 i
MAF Replacement .
I would do it yourself you can swap it in about 15 - 30 minutes. If you want you can give me the $200 and I'll do it.
-Chad
Old 04-21-2005, 09:35 AM
fastbimmer fastbimmer is offline
Mein Auto: 1994 325is
You are getting screwed on that deal. Is this at the BMW dealership?
Old 04-21-2005, 10:10 AM
gaspain gaspain is offline
Mein Auto: e36
the whole scenerio doesnt make sense. Remember she said gasoline was spurting out? The Mass airflow sensor doesnt have anything to do with that. If anything it is a problem with the FUEL RAIL...that is unless the gasoline burned the plasic on the MASS airflow sensor.
'94 325is, '03 M3 Vert, '86 M35a2
Old 04-21-2005, 01:53 PM
LmtdSlip's Avatar
LmtdSlip LmtdSlip is offline
Do the interns get Glocks
Send a message via AIM to LmtdSlip
Mein Auto: 325iC
We need more info:
Now that he has cleaned up the engine bay and replaced the fuel line is it drivable?
As this car is an OBD1 car you can diagnose the check engine light using the throttle pedal.
See this link for more info:
http://member.rivernet.com.au/btaylo...aultCodes.html
The MAS is a DIY job.
Photobucket
Similar Threads
The same old code again!!!! kenkorsak E36 (1991 - 1999) 5 04-04-2008 07:31 AM
* M6 * - Press Release from BMW Emission E63 / E64 M6 (2006 - 2010) 6 03-06-2007 07:20 AM
voltage from mass air sensor tadek E34 (1989 - 1995) 0 04-07-2005 09:51 PM
Tool: S54 mass air flow sensor removal Ron Stygar E36/7 Z3 (1996-2002) and E85 Z4 (2003-2008) 8 01-09-2003 05:00 AM
